Old 01-10-2006, 03:03 PM   #12736
Send a message via ICQ to MattW
Yes sanding the rings with 600 grit does make a big difference - i've been doing this for a long time. So far i would say that is the single biggest improvement i have done to diffs.
Might try some CA on them, i don't know - i have a brand new diff sitting on my bench at this moment..........hmm
MattW is offline   Reply With Quote
Old 01-10-2006, 03:19 PM   #12737
Trader Rating: 239 (99%+)
Sand and glue is the best!
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 01-10-2006, 03:37 PM   #12738
hey are there any tips on getting the cir clip out of the diff out drive?? holds the thrust bearing in last time i tried i broke one and righ now i have no spares? i tried to use and automotive circlip tool but the tip was to big is there something else i can do please help dont feel like wait for a week for ascrew kit to come from other side of australia
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 01-10-2006, 03:57 PM   #12739
mini-dub's Avatar
Trader Rating: 16 (100%+)
I used a pair of straight body scissors and dremeled the tips into a point that will fit the c-clips. They suck for body scissors now but you can still cut other stuff with the back of the blade. They work really well for removing c-clips though.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 01-10-2006, 04:09 PM   #12740
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
I have a pair of cheap round nose pliers that I got from my local hardware store for about a dollar and they work great. I dont know what its like down under but here most hardware stores have a cheap tool section take a look there maybe.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 01-10-2006, 04:43 PM   #12741
King-G's Avatar
Send a message via ICQ to King-G
I bought an inexpensive circlip pliers from Dick Smith Electronics.
I had to file a small portion off the tips to fit the schumacher circlip hole size, but they work perfectly and cost me just a few bucks
King-G is offline   Reply With Quote
Old 01-10-2006, 07:24 PM   #12742
hey do you guys seal up your batteryholder with ca?? i know your ment to sand and then putdrops of super glue on the chassis but do u guys do it to the battery tray and strap??
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 01-10-2006, 07:46 PM   #12743
King-G's Avatar
I personally dont bother C.A any of my chassis edges..I sand them round, and use wed / dry fine grit to give a glass like finish to the edges.
I havent had a problem with delaminating chassis in the time Ive raced.
I figure a hit hard enough to delaminate a rounded edge would still damage one with a thin layer of C.A.
I do file the edges of the battery slots slightly to prevent it cutting the cells shrinkwrap.
Old 01-10-2006, 09:55 PM   #12744
hey guys what soldering iron do u reckomend to do battery building and general wiring and repairs? 60watt or 80 watt or 100watt??
and why? is a temp adjustable iron wether waiting and saving for??
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 01-10-2006, 10:49 PM   #12745
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You'll want to get the best iron you can get with the widest tip you can get. An adjustable temp iron like the Hakko 936 that I use is nice but not a necessity. I used a Hakko 80 watt iron for a long time. It's cheap, comes with a big wide tip that's perfect for doing batteries. The key when doing batteries is to only have the tip on the cell for 1-2 seconds. You don't want to heat up the cells too much or you can damage them.
Jon Kerr is offline   Reply With Quote
Old 01-10-2006, 10:58 PM   #12746
BATT_MAN's Avatar
For battery assembly you should get a 100W 700'F (or an 80 Watt like Jon said) soldering iron with a 1/4 tip. The WELLER 100P is a very goood sldering iron to do packs. You can do most connections in less than 2 seconds.
For eveything else, any good station will do.
You do not want to use a lowwattage station to build batteries unless you are very good at soldering. The longest time you want to keep an iron on as battery tab is 5 seconds. After that you are asking for trouble.
You do not need more than 50W for general soldering like wires to the ESC and to the motor.
60/40 solder melta at around 420'F and Silver solder at around 470'F
What you need for battery/tab soldering is an iron with enough POWER not heat.
BATT_MAN is offline   Reply With Quote
Old 01-11-2006, 01:49 AM   #12747
does the pro diff rebuild kit in clude a pro thrust bearing or just a standard bearing?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 01-11-2006, 03:38 AM   #12748
SA_Racer's Avatar
Default MI2 bith BMI Chassis
Does anyone here have a base setup for a BMI2 on asphalt with rubbers? Has anyone here been able to compare the handling of the BMI2 to the EC? Id be interested in knowing the diffirence. I just got my MI2 a short while ago and have only run it once with foams and it felt realy great but we have a club race this weekend and Im going over to rubber so would apreciate any help that you may be able to give me.
SA_Racer is offline   Reply With Quote
Old 01-11-2006, 04:06 AM   #12749
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Set up
Marcos has a hot set-up that he ran this past weekend.
Shot him over a P.M. and I'm sure he will help you out.
http://www.rctech.net/forum/members/marcos-j-8722.html
RED-LINE M03 is offline   Reply With Quote
Old 01-11-2006, 07:49 AM   #12750
PW
PW's Avatar
Send a message via AIM to PW
Great setup for BMI2 (rubber/asphalt)
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
