Old 11-07-2005, 05:29 PM   #11656
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Just put a Reedy Ti 8T double in the car that I have had for a while, geared at around a 9.0 MAN O MAN scary fast , may have to go 10.0 or better but I haven't seen the new layout at this track yet. First time in Mod in awhile.
Rod
ClemsonTigers
USVTA # 224
Team C Racing USA / TC 10 2015
ERC
RKeasler is offline   Reply With Quote
Old 11-07-2005, 06:01 PM   #11657
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
yeah, but you gotta watch out for the belt construction. the standard gates stuff has an .045 backing, or so, which makes the belt very stiff. the industrial stuff is not designed for efficiency, so much as torque transmission. i assume the cen job would be in the ballpark.
to each his own. personally, i have a top secret belt in the front. and it is 4 tenths faster per lap.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 11-07-2005, 06:09 PM   #11658
AdrianM's Avatar
It must have more monkeys in it
Adrian Martinez
Old 11-07-2005, 06:14 PM   #11659
AdrianM's Avatar
Guys in about 4-6 weeks the EC will be out and we will have all the belts you could wish for.
Tomorrow we will have a press release the will make a lot of you guys really happy
Adrian Martinez
Old 11-07-2005, 06:39 PM   #11660
rcshark's Avatar
Send a message via Yahoo to rcshark
Unhappy
I will be happy in about 4 to 6 weeks
rcshark is offline   Reply With Quote
Old 11-07-2005, 09:31 PM   #11661
RKeasler's Avatar
You mean a nice low price for Schuie faithful???!!!
Rod
ClemsonTigers
USVTA # 224
ERC
Old 11-07-2005, 09:39 PM   #11662
rbboy's Avatar
Send a message via MSN to rbboy Send a message via Yahoo to rbboy
is there a center one-way for the Mi2 EC?
www.xtremerchobbiesph.net
rbboy is offline   Reply With Quote
Old 11-07-2005, 09:45 PM   #11663
AdrianM's Avatar
Rod
Actually you got that already. At $419.99 with everything you need to race and more in one box by the time you hit the track this will be the least expensive Schu sedan ever. Most guys in the US added ~$200 of hop ups to their Mi2. The EC is an awesome deal.
Adrian Martinez
Old 11-07-2005, 09:49 PM   #11664
AdrianM's Avatar
Right now there are no plans for a center one-way. We see no performance benefit to having one. All the guys with cars that come with center one-ways agree with us. It seems like the first hop up guys with center one way cars get is a locked lay shaft pulley.
Adrian Martinez
Old 11-08-2005, 07:52 AM   #11665
AdrianM's Avatar
Default Mi2EC USA Foam Spec Announced!!!
To better suit the needs of US carpet racers Schumacher will be releasing the World's First production sedan optimized for racing on carpet with foam tires! This kit is not just a rubber car with a thicker chassis and top deck. The Mi2EC USA Foam Spec has different suspension geometry and weight distribution optimized specifically for foam tire racing. The Mi2EC USA Foam Spec kit will incorporate a number of changes developed by Schumacher US team drivers. These changes have been race proven with prototypes already generating great results at major races like the International Indoor Championships in Las Vegas and significant Regional and local races. The Mi2EC USA Foam Spec will be the ultimate sedan for carpet racing!
-New 2.5mm Carbon lower chassis with revised hinge pin locations and battery location.
-New 2.5mm Carbon super stiff top deck
-New Carbon front and rear shock towers with revised shock and camber link locations
-New Low center of gravity Mi2EC drive train (everything is 2mm lower than on the standard Mi2EC)
-Lower roll centers than the Mi2EC
-New front diff with aerospace T/C thrust bearing
-Stiffer Front Sway Bar, no rear sway bar.
-Stiffer front and rear Pro Springs
Adrian Martinez
Old 11-08-2005, 08:58 AM   #11666
seaball's Avatar
long awaited.
Old 11-08-2005, 09:07 AM   #11667
KE4PJO's Avatar
What about availability, and "street price"?
"If at first you don't succeed, sky diving is not for you" Unknown
"A bad day racing is still better than a good day at work" Me
KE4PJO is offline   Reply With Quote
Old 11-08-2005, 09:20 AM   #11668
AdrianM's Avatar
The part number is K059 and it will sell for around $439.99. It will be available at the same time as the standard EC car.
The front diff and thicker carbon account for the increase in price. The Foam Spec car will have the same spec at the Mi2EC is it will include
Ti Turnbuckles
Ti Hinge Pins
Purple Alloy suspension mounts
Black Oxide Steel Hex screws throughout
Machined diff and lay shaft pulleys
New shocks
Pretty much everything from the EC with the changes listed below.
Adrian Martinez
Old 11-08-2005, 09:33 AM   #11669
rayhuang's Avatar
This is pretty amazing stuff. A European company developing a ground up foam tire car. If it goes as well as Seaballs Mi2-youve got a winner on your hands. I am glad to see your addressing the shocks and diffs on the Schuie across the board too.
Old 11-08-2005, 09:38 AM   #11670
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Forget Seaball's car ...if its as good as PW's car at the IIC then Schumacher has a real winner on its hands.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
