Old 11-01-2005, 01:25 PM   #11626
Super Moderator
Trader Rating: 17 (100%+)
how would you say that running cyan/magenta's differes from plaid/purples?
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 11-01-2005, 01:42 PM   #11627
mini-dub's Avatar
Trader Rating: 16 (100%+)
The plaids/purples make more sidebite and less forward bite because of the harder compound. The cyan/magentas will free your car up because of the softer sidewall which makes them much better for high bite. The cyan/magentas give your car more steering and better forward traction.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 11-01-2005, 02:48 PM   #11628
Mal
Registered User
Yep, Weylin's shoemaker is pretty impressive
Mal is offline   Reply With Quote
Old 11-01-2005, 02:49 PM   #11629
Super Moderator
cool thanks
Old 11-01-2005, 02:50 PM   #11630
mini-dub's Avatar
So Mike, you gonna buy the new one when it's out ?
Old 11-01-2005, 04:25 PM   #11631
Mal
Registered User
Maybe, I want to see one first ....
Old 11-02-2005, 06:59 AM   #11632
PW
PW's Avatar
Send a message via AIM to PW
New asphalt setup for med/high bite track. This setup should be really good in stock & 19turn Setup for tons of steering
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 11-03-2005, 10:43 PM   #11633
nf_ekt's Avatar
Trader Rating: 113 (100%+)
PW--- I was hoping you could email me that PDF. for Weylin set-up, having trouble opening it from the link you provided (a buddy of mine used my computer and its been sorta' messed up ever since). I am pretty sure I can open it from an email, though. Also If you have any asphalt set-ups for the stock kit (stock towers, ect.) That would be cool. email to: nf_ekt@yahoo.com.
Thanks for your help...
nf_ekt is offline   Reply With Quote
Old 11-04-2005, 12:46 AM   #11634
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Smile
Hi all,
What bearings do you guys use the standard ones or are there some after market hop up ones.
Taffyjnr5
Taffyjnr5 is offline   Reply With Quote
Old 11-04-2005, 05:26 AM   #11635
IslandBwoy's Avatar
Default BMI Tweak Issue
Have any of you guys experienced tweaking issues with your BMI chasis? I just build mines and cant seem to get the weight evenly distributed across the chasis? My left rear tire is lighter than my right rear and the left front tire is lighter than the right front?!?!?!?. Didnt seem to have this problem with the Teemu chasis. I've check all my shock/spring lengths; droop; balance; and even rebuilt the car from scratch but the closest i can get the lateral weight to be is in the range of 30-50 grams off. Any suggestions would greatly be appreciated. :-(
IslandBwoy is offline   Reply With Quote
Old 11-04-2005, 06:30 AM   #11636
Jon Kerr's Avatar
nf_ekt- YGM
Taffyjnr5- I've always just used kit bearings. Schumacher does have some new bearings for the car that are supposed to be much better. I just got them and will be running them this weekend for the first time.
IslandBwoy- I think you have a weight distribution issue, not a tweak issue. Take the tires off and if you have some droop blocks like the Schumacher ones or the Hudy ones, set the chassis on that making sure that it's not sitting on any screw heads. If the chassis doesn't set perfectly flat on the blocks, the chassis is tweaked. If it does, you're weight distribution is off. I've had to put up to 35g on the left side of the car before to get the weight just right. The easiest way to check the weight distribution is to set the car on a flat LEVEL surface, ready to run, and lift the car from the center of the shock towers on both ends with a couple of hex drivers.If one side comes up first, that's your light side and you'll need to add weight. Try and add the weight as low on the chassis as you can.
Jon Kerr is offline   Reply With Quote
Old 11-04-2005, 07:48 AM   #11637
IslandBwoy's Avatar
That is very possible Jon, I started to put weights on the car but when i got up to 30+ grams i started to think that something was wrong. As i was discussing with Paul it gets kinda dificult to balance the car with the BMI chasis becuase the center point of the towers are so low, its hard to get something through there from front to back. I'll try balancing the car again today before the club races and see what happens.
R.
Old 11-04-2005, 04:26 PM   #11638
mo
mo's Avatar
Instead of adding weight to the left side, you can get a motor spacer to move the motor farther out and that will help balance it w/o extra weight.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 11-04-2005, 05:42 PM   #11639
Jon Kerr's Avatar
Or add a fan. Functional weight is a god thing.
Old 11-05-2005, 11:07 AM   #11640
IslandBwoy's Avatar
Well other than keeping the motor cooler. what does the fan provide? Can i as a result of adding the fan run higher ratios? 'cause personally i've never had a problem overheating a motor in 19T. But then again maybe thats why i'm slow :-(
BTW: I've noticed that some of the setup sheets call for blue front and silver rear springs. And then others would call for the opposite. ???
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
