Old 11-26-2005, 09:38 PM   #11956
Default belt tension
hey how do u guys set ur belt tension and when the say belt skip what is it??
thanks for any help
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 11-27-2005, 02:10 AM   #11957
Send a message via ICQ to MattW
Bob, yes i know someone that fitted one and it was fine. You just need to check the belt spacing. Can't remember if the spacing needed changing from std on the spool, just check it.
MattW is offline   Reply With Quote
Old 11-27-2005, 09:29 AM   #11958
TVMRocket69's Avatar
Send a message via AIM to TVMRocket69 Send a message via Yahoo to TVMRocket69
Matt what spacing. Or are U talking about the Belt tension.
Thanks for your help.
Bob Walker Jr.-Sponsor's-
AnswerUSA-RC Team Driver, G's R/C Raceway Team Driver, RBMods Team Driver, Kosmic R/C Fuel Team Driver, MurfDogg Motorworks Team Driver, Serpent S811B, Serpent S811t, MurfDogg Powered V-Desizn Carpet Ripper 5
TVMRocket69 is offline   Reply With Quote
Old 11-27-2005, 03:20 PM   #11959
The diff pullies are wider than the belts, so there are spacers on the pullies to geep the belt running true. As the spool is supplied, the spacers will be in th ecorrect position for the Mi2 transmission, so when putting it in a mission, you would just have to check that the belt still ran correctly, if not adjust the spacing.
Old 11-27-2005, 04:12 PM   #11960
Oh ok TY
Bob
Old 11-27-2005, 06:56 PM   #11961
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
thanks for any help
Usually for belt tension, I just run the top tensioner for the front belt and the bottom tensioner about half way to 3/4 of the way up and that's it. it's rare to ever get a belt skip at that setting and the drive train is very free.
Jon Kerr is offline   Reply With Quote
Old 11-28-2005, 03:47 PM   #11962
Send a message via ICQ to piorc
hey guys...i have 2 questions.
i just bought my trf shock to my Mi2, and need to know which ball cups do u use to fit the shock on the mi2? are the original fits?
and what springs do u recommend to buy?
Thanks a lot.
piorc is offline   Reply With Quote
Old 11-28-2005, 03:52 PM   #11963
Jon Kerr's Avatar
You can use the stock ball cups on the bottom mounts. Just cut about 2mm off them so they'll be short enough. For the top mounts, these Upper shock mounts are awesome.
Go to www.pdubracing.com or click the link in my sig and click on products. Lower right corner you'll see them.
Oh and for springs, you can get the Schumacher Pro Spring Kit. Part# U2812. It's got one pair of each weight spring. You may want to pick up an extra set of white springs, U2823. The outdoor setup we're running calls for them front and rear.
Old 11-28-2005, 03:58 PM   #11964
but these Upper shock mounts are from which brand or manufacturer?
tks
Old 11-28-2005, 05:09 PM   #11965
Super Moderator
Hey Bob you don't want to run a spool in that car for carpet anyway. Ask PW to send you a copy of his Snowbirds setup from a few years ago. Thats what you need on the car for Horsham and other carpet. If you are going to Run asphalt then get his other setup...I think it was the 19turn one that was dialed.
Tekno | JConcepts | ProTek RC | BOOMrc
Bob Barry is offline   Reply With Quote
Old 11-28-2005, 05:26 PM   #11966
Jon Kerr's Avatar
tks
BMI makes them and PDub sells them. They're specifically for the Mi2 with TRF shocks.
Old 11-29-2005, 12:21 AM   #11967
It has a 1-way in it now, but the track I'm racing at now is a indoor Asphalt.
The spools for it I'll still have the 1 way.
Old 11-29-2005, 06:19 AM   #11968
Jon Kerr's Avatar
I have a setup with a oneway that we've been running that's a pretty good starting point for SoCal (indoor asphalt) when grip is up if you'd like to try that. Drop me a PM and I'll Email it to you.
Old 11-29-2005, 06:29 AM   #11969
Super Moderator
Bob You are talking about the original Mission not the MI2 correct? Listen to Jon's advise. He will get you sorted out. Thanks for helping him out Jon. I would tell him to run the setup with the bulkheads shimmed up but I think it might be a little hairy for him to drive. I wish I still had all my info on that car cause I was fast with it outside. Carpet on the other hand....
Old 11-29-2005, 06:36 AM   #11970
Jon Kerr's Avatar
I'm sorry. I assumed you were running the Mi2. If it's for the original Mission, that was before I was with Schumacher. But I'll see if I can find you a setup for that car. I'm pretty sure Donny may still have something from when he was running it at SoCal.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
