Old 11-17-2005, 10:25 PM   #11851
cornerspeed's Avatar
Cool, upper front adjustable belt tensioner.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 11-17-2005, 10:36 PM   #11852
mini-dub's Avatar
Trader Rating: 16 (100%+)
There won't be any conversion because pretty much everything has changed, so to bring a current Mi2 up to EC spec would change pretty much everything . The chassis, topdeck, shock towers, shocks, arm mounts, arms, front and rear hubs, front knuckles, bulkheads, diffs, layshaft, layshaft pulleys, CVD's, hex hubs... you get the idea . If you want to put just a few things from the new car on the old car I'm sure you could. Such as the towers, but the geometry still wouldnt be the same as the EC because the arm mounts have been moved.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 11-18-2005, 02:19 PM   #11853
IslandBwoy's Avatar
Hey Guys,
WHat does this mean (taken from Weylin's setup): Center track-rod 40.8mm. Tower spaced 2.5mm forward. Camber in middle upper hole. BMI shock towers
IslandBwoy is offline   Reply With Quote
Old 11-18-2005, 02:33 PM   #11854
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
"Center track-rod 40.8mm." : The rod that connects the two steering bell cranks is 40.8mm long.
"Tower spaced 2.5mm forward." : The front shock tower has 2.5mm spacers between it and the bulkhead (This will effect the camber gain) to move it forward. This lines up the camber link with the CVD.
"Camber in middle upper hole. BMI shock towers" : The BMI shock towers that he has, I believe there's 8 positions you can use. The position he's using is the middle column, upper hole.
Jon Kerr is offline   Reply With Quote
Old 11-18-2005, 06:22 PM   #11855
IslandBwoy's Avatar
Thanks again jon.
Old 11-18-2005, 06:26 PM   #11856
Jon Kerr's Avatar
Anytime
I'm really looking forward to the EC coming. But like someone else mentioned, what's up with the gold preload collars. P-Dub Racing needs to come up with some purple or black ones
Old 11-18-2005, 08:58 PM   #11857
OK...stupid question number agillion...if I change over to the lower shock towers, I have to grind off part of the lower ball cup on the shock, right?? I tried installing them and bottomed the shock completely. Guess that means I have to shorten the shocks to about 62 mm (currently have them at 66mm) and grind off some of the ball cup? How much?
Thanks...Mark
Forgot to say...on the MI2...
markg is offline   Reply With Quote
Old 11-18-2005, 09:16 PM   #11858
Jon Kerr's Avatar
Shorten the shock lengths up and cut about 2mm off the ball cup on the shock. We usually run about a 63-64mm shock length.
Old 11-18-2005, 09:27 PM   #11859
Cool...thanks Jon...
Old 11-18-2005, 09:28 PM   #11860
Was just looking at pics of the new car..looks nice...its very....purple...
Old 11-18-2005, 09:36 PM   #11861
A Ilievski's Avatar
Trader Rating: 39 (100%+)
stupid question here, but ive been wondering how the hell do i messure toe in/out. theres no gauge so how do i do it
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 11-18-2005, 10:03 PM   #11862
Jon Kerr's Avatar
You can get a setup station like the Hudy or the Integy one. You can also measure the distance between the front of the tires to the rear of the tires. This is kind of a tough way to do it but it works if done right. I'd get a setup station. It's much easier and much more accurate.
http://www.speedtechrc.com/store/ebp...nid=384&id=653
This is the one I have and it works just fine. There's really no need to go and spend 5 times as much on the new Hudy one. It's very nice but not really necessary.
Old 11-18-2005, 10:05 PM   #11863
Jon Kerr's Avatar
Anytime. There really aren't many stupid questions. (I won't say there aren't ANY because there are some out there ) But if you need to know something, ask. That's how we all learn.
Old 11-18-2005, 11:12 PM   #11864
mini-dub's Avatar
Boy your smart ! How'd you know all that stuff without asking me ? The BMI tower's I was using with that upper middle position raised the link about 4mm above the stock carpet tower upper middle hole. I've also just drilled stock carpet towers to achieve the same location.
Cant we just use spray paint for the gold shock collars ? I hate spending money on shock collars !!!
Old 11-18-2005, 11:49 PM   #11865
Jon Kerr's Avatar
Because I'm doing the exact same thing
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
