Old 02-03-2002, 06:25 PM   #1201
ottoman's Avatar
R/C Tech Charter Subscriber
Kevin K.... I ran the upper arms in the lower hole today at Trackside and ended up being the only car to run 24 laps (including the mods) so I have to say I like it so far. I noticed that in your setup you ran the front hubs inline. When I tried to go inline on the hub, with the lower upper arm mount hole, the hub bound up on the arm ball cup. It looked like I would have to grind away the inner ballstud hole area of the hub to make everything clear. How did you make yours work?
ottoman is offline   Reply With Quote
Old 02-03-2002, 08:33 PM   #1202
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
ottoman, to run inline, with the lower mount, you have to grind that other mount away...
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 02-03-2002, 10:46 PM   #1203
STLNLST's Avatar
Trader Rating: 19 (100%+)
Racer X- We actually got out of there pretty early. We went to Wendy's and ate there and then got stuck in traffic by calexpo and still made it home while there was still some light out. Maybe we'll see you next weekend????
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-03-2002, 11:06 PM   #1204
I am considering buying the Mission and I want to know what you guys think about it. How is the durability and how is the handling? Thanx in advance.
IKE
FoamDonuts is offline   Reply With Quote
Old 02-04-2002, 01:31 AM   #1205
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Ottoman.....Good job on the lap times......Like Spooky said I ground a little off the ball cup on the upper A-arm and it works fine. How close did you run your car to the setup I posted and what tires were you running??? Hopefully I will make it up to Trackside this sunday, if so I hope to see you there.
FoamDonut......I dont think that you will find a stronger TC on the market and it handles right up there with the best of the cars on the market if not better IMHO. You could not go wrong in getting one you will enjoy it.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 02-04-2002, 06:42 AM   #1206
I've been trying to find some good detailed photos of the Mission but I haven't found any yet.
Do you guys know where I can find them or have you some you can post.
Like I said, detailed photo's would be nice. No one where we race has one yet so I'm curious to see one up close.
Yorkie
Yorkie is offline   Reply With Quote
Old 02-04-2002, 09:56 AM   #1207
Default Snowbirds
Looking forward to meeting some of you guys at the Snowbirds...its gonna be fun. More than just a couple of hours away, but what the heck...
Four of us are coming from Austin...Toastie (last year stock winner and 2nd place 19 t I think), David, Atomic Ron, and me...look us up
Adrain/Paul..hope you're bringing caps...I want a Schumacher cap to wear in the winners photos...
Looking forward to it guys...
markg is offline   Reply With Quote
Old 02-04-2002, 10:10 AM   #1208
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Good luck to everyone at the snowbirds, bring it home
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 02-04-2002, 06:05 PM   #1209
ottoman's Avatar
Kevin I ran Yok 139g with Echo reds
Front
60wt with 2 hole 67mm long
2nd hole from inside on tower, inside on lower arm
asc gold springs
1.5 camber
min caster
inboard toe zero out board toe
lower hole on upper mount
non inline hub
5mm
Rear
60wt with 2 hole piston 67mm long
asc blue
third hole from inside on tower and inside hole on arm
inboard toe with 2 degree outboard
not inline on hub
1.5 camber
5mm
I ran sway bars. I didnt measure the drop, just eyed it up
ran with the oneway
P2K2 86/27
Old 02-04-2002, 06:13 PM   #1210
ottoman's Avatar
Kevin....I know you prefer 139g tires. Have you tried the 139gs or the 139m yet? I picked up a set of 139gs or is the 139sg? anyway I might try them out Sunday.
Old 02-04-2002, 07:07 PM   #1211
Kevin K's Avatar
Ottoman....I like the 139g's they do have a 139s I tried at the Novak and did not really like them as much as the 139g's. Yokomo has some new inserts out now that are thinner and they might work better then the Echo's I need to pick some up and try them out. I should be up there this sunday I will see ya up there if you guys make it down.
Old 02-04-2002, 11:40 PM   #1212
Thumbs up
I'd like to wish everyonre racing at "The Bird" good luck. Hope to meet some, if not all, of you at the race. Lets put Schumacher on hte podium!!!
Stika525 is offline   Reply With Quote
Old 02-05-2002, 11:26 AM   #1213
Location: in Bolton, near Manchester, where it rains more than in the Amazon...
Can anyone point me towards a grippy, aggressive carpet setup running mod on a short track? My car is an axis 2. I like it a LOT, only had it a while
Rick of England is offline   Reply With Quote
Old 02-05-2002, 12:16 PM   #1214
Sigearhead's Avatar
Trader Rating: 68 (100%+)
Default Mission pics
http://home.fuse.net/favian/Mission.jpg
http://home.fuse.net/favian/Mission%20top%20view.jpg
http://home.fuse.net/favian/Mission%20bottom.jpg
These are pictures of my Mission. I have had just about every touring car there is to have (Yokomo, TC3, XXX-s, Pro2, Pro3, SST99) and the Mission is by far the best handling and performing car I have ever had. My only knock is parts availability, at least locally for me.
Sigearhead is offline   Reply With Quote
Old 02-05-2002, 01:11 PM   #1215
Trips's Avatar
Trader Rating: 16 (100%+)
Has anyone been able to coontact Shumacher USA by phone in the last couple of days? I've been trying to call in a parts order and the phone has been busy for two days solid.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
