Old 01-02-2006, 12:15 PM   #12586
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Pics PW!!!!
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 01-02-2006, 12:24 PM   #12587
Originally Posted by RKeasler
Pics PW!!!!
Rod
Rod,
Paul posted Pics of his car on the bottom of page 416. I hope this is what you were looking for
Later
Jim
Fantom, BL Racing, Retired
jimnew is offline   Reply With Quote
Old 01-02-2006, 03:12 PM   #12588
RKeasler's Avatar
Nah, that's the Carpet version I want to see the regular EC
Rod
ClemsonTigers
USVTA # 224
ERC
Old 01-02-2006, 03:33 PM   #12589
Send a message via ICQ to MattW
Not great pics, as the lighting wasn't so cleaver.
On a side note, has anyone (Paul??) fitted 64dp spur gears yet?? What's the easiest method. Looks like there is plenty of room (tried it!) for both Kimbrough or Xenon, just needs the holes countersinking/Counterboring.
MattW is offline   Reply With Quote
Old 01-02-2006, 03:51 PM   #12590
dont shoot me but what is the difference between carpet spec and the normal mi2ec??
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 01-02-2006, 04:28 PM   #12591
hi guys jsut finished building my EC just got to get sum bits in it now
talk of this droop what do u recon i use the schi gauge witch sits the chassis on 10mm blocks start at about 3mm front 4mm back to start?
bob33 is offline   Reply With Quote
Old 01-02-2006, 05:44 PM   #12592
I have a RW spur mounted in my car right now, 114. Looks like you can get 118 in the carpet spec.
You do have to countersink the gears , but i was told that Schumacher should have a fix for the guys running 64 pitch soon
The RW spurs work the best because they are flat and won't bow when you try to countersink them.
Hope this is what you were looking for
Later
jim
Old 01-02-2006, 06:04 PM   #12593
mini-dub's Avatar
Trader Rating: 16 (100%+)
I just finished building my carpet spec EC and put a 118t RW 64p spur on it. It sticks down into the cutout in the chassis but it looks like there might be enough room to put a 120. Don't hold me to that though as I didn't try it but a 118t fits easily. I just countersunk it with a couple stone dremel bits.
Bob - The setting on the droop gauge changes with tire diameter. Set the car to have about 2mm uptravel and then take off the wheels and make sure it's even right to left.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 01-02-2006, 06:27 PM   #12594
RKeasler's Avatar
I am going to keep my Mi2 even after getting the EC so as far as 64 pitch goes to get the RW spurs to fit what do I need other than the spur.
Rod
ClemsonTigers
USVTA # 224
ERC
Old 01-02-2006, 06:37 PM   #12595
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Rod
Rod- YGPM
Jon Kerr is offline   Reply With Quote
Old 01-02-2006, 08:54 PM   #12596
RKeasler's Avatar
Thanks Jon just put in the order a little while ago.
Rod
ClemsonTigers
USVTA # 224
ERC
Old 01-02-2006, 10:01 PM   #12597
A Ilievski's Avatar
Trader Rating: 39 (100%+)
hey what tape are you using to hold ya batteru pack in. i need some to hold my 3800 packs in
A Ilievski is offline   Reply With Quote
Old 01-03-2006, 02:54 AM   #12598
Jim, fair enough. I don't generally use RW gears, but i guess with them being so stiff makes them easy to countersink. I had a 48dp 90 in the car to check when i was building, that equals 120 64 Was very close to being right through the cutout, would be fine i would guess for you guys with an extra 0.5mm on the chassis, but not sure i'd risk it. 118 should be fine though.
Kid TT, that is Xenon tape (I think!), very strong, but very expensive.
Old 01-03-2006, 10:24 AM   #12599
STLNLST's Avatar
Trader Rating: 19 (100%+)
I need an EC
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-03-2006, 01:54 PM   #12600
King-G's Avatar
Send a message via ICQ to King-G
Mine lands today, has been sitting at UPS H.Q over the New year period!
God damn getting Ancy!
King-G is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
