Old 01-01-2006, 09:52 AM   #12571
Send a message via ICQ to MattW
I have one shim on each side at the moment, but think this is probably just a touch too much. It isn't tight, but there is virtually no float. Think i am going to get some thinner shims so i can effectively take less than 1 std shim out.
MattW is offline   Reply With Quote
Old 01-01-2006, 10:13 AM   #12572
ChadCapece's Avatar
Is there any disadvantage of "float" or "left-right slop" in a belt driven car's tranny?
ChadCapece is offline   Reply With Quote
Old 01-01-2006, 12:22 PM   #12573
Originally Posted by PW
Here is Teemu's setup from the GP Carpet Wars race
Which droop settings did Teemu use?
MortenFogh is offline   Reply With Quote
Old 01-01-2006, 12:36 PM   #12574
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by HarshGuy
I'm sure you heard ...but your compadre TQ's and won with his new car (even beat A-Yo's TQ). He was heard saying in the pits "can't wait for STLNLST and his EC".
It's all good. I'll be out there for the race on the 28th and go from there.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-01-2006, 06:45 PM   #12575
P-DUB's Avatar
I don't remember exactly, but he measures top of the axle to the pit board and it was in the 23.5mm range. I would probably start around 2 or 3mm above ride height
Larry Pryor
P-DUB is offline   Reply With Quote
Old 01-01-2006, 07:27 PM   #12576
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
I only ended up with one shim on the front diff and none on the rear and it seems fine on my EC. The drive train is super free on my car for just being built. I get to run the car tomorrow for the first time then at the Novak Race later in the week. The car looks really good so far I will be able to tell you guys more tomorrow night.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 01-01-2006, 07:51 PM   #12577
hey guys just brought a hpi droop and ride hight gauge and was wonderingdo i measure to the bottom of the suspension arm or is there a better way? i hope i bought the right droop gauge?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 01-01-2006, 10:05 PM   #12578
P-DUB's Avatar
Yes...Well outer most part of the bottom of the arm.
Larry Pryor
Old 01-01-2006, 10:54 PM   #12579
is there a better way to measure droop?? how do u factory guys measure droop?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 01-01-2006, 11:28 PM   #12580
STLNLST's Avatar
a factory guy just answered that
Old 01-01-2006, 11:32 PM   #12581
oops sorry p dub so u guys dont measure to the drvie shaft(heard it mentioned somewere) u just use a droop gauge (ie hpi gauge) how much droop should i run?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 01-01-2006, 11:53 PM   #12582
Jon Kerr's Avatar
Teemu measures his droop from the pit board to the top of the axle. I don't really like doing it that way. I measure the droop as above ride height. Set the cars ride height where you want it. Then lift the car by the center of the shock tower with the shaft of a hex wrench just until the tires come off the ground. Then use your ride height gauge and measure your ride height again. The difference is your droop. If you set the car to 5mm ride height and lift it up until the tires are just touching and measure again and you get 8mm, you have 3mm of droop. Then use the actual droop gauge to make sure both sides are even. I usually run between 3 and 5mm of droop above ride height.
Jon Kerr is offline   Reply With Quote
Old 01-02-2006, 01:45 AM   #12583
bender's Avatar
I personally find Teemu's way very accurate.
What you can do is make up a spreadsheet that lists combinations of tyre diam, desired ride height, and desired droop (above ride height)- and then gives you an axle height measurement.
The formula is: tyre diameter/2+2-rideheight-droop= axle height (to top of axle).
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 01-02-2006, 02:52 AM   #12584
Wirre's Avatar
Measuring below the wishbone gives you pretty much exactly (maybe +/- 0.1mm) 20mm smaller result, so 3mm under == 23mm to axle. Hope this makes it a little easier to compare between setup-sheets.
Kyosho Ultima RB-5 SP
Kyosho Ultima RT-5
Kyosho Lazer ZX-5 FS
Orion Vortex Motors and ESC
Wirre is offline   Reply With Quote
Old 01-02-2006, 03:48 AM   #12585
ok i set my droop with 5mm ride hight at 5mm on my hpi droop gauge is this right?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
