Old 02-05-2002, 01:34 PM   #1216
HEHHEHEHEHE You said COONTACT. I just tried and it was busy as well.
IKE
FoamDonuts is offline   Reply With Quote
Old 02-05-2002, 01:52 PM   #1217
Default REDIAL :)
I got through today and once yesterday, but when I tried to call back yesterday it was busy for HOURS!!!! Better hop to get through today or you won't reach them until after the Snowbirds and that means no parts until Monday Keep trying is my only advice !!!!
wilson10 is offline   Reply With Quote
Old 02-05-2002, 02:32 PM   #1218
Ian S's Avatar
Default moving from axis to mission
I currently race on carpet with an axis and will be ordering a mission tomorrow. How will my axis set-up differ to my mission set-up? my current axis set-up is:
Front:
1 deg neg camber
10 deg caster
0 deg toe in
yellow schu springs
80 weight oil
1 hole open in the piston
shocks in most upright position
Rear:
1 deg neg camber
zero anti squat
2 deg toe in
red schu springs
80 weight oil
1 hole open in piston
shocks in upright position
General:
jaco green foams all round with TQ purple additive on all the rear and half the front.
How would i adjust this set-up to work with my mission?
Ian s
Ian S is offline   Reply With Quote
Old 02-05-2002, 04:35 PM   #1219
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Ian.......you might want to try your setup first and see how things go. I know when I got my Mission my old Axis set up did not work at all. One thing that you will notice is how much steering the car has right of the board. Good luck with the new ride.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 02-05-2002, 04:35 PM   #1220
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
Any of you guys running the alloy purple diff housings f/r? And if so, how much sweeter do they make the car look? Because Scumacher is sending me some! lol
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 02-05-2002, 04:47 PM   #1221
Kevin K's Avatar
Corey they look sweet but they are heavy but they add a little something to the car in the looks dept.
Hey Guys I was told that Schumacher USA would be open all week during the Snow Birds. I guess Robin is going to be running the office and getting product out to people. So there might be only one man in the office so just give him time Im sure he will help ya out.
Old 02-05-2002, 07:56 PM   #1222
Hey Racer X and others thanx for the tips. What do you all think about running the stock swaybars on a high traction asphalt track, is it necessary. I,m going to try the 20 tooth pulley, the lower upper arm pos., and the in-line hubs that you all suggested. I,m really curious about those sway bars. I took 2nd at my local track and my MISSION was the star of the show 1st time out it produced repeatable results. Lots of room for improvement!!! Hasta!!!
War Schumacher!!!
Doggs_03 is offline   Reply With Quote
Old 02-06-2002, 02:16 AM   #1223
Adrian et al, I have decided to go with the Carbon Mission. Now, I need an Ozite foam tire, Mod Sedan setup for it. I run plaid jaco fronts and purple jaco rears trued down to 2.275 to start with. Please post setups here. Thanx, and I cant wait to get my new car. I just figured that I havent seen or heard of one single Mission for sale yet, and everyone of you guys cant shut up about how great they are, I just had to get one. Does anyone know if Steve Wang(Speedtech RC) will be getting the hop-ups in? I wanted to order the threaded shock bodies and the screw kit and stuff when I order the kit from him.
IKE
Old 02-06-2002, 04:25 AM   #1224
Sigearhead's Avatar
Trader Rating: 68 (100%+)
Default Carpet Setup
Foam Donuts:
Go with PW's carpet setup that he used in Cleveland, it was posted by Adrian a few pages back in this thread. It's an awesome setup. Get the competition swaybars and the threaded shocks, you really won't need anything else. BTW, use the 20t pulley. If you have any questions about the setup, let me know, I run on ozite with foams, purple rears, plaid fronts and my car is dialed!
Sigearhead is offline   Reply With Quote
Old 02-06-2002, 04:35 AM   #1225
Sigearhead's Avatar
Default Swaybars
Doggs_03
Yeah man, you're gonna need those swaybars if your track is high traction!
Old 02-06-2002, 07:12 AM   #1226
cornerspeed's Avatar
Hey markg, tell toastie Don V says hello. Also I cant get a hold of Atomic Ron. If you see him, have him call me.
Thanx
cornerspeed is offline   Reply With Quote
Old 02-06-2002, 12:59 PM   #1227
Sigear,
I thought everyone was using the 17t pulley?????
IKE
Old 02-06-2002, 04:27 PM   #1228
Default In line hubs
Anyonw using inline hubs? If so What turnbuckle did you change to? I tried it w/out knowing stock was too short and my rear arm split. Paul W said I needed to use longer turnbuckles, well the ones he sent me don't look to be much longer. the part number is L428 Ti Turnbuckle 4x28mm. I this the correct one? Thanks Oh and BTW I also thought everyone was using 17t pulley EXCEPT on LARGE tracks!!
Old 02-06-2002, 04:41 PM   #1229
Kevin K's Avatar
Wilson....I have split the upper a-arms on the axis but not on the Mission yet with them in the inline pos. Its b/c you hit something and they break right there on the back side of the upper a-arm. If you dont run in-line then the arm does not break but the tie rod might snap...Have had this happen too. They are working on changing the mold and putting more material around the threads of the upper a-arms so this does not happen as much. They did change the mold when they went to the new upper a-arms on the mission but its still not enough.
I like the 20t pulley better.....the drive train feels much better with it installed then the 17t. Also with the 17t pulley the car just seems to spool up and never run down the straights on like a 75ft. or more straight.
Old 02-06-2002, 04:44 PM   #1230
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
KevinK - Regarding the pulleys I agree with you 100%
Oasis2001 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
