Old 01-10-2006, 04:03 AM   #12721
if its just grity just strip it all down and clean evarythink well. rub the rings with some 600grit paper (not a must) get sum diff lube (i use ae stuff) put plenty in put all back together, tighten up fully, undo about qutter turn (but to feel) then lock it off with the locking grub screw on the outdrive. and thats job done. if it still feels gritty after that i would jsut get sum new diff rings/plates an diff balls
hih
bob
bob33 is offline   Reply With Quote
Old 01-10-2006, 04:03 AM   #12722
heavy's Avatar
Trader Rating: 20 (100%+)
Originally Posted by aus jd 2703
what do i need for a diff rebuild?? my diffs feel gritty thats all
Just pull them down and clean (use shellite) everything and rebuild as per teh manual. Use black grease on teh thrust bearing (small balls) and silicon grease on teh diff (large balls).
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 01-10-2006, 04:22 AM   #12723
ok did that still gritty could i just be being picky?? or should it be smooth?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 01-10-2006, 04:34 AM   #12724
well after a bit of use it wil get a bit ruff but nothink to worry about its wen it gets notchy worry
Old 01-10-2006, 05:22 AM   #12725
hey do u guys soak your belts in wd40?? heard it loosens em up for less resistance?? oh yeh u do let them dry lol
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 01-10-2006, 06:16 AM   #12726
dont think many ppl do that. just run a r12 belt up front ther abit freer than the stock 1
Old 01-10-2006, 09:23 AM   #12727
Racer X's Avatar
...still around, just quietly awaiting my car for my big return to racing.
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 01-10-2006, 09:24 AM   #12728
Racer X's Avatar
...and I promise to post the pictures of whoever looses the mullett challenge (won't be Stlnlst)
Schumacher Mi6
Integy
Old 01-10-2006, 09:29 AM   #12729
IslandBwoy's Avatar
Having done both, the R12 belt is much freerer than the stock belt even after soaking in WD.
IslandBwoy is offline   Reply With Quote
Old 01-10-2006, 11:35 AM   #12730
HarshGuy's Avatar
won't be me either ...so I guess that leaves Scott!!
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-10-2006, 12:50 PM   #12731
Send a message via ICQ to MattW
Any of you guys ever glued your diff plates to the outdrive?? Was mentioned to me over the weekend, seems like a fair idea that might improve the diff but it just kind of makes both plate and outdrive scrap with the plates get pitted.
Any thoughts?
MattW is offline   Reply With Quote
Old 01-10-2006, 12:55 PM   #12732
Super Moderator
Trader Rating: 17 (100%+)
glueing rings is an old 1/12th scale trick. you can do it with out wasting the outdrives. just dont use alot of glue.
Tekno | JConcepts | RRP | LutzRC | BOOM RC
Bob Barry is offline   Reply With Quote
Old 01-10-2006, 01:39 PM   #12733
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Mattw,
That is the single best tip I have recieved recently. My diffs are million times better after gluing them...
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 01-10-2006, 03:13 PM   #12734
IslandBwoy's Avatar
How does this help the diff?
Old 01-10-2006, 03:38 PM   #12735
AdrianM's Avatar
The key is to sand your diff rings with 400-600 grit paper and a little WD40 until you have even scoring across the full face of both side of the ring. I use a female out drive with the thrust bearing removed to hold the ring for sanding.
This makes the rings dead flat and smooth. If you do this alone your diffs will last months longer.
CA'ing the rings lets you set the diff even looser without ring slip. I have run diffs as loose as 3/8 of a turn that required great force to make the diff slip.
I really don't glue my rings anymore as I run Mod mostly and you don't want your diff too loose with a 7 turn. I usually run 1/4 turn lose.
Note that the EC comes stock with the U1954 thrust bearing. This means the thrust bearing is pretty much good for the life of the car. If you ever get a gritty diff. Flip the rings first and if it is still gritty replace the diff balls.
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
