Old 10-19-2005, 09:08 PM   #11461
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by PW
I would suspect production models will be running at the Birds
Anyone attending the I-Hobby show this weekend in L.A. please stop by and check out the booth My personal car has been taken away for everyone to check out....please be nice to her
PW when do you leave for the show? I have a couple of questions about the set up you posted.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-20-2005, 06:33 AM   #11462
PW
PW's Avatar
Send a message via AIM to PW
I leave today around 5:00pm est
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 10-20-2005, 06:40 AM   #11463
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Are you ever going to get to stay home from more than a week at a time?
Jon Kerr is offline   Reply With Quote
Old 10-20-2005, 06:53 AM   #11464
Taffyjnr5's Avatar
Trader Rating: 31 (100%+)
Jon,
I went out for another run using the PW setup and it was still quite taily even when the tyres come up to temp anything you can suggest maybe raising the rear roll centre 1mm from standard.
Taffyjnr5
Taffyjnr5 is offline   Reply With Quote
Old 10-20-2005, 07:08 AM   #11465
rcshark's Avatar
Send a message via Yahoo to rcshark
I switched the blue springs on front and silver on back had. Took the antidive out of the front and went to 27s and mishark is dialed. Still no ft. riaser plate. will try that later Im staying with what works.
thanks Jon taking out the washers up front and going to a lighter oil helps the car alot!
rcshark is offline   Reply With Quote
Old 10-20-2005, 07:36 AM   #11466
IslandBwoy's Avatar
Default Coned Spacer
Hey Guys,
I'm not sure how but i seemed to have misplaced my spacer (long) for my spur gear assembly and was wondering if anyone knew of a temporary way to replace that part until i get a new one.
Any suggestions would be appreciated.
R.
IslandBwoy is offline   Reply With Quote
Old 10-20-2005, 07:55 AM   #11467
Jon Kerr's Avatar
Originally Posted by Taffyjnr5
Jon,
Taffyjnr5
Is it loose on entry, mid, or exit?
Old 10-20-2005, 07:59 AM   #11468
Taffyjnr5's Avatar
Jon,
Exit under power.
Taffyjnr5
Old 10-20-2005, 08:04 AM   #11469
Jon Kerr's Avatar
Add some front droop. This will help the car transfer more weight to the rear on power. Also, watch the attitude of the car and have someone else watch the car. If it looks like it's rolling over too much or not rolling over at all, there could be other things that need to be addressed.
Old 10-20-2005, 08:12 AM   #11470
Taffyjnr5's Avatar
OK I will try that then I was maybe thinking that some rear antiquat 1mm might help but hey your the pro.
Taffyjnr5
Old 10-20-2005, 08:16 AM   #11471
Jon Kerr's Avatar
Far from a pro! But I try to help. I've been trying to get away from using antisquat. Only if it's really needed. Try the droop first then if that doesn't work, do the anti squat. What droop are you running in the front now?
Old 10-20-2005, 08:24 AM   #11472
Taffyjnr5's Avatar
Jon,
I am running 3mm front droop and 4mm rear.
Taffyjnr5
Old 10-20-2005, 08:59 AM   #11473
Jon Kerr's Avatar
Go to 3.5 in the front and try it. Then try .5mm antisquat. 1mm max. I'm actually running 3.5mm droop in the front and 4.5 in the back right now.
Old 10-20-2005, 09:44 AM   #11474
Send a message via AIM to Roberto Falcon
Hey Jon is it better to use the stock raiser plate in the front when using the BMI chassis?
Roberto Falcon is offline   Reply With Quote
Old 10-20-2005, 09:55 AM   #11475
Wirre's Avatar
Taffyjnr5
I've experienced the same kind of problems, but the car have been very consistant on power ever since I attached the riser plates and started using a bit higher roll centers, +.8mm in the front and +1.6mm in the rear. So you might wanna try that. I'm not using as much droop as before either, 4,5mm in the front and 3mm in the rear.
I'm not sure why these things have made the car so much better, maybe John has an idea?
Kyosho Ultima RB-5 SP
Kyosho Ultima RT-5
Kyosho Lazer ZX-5 FS
Orion Vortex Motors and ESC
Wirre is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
