Old 12-13-2005, 03:01 PM   #12226
TeamButter's Avatar
Send a message via AIM to TeamButter
Errrr..Well this sand "Butter" did run 19 turn and finsihed 2nd to a Schumacher driver who was less than courteous on the track on various occasions.......Let's hope Schuie doesn't have any drivers going back to stock to SANDBAG.....
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 12-13-2005, 04:11 PM   #12227
STLNLST's Avatar
Trader Rating: 21 (100%+)
TOASTY!!!!!
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-13-2005, 06:14 PM   #12228
mini-dub's Avatar
Trader Rating: 16 (100%+)
I hear that Butter guy cant drive a mod motor
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 12-13-2005, 06:30 PM   #12229
tantalus007's Avatar
Trader Rating: 17 (100%+)
Thanks for the tips concerning the gt7 mounting.
IslandBwoy- it would really help if you could post the pics. Thanks.
Is the teemu raiser plates thicker the the bos stock raiser plates? Thanks.
tantalus007 is offline   Reply With Quote
Old 12-13-2005, 08:33 PM   #12230
nf_ekt's Avatar
Trader Rating: 113 (100%+)
need some help with setting the car up with carpet towers:
just got some carpet towers for my Mi2 and I cant seem to make it work. I have the front shocks set at 63mm, the rears 64mm (as per the setup sheet i have from schumacher) using the stock dampers. with the shock collars all the way up (to the point they are making contact with the plastic mount and wont go any higher) i cant get the ride height where it should be and the suspension movement is next to nothing. i can only guess i'm doing something wrong, i dont know. do i need shorter shock rods?, different shocks alltogether? probably a rookie question i know but any help/suggestions would be apreciated... guess i'll use the stock towers till i figure it out
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 12-13-2005, 08:39 PM   #12231
A Ilievski's Avatar
Trader Rating: 39 (100%+)
will the 3700 or 3800 cells fit in the normal BMI chassis
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 12-14-2005, 06:20 AM   #12232
Jon Kerr's Avatar
Did you cut 2mm off the ball cup on the shock shaft? If not, that may be your problem. Are the shock bottoming out or is the top of the ball cup hitting the shock body to limit the susmension travel?
Jon Kerr is offline   Reply With Quote
Old 12-14-2005, 06:55 AM   #12233
PW
PW's Avatar
Send a message via AIM to PW
Yes, if you are using the stock shocks then cut 2mm off the shockshaft threads and 2mm off the ball cups.
The new schumacher shocks will be available in 2 weeks time
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 12-14-2005, 07:01 AM   #12234
nf_ekt's Avatar
John Kerr- I haven't tried cutting down the ballcups yet, but i can see why that would make a difference in allowing the spring to sit lowere and make it to where i can actually twist the collars back down (they're as high as they'll go at the moment). The fronts weren't so bad but the rear shocks would'nt hardly move at all-- I did however replace both of the front shock rods with Losi rods which I know to be 2mm shorter, so maybe this is making a difference (Plan on replacing the rods on the rear dampers as soon as I find another pair from Losi, the nitride feels smoother). I'll get to cutting the cups down and see if it helps...
Up the Irons \m/
Old 12-14-2005, 07:03 AM   #12235
nf_ekt's Avatar
I think PW just answered my question on the length of the shock rod. Gotta find another pair of Losi's!
Up the Irons \m/
Old 12-14-2005, 12:30 PM   #12236
The Evicerator
Adrian: YGPMs
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 12-14-2005, 02:21 PM   #12237
A Ilievski's Avatar
im about to buy 3 new gp 3700 packs and i was wondering will the cells fit in the MI2, i need to know asap as the guy is waiting for my decision
Alex Ilievski
Old 12-14-2005, 02:27 PM   #12238
STLNLST's Avatar
there's a new tray that will fit the newer 3700's. I can't remember the part number but Schumacher does offer it.
Old 12-14-2005, 02:32 PM   #12239
Jon Kerr's Avatar
They won't fit in the stock Mi2 or the older BMI chassis but Schumacher does make a new battery tray for them and any new BMI chassis that's sold is cut for the larger cells.
Old 12-14-2005, 02:37 PM   #12240
Jon Kerr's Avatar
Hey look, Clint's not yelling! He must be in a good mood.
Just messin' brotha.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
