Old 01-14-2006, 11:54 PM   #12826
ok thanks sent him a PM
James605 is offline   Reply With Quote
Old 01-15-2006, 04:04 PM   #12827
Adrian,
I tried to call you but its sunday... Dont thiknk your there, left you Pm.
Old 01-15-2006, 06:58 PM   #12828
hey guys orderd some diff rebuilds and a r12 belt some other little things for my mi2 and was wondering how long does it take for schumacher to send the stuff out?? i live in australia and ive been told 2 to 3 weeks is that bout right its just i want my new radio and he parts to arrive at the same time. lol i took the plunge and orderd a m11 with a airtronics digital servo thats good for .06 sec transit and about 115 oz of torque. still i little worried i havnt even got to hold a m8 or m11 no one in my area runs them its all futaba hopefully i might break the mould. any way let us know how long it should take roughly, thanks
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 01-15-2006, 07:41 PM   #12829
AdrianM's Avatar
UPS order ship same day as we get them and post orders ship next business day.
Adrian Martinez
Old 01-16-2006, 03:19 AM   #12830
first run with the EC on sunday was ok but need a bit of set up work lol. anyway
anyone got the part number for the driveshaft pins (bit that conects the drveshaft to the axle (not the one that goes though the hexs)i broke 3 of them. and i found out that the ones off the steel driveshafts do not fit the new ec ones, ther to fat. and i need some pins for next sunday if anyone can help,
cheers bob
bob33 is offline   Reply With Quote
Old 01-16-2006, 04:20 AM   #12831
mutley001's Avatar
Bob33
Unfortunately I had that problem too but all I did was cut cown a bodyclip to size cos I couldn't find a part number either! I did contact Schumacher UK and Chris Ashton recommended stripping down the shaft, greasing it and then threadlocking the grub screw back in (aparrently its this being a little loose that causes the pin to vibrate, snap and come out!) but he couldn't give me a part number either.
Anyway, its seems to have solved the problem, I've not had one break since.
HiH
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 01-16-2006, 04:50 AM   #12832
thanks paul. does the bodyclip work ok then? will it last ok. so i should strip them all down grease and thredlock? and i should b sorted
Old 01-16-2006, 05:25 AM   #12833
mutley001's Avatar
ran 2 whole meetings with it so far and no problems so seems fine! Funnily enough it only seemed to happen on my left rear shaft?!?! but since greasing the little cylindrical componedn in the centre and threadlocking the grub screw all have given me no problems at all.
Best of luck
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 01-16-2006, 05:58 AM   #12834
hi adrian have you recived an order for 2 pro diff rebuilds and a r12 belt and some diff mounts for a mi2?? im just not sure if my transaction was aproved i recived an email but there were no links to confirm it just being safe thats all thanks for ya time
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 01-16-2006, 06:21 AM   #12835
HarshGuy's Avatar
Is your inventory "online" in your e-commerce site? i.e. if I got an order confirmation, is everything on it in stok?
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-16-2006, 07:20 AM   #12836
AdrianM's Avatar
The pins for the driveshafts are in the needle rollers bag (U1633).
The website send a confirmation that the order has been placed and the order generally ships next business day if it is via UPS. USPS picks up too early for us to get post order out that fast.
Adrian Martinez
Old 01-16-2006, 08:48 AM   #12837
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
I am very interested in getting a mi2ec and have a few questions:
1. Is there a rear toe adjustment? (inboard or outboard)?
2. Is there a front inboard toe adjustment?
3. By having only 2 camber link positions on the shock tower, does that limit the 'tuneability' of the car?
4. What size is the standard spur? (and what would you use in 64dp?)
5. What size drivers are needed?
6. What springs and roll bars come standard with the car?
Any help or advice would be greatly appreciated.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 01-16-2006, 08:54 AM   #12838
thanks adrian so all i need is a pk of them?
dirtydog ther is plenty of ajustment on the car.im not sure how u ajust the rear toe tho (i have got the car but dont think u can) and for drivers all u need is a 2mm for all screws on the car. and a 2.5mm for droop screws.
Old 01-16-2006, 09:04 AM   #12839
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Every time we go to anything other than the 2 rear toe, we always go right back to it. Same with the camber link positions.
No there isn't.
Many of the current cars only have one location w/ vertical studs and you can adjust the height only. We've found putting the inner camber link anywhere other than directly over the hinge pin gives inconsistent handling.
Not 100% sure. Haven't got my car in yet. I belive the biggest 64p gear that you can use is 118, maybe 120.
2mm for the hex screws, 2.5 for droop screws, 1.5mm, .050", 7mm for the wheel nuts. I think that's all.
The rubber tire car comes with the white springs (what the majority of the setups we've been running on asphalt use) and the silver sway bars.
Jon Kerr is offline   Reply With Quote
Old 01-16-2006, 10:17 AM   #12840
AdrianM's Avatar
Jon is right on. The rubber car comes with 2deg and that is all we ever seem to run everywhere we go. You can get a set of U2450 plastic suspension mounts and they will let you hit 1.5 deg and 3 deg. However, like I said, we never run those.
The Foam car comes with 1.5 deg toe out of the box
No
3. By having only 2 camber link positions on the shock tower, does that limit the 'tune ability' of the car?
48P 89T. You can run up to 118T in 64P
1.5mm, 2mm, 2.5mm hex drivers and M3 (5.5mm) and M4 (7mm) nut drivers. This is what you use on all metric cars
K058 Mi2EC - 2pr White (14lb) springs and front and rear silver sway bars (1.2mm)
K059 Mi2EC Foam Spec - 1Pr Violet (27lb) and 1Pr Red (20lb) springs and a front Yellow (1.7mm) sway bar. No rear bar as you never use one on foam tires.
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
