Old 01-07-2006, 06:40 PM   #12676
hey guys is the 27t ultra flex front belt a good idea for running stock?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 01-07-2006, 11:49 PM   #12677
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Maybe OK for runnign stock, but most of us have gone to running the front belt from the R12. Part U2601.
Jon Kerr is offline   Reply With Quote
Old 01-08-2006, 02:33 AM   #12678
hey guys,
just wondering why the black "ball grippa's" wern't included in the kit,
as they seem to be in the manual as an optional part:
U2989 - Ball Grippa Sockets - Black (pk8)
AL-HEX is offline   Reply With Quote
Old 01-08-2006, 05:12 AM   #12679
IslandBwoy's Avatar
Brrrrr. 36 degrees. Definately not running today.
Anyone know where i can get report on how we (shuie) is doing at the Novak's????
R.
IslandBwoy is offline   Reply With Quote
Old 01-08-2006, 07:15 AM   #12680
protc3's Avatar
Congrats to Adrian for winning 1/12th GTP at the snowbirds warmup race this weekend!!
I gotta tell tell ya,he drove his A$$ off this weekend.i would have to say that it is the best i think i have seen him drive.thanks for all the help this weekend adrian.now we need to lay it down at the birds.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-08-2006, 07:50 AM   #12681
Trader Rating: 36 (100%+)
liverc.rccars.com
Wynn is in the Factory 19 B and Mod C
Goetz A Stock Foam and A Factory 19T
Kevin K. C Stock Foam D Factory 19T w/Weilyn
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-08-2006, 02:12 PM   #12682
King-G's Avatar
Send a message via ICQ to King-G
Extremely positive about the new car after its first outing, Q2 finish 2nd to the current pace setter at our track. The car was on winning pace in the finals, just 2 tenths in the 2nd final and very close in the 3rd until a front wheel nut decided to vacate...a quick pitstop (well 3 laps lost) and i was on it again, catching the leader by 3 tenths per lap and moving back to 3rd place by race end.
Car is a large step in performance over the original Mi2, has more turn at all speeds with great stability.
Not a single board all weekend, very easy to drive car.
Only issue i found was some chatter in the front cvd's at 80% dual rate, perhaps some metal flashing inside the joint causing this, will rebuild them and see if its cured.
On its first run on saturday a rear CVD pin loosened and ejected. I suggest dissasembeling them from new, greasing the cvd joint as it appears to be dry from the factory and reassembling with a dab of loctite on the grubscrew.
Car remained perfect all day, very consistent! no sign of tweak.
also better tire wear than the mi2, which is a sign the new geometry is sorted!
all in all very exciting!
King-G is offline   Reply With Quote
Old 01-08-2006, 02:17 PM   #12683
Send a message via ICQ to MattW
Sounds good, still not had chance to run mine yet been working on it though, and it's finally ready, hopefully for debut at a club race during the week.
MattW is offline   Reply With Quote
Old 01-08-2006, 02:26 PM   #12684
John_S's Avatar
hey just got finished with the build of my ec and was quite happy exept for missing ball ends for the steering rod. And another thing was did anyone notice that the shock preload screws were very loose on the threads and never had a rubber o ring in them? I was just wondering what the reason was for this. Thanks
John_S is offline   Reply With Quote
Old 01-08-2006, 03:22 PM   #12685
IslandBwoy's Avatar
Extremely positive about the new car after its first outing, Q2 finish 2nd to the current pace setter at our track. The car was...
I'm glad to hear this. Ive been aticipating the arival of the EC here in Central Florida, but at the same time I've been skeptical about "Starting Over". Mi MI2 is working so well now that I'm having a hard time thinking about leaving it behind. Afterall, if the EC is simply a modified MI2 and I've already moded my MI2 to include a lot of the changes dont I essentially have an EC already?!?!?!
Either way, like i said its good to hear that you have confidence in the new car. Maybe when your finished fine tuning it I'll get an opinion from you regarding the differences btwn the 2.
IF WE PUT BOtH CARS ON THE TRACK SIDE BY SIDE WHO WILL FINISH FIRST; THE CHICKEN OR THE EGG???
Old 01-08-2006, 05:55 PM   #12686
King-G's Avatar
unless you have modified your arm mounting positions (wider apart) and also the new tower geometry (also wider apart with refined camberlink geometry) with updated rear hubs and narrow hex's. Bellcranks moved rearward some 2mm, gearboxes further apart etc etc...you wont replicate the feel of the E.C from an Mi2.
The drivetrain is a big change, but its increase in speed is more attributed to the geometry changes, which are a result of 2 years R+D of Team drivers worldwide.
The Mi2 was a good car, but It was a rather drastic departure from the Mission, which there was lots of data / setup knowledge for, and had been honed over a number of iterations.
This car seems to have ironed out the teething bugs of the Mi2, numerous geometry changes all combining for one complete package.
I was faster than my Mi2 out of the box with the suggested setup, after some minor setup changes in qualifying (reduced droop 1mm f+r, moved shocks out 1 hole f+r, and changed bars to black 1.4mm) it was dialled in the finals.
The great news is that in development testing in the U.K the car has worked with a base setup (Teemu euro setup) everywhere with just minor changes. This tells me the geometry is well sorted.
Old 01-08-2006, 06:02 PM   #12687
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
You my dear sir are making me feel very good about the car. Thank you
Rod
ClemsonTigers
Team C Racing
TA10
RKeasler is offline   Reply With Quote
Old 01-08-2006, 06:03 PM   #12688
cornerspeed's Avatar
Had my first race with the MI2 EC today. Very good runs. TQ in Mod over Steve Wiess. Was leading for 2/3 of the race until I threw a wind in the motor. It happened at the end of the straight, locked up big time.
Very easy car to drive at speed, I was driving about 75%. No set-up changes all day.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 01-08-2006, 06:23 PM   #12689
RKeasler's Avatar
Don did Jon race with you? Are you using all Schuie Shock/spring setups?
Rod
ClemsonTigers
Team C Racing
TA10
Old 01-08-2006, 06:35 PM   #12690
Rod
No, Jon was not able to make it out. Not feeling well.
The only differences from the kit set-up/rubber tire car is:
I ran 30wt. front, 35wt. rear oils.
Outer hole on front tower
3rd hole out on rear tower
4mm front droop
4.5mm rear droop
upper camber link holes front and rear
Thats it.
There are some things that I would like try next time I already have ideas for. Overall very easy to drive and was at winning pace already on its first outing. Its only gonna get better.
Donny Vinkemulder
TLR Driver
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
