Old 10-19-2005, 07:04 AM   #11446
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Not a problem Jon is the man and I'm working on it
Rod
ClemsonTigers
RKeasler is offline   Reply With Quote
Old 10-19-2005, 07:29 AM   #11447
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Taffyjnr5
I would like to thank Jon Kerr and RKeaser for thier help I used the PW setup you suggested and wacked on some Take off 27s and it is a bit taily at firstbut a differant car to drive it hugs the turns now and at least 1/2 a second a lap quicker.
Thanks heaps
Taffyjnr5
Anytime.
Jon Kerr is offline   Reply With Quote
Old 10-19-2005, 07:37 AM   #11448
Jon Kerr's Avatar
Originally Posted by bob33
helo all, what pw set up are u onabout withch 1 is it on gear chart,?
im looking at the state race one is that right for ruber carpet??
and on that am i right in thinking take front riser plate out then put pivot blocks on 1mm shims.
and on the rear wer do i put the 1mm shim for anti-squat? (and is that just 1mm shim on the riser) oh and btw im runing plastic pivot blocks.if it makes a diference.
thanks for the help.
http://www.racing-cars.com/usa/image...ew_asphalt.pdf
I'm not sure if this one is on gearchart.com, but I know it's the one we've been using. On this setup you run the stock riser plate in the front but if you want more steering, you can take that out and replace it with 1mm shims to lower the mount. This will lower the roll center. This setup shows the car with the stock 2mm riser in the rear as well. Personally I didn't like that and raised it an additional 1mm. But copy this setup exactly and start there. If you're running it on rubber tires on carpet, put a one-way in it.
Anti-squat is when the front of the hinge pins is higher than the rear. So if you want to put in anti-squat, start with just .5mm under the front but don't go over 1mm.
Old 10-19-2005, 07:47 AM   #11449
STLNLST's Avatar
Two more days until regionals. I can't wait to run the P-dub carpet set up. Hopefully it gets me the corner speed I have been looking for. Gotta show the king of this carpet track who the real boss is....LOL
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-19-2005, 08:39 AM   #11450
Send a message via Yahoo to Chico
Has Paul's Vegas carpet set up for foam tires ben posted yet?
TLR Racing - Team Orion - Dynamite - Horizon Hobby -Spektrum - Kolor Koncepts - Casper RC - RCinsider.com
Chico is offline   Reply With Quote
Old 10-19-2005, 08:40 AM   #11451
thanks jon i will try it in abit, im racing in about 4 hours ill just have a play with the set up ther aswell.
bob33 is offline   Reply With Quote
Old 10-19-2005, 03:18 PM   #11452
PW
PW's Avatar
Send a message via AIM to PW
Hey guys...I see a few request for my foam setup, but nothing has really been posted because my chassis was using most of the new Mi2EC specs
I will try and get something posted for the standard Mi2 spec or BMI spec
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 10-19-2005, 03:23 PM   #11453
drew85's Avatar
Paul anyword on when the new car is coming out??
drew85 is offline   Reply With Quote
Old 10-19-2005, 03:35 PM   #11454
Jon Kerr's Avatar
Hey guys. PW sent me the setup. The setup he ran was a little different because he essentially had the EC car. But this should work really well for you guys.
Old 10-19-2005, 03:46 PM   #11455
PW
PW's Avatar
Foam setup for the BMI Mi2
Paul Wynn
Old 10-19-2005, 03:51 PM   #11456
PW
PW's Avatar
Not really sure, but I think we have talked them into really go all out with the specs and that might delay the release slightly I think there are only about 4 or 5 things carrying over from Mi2....Can you say Mi3
Paul Wynn
Old 10-19-2005, 04:04 PM   #11457
Send a message via AIM to Roberto Falcon
SWEET!
Awesomatix USA - Speed Passion - Superior Hobbies
Roberto Falcon is offline   Reply With Quote
Old 10-19-2005, 04:38 PM   #11458
Hey Paul will I be seeing the new car at the birds next year?
Old 10-19-2005, 05:05 PM   #11459
PW
PW's Avatar
I would suspect production models will be running at the Birds
Anyone attending the I-Hobby show this weekend in L.A. please stop by and check out the booth My personal car has been taken away for everyone to check out....please be nice to her
Paul Wynn
Old 10-19-2005, 05:11 PM   #11460
Jon Kerr's Avatar
I may come up on Sunday. Depending on if we race Saturday night or not.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
