Old 10-30-2005, 07:43 PM   #11611
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by hyena boy
what sway bars and springs come on the new car? what are some of the tuning options, new caster blocks, hub carriers, and gearing? what is the biggest spur gear in 64p that will fit?
the biggest 64 spur that we have run on the car so far has been 128. That shouldn't change on the new car. The gearing should also remain the same. I haven't heard of any change to the cars drive ratio. you can click on the website for any information.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-30-2005, 08:40 PM   #11612
P-DUB's Avatar
Originally Posted by RC Old Man
What parts do you need to put the corally steering bellcranks on the MI2?
You need the corally bell-cranks, bearings, and stand-offs....I'm not running the corally steering anymore
It will come with silver bars and white springs (14lb). Not exactly sure on max spur size, but will probably be 120/64p - 90/48p or smaller. The car will come standard with an RW 48p gear (probably 89t).
Larry Pryor
P-DUB is offline   Reply With Quote
Old 10-31-2005, 06:47 PM   #11613
CAR
CAR's Avatar
Need a good starting point for gearing 19T Reedy foams small track . Thanks
CAR is offline   Reply With Quote
Old 10-31-2005, 06:53 PM   #11614
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Street price for Mi2ec
The car is coming out @ X-MASS. Does any body know the street price of the new Mi2ec?
Thanks,
E
RED-LINE M03 is offline   Reply With Quote
Old 10-31-2005, 07:06 PM   #11615
P-DUB's Avatar
E
$419.99
Depends on your tire size, but with rubber tire we run 5.7 - 5.8 overall.
Gotta give mad props to C-Ball for laying down some killer runs at the Halloween Race....Don't forget to send me that setup and cut that body before cleveland!!!!!!!
Larry Pryor
Old 10-31-2005, 07:17 PM   #11616
Default Thanks
Thanks P-DIDDY
I mean P-DUB
Later,
E
Old 10-31-2005, 07:36 PM   #11617
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Thanks P-DIDDY
I mean P-DUB
Later,
E
ygpm
Old 10-31-2005, 11:20 PM   #11618
STLNLST's Avatar
we normally run our rollout at 34 on foams. Play with going up or down at your track.
Old 11-01-2005, 04:24 AM   #11619
CAR
CAR's Avatar
Just getting into 19T foam class ,Stock chassis with a stiffer top deck small/tight track. Who has a fast set up. Thank You!
Old 11-01-2005, 04:33 AM   #11620
Hey guy's over on the Van. Ils. We place our touring cars to sleep for the winter. I was planning on going to the main land to do some carpet racing. stock rubber and maybe some 19 turn foams. I was curious what one should do to the MI2. to get her ready for some carpet action. I only have race on asphalt with the MI2. only ran 12th on carpet. so any sudjestion would be great. to get this car ready before I head over.
one other what a good 19 turn that runs great in the MI2. on carpet. Ive notice some motor work better than other in certain cars and certain surfaces. (carpet, ashphalt etc etc.)
cyrrus is offline   Reply With Quote
Old 11-01-2005, 04:34 AM   #11621
OH yeah forgot to ask. what is some good foamies to start with. and what compound.
Old 11-01-2005, 05:20 AM   #11622
hi cyrrus
set up for carpet im runing paul wynn speedline set up and its grate. jsut rase the rear pivot blocks 1mm. and it a good starting point.
i have run orion foams but on sunday i run ATS foams 35shore rear and 40 shore front and was happy with them.
i run a team br00d c2 in 19turn and its verry good in the mi2. i gear mine at 89/24 on a small/medium track.have also got a EA motor but not run it yet.
bob33 is offline   Reply With Quote
Old 11-01-2005, 07:09 AM   #11623
STLNLST's Avatar
I have been running the new GQ foams. Red/Tan fronts and Tan rears. They wear great and are very similuar to Parma and the old Jaco's not the new two stage. On rubber tire's I found that my asphalt set up worked great but a little fine tuning here and there made it awesome. For foams I'd go with PW set up or one of Mo's from www.gearchart.com I have been using the Reedy 19 turn in my MI2 and it's pretty fast. The C2 has also been burning up the track. You can't go wrong with either motor. Just make sure your roll out is correct and you should be fine.
Old 11-01-2005, 02:15 PM   #11624
thanks guy's
Old 11-01-2005, 02:22 PM   #11625
mini-dub's Avatar
Trader Rating: 16 (100%+)
You can't go wrong running Parma cyan fronts and magenta rears. Thats what I've been running and my foam car has been dialed.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
