Old 12-16-2005, 07:47 PM   #12256
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Help me out guys!!!!!! I have a trophy race tomorrow and have a broken shock shaft. No way to get one for the Mi2. Is there another shock shaft that will work? Please tell me that a Losi will work.
Rod
ClemsonTigers
RKeasler is offline   Reply With Quote
Old 12-16-2005, 07:49 PM   #12257
P-DUB's Avatar
Rod
The Losi rear XXXS shock shaft should work
Larry Pryor
P-DUB is offline   Reply With Quote
Old 12-16-2005, 07:50 PM   #12258
RKeasler's Avatar
You are the man, no matter what Adrian says.
Rod
ClemsonTigers
Old 12-17-2005, 05:45 AM   #12259
tantalus007's Avatar
Trader Rating: 17 (100%+)
Islandbwoy - thanks for the pics...
tantalus007 is offline   Reply With Quote
Old 12-17-2005, 06:35 AM   #12260
IslandBwoy's Avatar
np
IslandBwoy is offline   Reply With Quote
Old 12-17-2005, 07:03 AM   #12261
IslandBwoy's Avatar
Now this is different: just upened my brand new alloy rear hub adapters which is all good, except for the fact that the instructions are for the Alloy GEAR apapter.?!??!?! How do i assemble my hub adapter????
Old 12-17-2005, 08:13 AM   #12262
Jon Kerr's Avatar
Use the black insert that you want to get the desired toe. I always ran the 0º insert in the hub with the alloy pivot blocks. This will give you 2º toe in. If you want more, use the 1º and make sure the arrow is pointing forward. Use the set screw to hold the insert in place. Make sure you use some blue thread lock on the set screw. They like to back out in the middle of a run if you don't. Also, depending on setup, I usually ran 1mm under the ball stud and make sure to take the 2mm spacer out from behind the camber link mount on the shock tower and space the tower back from the bulkhead 2mm. This will put the camber link parallel to the CVD. If you don't set that up right, it can greatly effect the camber gain.
Jon Kerr is offline   Reply With Quote
Old 12-17-2005, 08:15 AM   #12263
P-DUB's Avatar
Very straight forward...Slide the 0deg insert into the hub with the hinge-pin hole to the bottom. Center the insert in the hub and snug the set-screw (grub screw).
I personally did mine a different way; I put the insert flush to one side on the hub and then cut the insert flush to the other side. Then use spacers to center the hub instead. I recommend the first instruction just for testing, if you like the hubs then look into the second method
Larry Pryor
Old 12-17-2005, 08:30 AM   #12264
IslandBwoy's Avatar
Thank you both.
Old 12-17-2005, 08:31 AM   #12265
When i ran my mi2 yesterday and after i got into a crash, i had to adjust my steering trim in my tx a few notches for the rest of my run just to make the car run straight. When i changed my batts into a newly charged pack and resting it after more or less thirty minutes, i had to return my steering to its normal settings. My kit is using the teemu lower deck and does this usually happen? or is there something wrong with my kit? I know that you would suggest that i should refrain from crashing but i cannot prevent these accidents in happening. My driving skills need a lot of improvement.
Old 12-17-2005, 08:38 AM   #12266
P-DUB's Avatar
Check that the servo saver thumb nut is tight. If you have a good metal gear servo, just tighten the thumb nut all the way tight.
Larry Pryor
Old 12-17-2005, 11:10 AM   #12267
Which one is the servo saver thumb nut, is that the black plastic nut? I'm using a futaba 9402 servo, could i tighten the thumb nut all the way tight with this servo? Thanks.
Old 12-17-2005, 12:25 PM   #12268
Jon Kerr's Avatar
The one on the servo saver that's built into the left bell crank. I Run mine as tight as it can be. If yours is too loose, it could shift in the impact and not return all the way causing your trim to be off.
Old 12-18-2005, 06:42 AM   #12269
STLNLST's Avatar
Horrible day for me but Schuie driver's never quit. The traction is at the highest it's been all year and now the jaco wraps are the hot ticket. During club races they are turning the same lap times as the regular jaco's but now oohhhhhhh my gosh. It will be tough to practice for the nats when the bite isn't as high because we thought that we stubbled on to a great set up during practice but between the last round of practice and the start of the races the traction went up BIG TIME. The cars started handling differently. We have a few things to try during practice today and Barry has been helpful so we should be just fine. Wish us luck and I'll update my fellow schuie driver's later on today.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-18-2005, 07:04 AM   #12270
HarshGuy's Avatar
Sound like outdoor asphalt racing (working with varying traction as the day goes on!!)
If you want to hear the action and see live scoring (no video available at this time) you can go the www.2006RoarNats.com website ...click on the "Live Scoring" menu option up on top ..on the Carpet Nat's side of the menu.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
