Old 11-12-2005, 11:47 PM   #11761
heavy's Avatar
Trader Rating: 20 (100%+)
Originally Posted by kid TT-01
hmmm when i bought my Mi2 in april this year i bulit it and the rear diff was way to tight from production. i loosened it a bit but now the diff wont tighten up it always becomes loose. is the the diff disc springs that need changing, but i bought a new rear diff i just wanted to know how i can fix it.
another thing the screw in the rear diff filled up with some white putty kind of thing what is up with that?
sorry for the long post.
Are you aware that there is a diff locking screw in teh opposite outdrive to the diff screw. The locking grub screw has to be loosened till you get the right adjustment then tightened again.
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 11-13-2005, 12:09 PM   #11762
Send a message via ICQ to MattW
Default Vegas Rubber class
For anyone that raced rubber at the IIC in Vegas (or any other high bite rubber track), what shell did you run?? and what was the most popular at the sharp end of the field??
MattW is offline   Reply With Quote
Old 11-13-2005, 02:55 PM   #11763
b-man777's Avatar
hi all:is the mi2 ec legal for roar use?also is the mi2ec for asphalt racing and the mi2ec foam tire spec for carpet racing?finally who's on the schumacher racing team for 2006?thanks
b-man777 is offline   Reply With Quote
Old 11-13-2005, 06:53 PM   #11764
A Ilievski's Avatar
Trader Rating: 39 (100%+)
i know there is a grub screw in the opposite out drive. thanx for ya help tho
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 11-13-2005, 07:05 PM   #11765
P-DUB's Avatar
The Protoform Mazda and Stratus 3.0 dominated the field in Rubber...I finished 5th with a Mazda
Yes, all 4wd sedans are ROAR legal. Mi2EC = Rubber low/medium bite and Mi2EC Foam spec = Foam medium/high bite and Rubber high bite
Larry Pryor
P-DUB is offline   Reply With Quote
Old 11-13-2005, 08:09 PM   #11766
When will the carpet spec be available to the public?? thanks Matt Would like to take one to the Novak Race if possible
beanster is offline   Reply With Quote
Old 11-14-2005, 03:01 AM   #11767
Originally Posted by Jon Kerr
I'd rebuild the diff first. Make sure everything is clean and that there's no flat spots on the diff balls. If there are they'll need to be replaced. Lightly sand the diff rings with VERY fine grit sand paper and clean them off. Rebuild it exactly as the directions say. Tighten it until it feels like it's just about bottomed out, then back it off a 1/4 turn. Then break it in like a posted above. Final settings on it should be fairly loose. You really don't want your diff too tight. If you can hold one wheel and the spur and try to turn the opposite wheel, you should just barely be able to make it slip. But only just a little. Just make sure it's not slipping when on the track. Too tight a diff can make for a very erratic handling car and too loose can cost you punch coming out of the corners and can damage parts.
hey dude i took ur advice and checked the internals their all good (i think) so i tightened them and backed of 1/4 turn and the seemed very stiff and would bearly turn when the spur was held so i backed it of 1/4 turn more (1/2 a turn total) now it is a bit softer is still stiff but isnt like belt breaking will that be ok?? is 1/2 turn to much?? im new so i thought soft diffs might be more forgiving in the corners is this right any help would be great.
aus jd 2703 is offline   Reply With Quote
Old 11-14-2005, 05:39 AM   #11768
aus jd 2703 i alwase run my diffs 1/4 turn undone (some times a little tighter ) i would say 1/2 turn is a bit to lose tho mate. but u can try it and just listen on the track for it sliping
bob33 is offline   Reply With Quote
Old 11-14-2005, 06:16 AM   #11769
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
1/2 turn does seem like a lot but if it's tight, it's tight. I like to run mine as loose as possible without it slipping. Without having it in front of me and turning it myself, I can't really judge it.
Jon Kerr is offline   Reply With Quote
Old 11-14-2005, 10:12 AM   #11770
IslandBwoy's Avatar
Yeah. regardless if your going 1/4 or 1/2 turn the important thing is; is that you should have a fairly difficult time getting the diff to slip while holding one wheel and the spur. That is your litmus test because 1/4 turn or 1/2 a turn is different based on where your starting from.
IslandBwoy is offline   Reply With Quote
Old 11-14-2005, 12:37 PM   #11771
STLNLST's Avatar
Trader Rating: 21 (100%+)
It's Monday......I get to run my car on Saturday. Got a great set up to try and killer motors on the way. This weekend is my weekend.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-14-2005, 12:39 PM   #11772
HarshGuy's Avatar
....to turnmarshal the A ...you know it's just love Clint
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 11-14-2005, 12:51 PM   #11773
STLNLST's Avatar
I just hope you can stay on the same lap....LOL The MI2's are coming to claim what was once ours. Go back to the RDX thread. TQ and a win in 19 turn this weekend.......watch!!!!
Old 11-14-2005, 01:10 PM   #11774
Why.....is Mo driving 19T this weekend? LOL
See ya in the B!
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 11-14-2005, 01:54 PM   #11775
Jon Kerr's Avatar
Man, Clint's not gettin any lovin from his home town boys.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
