Old 10-18-2005, 08:37 AM   #11431
mutley001's Avatar
Hi
Looking for a good rubber tyre carpet setup (ing 25's) using my new BMI2 chassis. Any help gratefully recieved Jon or anyone else!
Cheers
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 10-18-2005, 08:45 AM   #11432
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Not sure about those tires, but with CS27's in Vegas we ran PW's asphalt setup with a oneway and a couple minor changes to adjust to the increasing grip through the week.
Jon Kerr is offline   Reply With Quote
Old 10-18-2005, 02:31 PM   #11433
Send a message via ICQ to MattW
mutley, has anyone actually seen any of those tyres yet?? I was told this afternoon that not that many had been seen...............
anyway, i have been working on a carpet set-up with rubbers. So far, i would say go with either PW's asphelt setup of Teemu's euros setup as your base. I have then gone up 4lb on front spring, and fitted a one-way. Have only done one club race so far, so i wouldn't say my set-up is finished, but that is where i am at the moment.
MattW is offline   Reply With Quote
Old 10-18-2005, 03:20 PM   #11434
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I ran the ING tires a couple of years ago on carpet, not sure what temp rating, but the setup was close to the 27's. I found they went away a little quicker the the 27's
Originally Posted by mutley001
Hi
Cheers
Paul
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 10-18-2005, 07:52 PM   #11435
IslandBwoy's Avatar
Are you guys making some sort of modification to get 2 degrees of toe in in the rear or are there blocks that allow for that setting? If there are blocks please send a part number.
IslandBwoy is offline   Reply With Quote
Old 10-18-2005, 08:12 PM   #11436
P-DUB's Avatar
The 2.5 deg U2742 alloy blocks actually give the car closer to 2deg than 2.5
Larry Pryor
P-DUB is offline   Reply With Quote
Old 10-18-2005, 09:25 PM   #11437
rbboy's Avatar
Send a message via MSN to rbboy Send a message via Yahoo to rbboy
JON KERR: hey there! thanks for e-mailing me your current set-up... i have a few questions though, how did you attain a front roll center of 2mm & a rear roll center of 3mm... is this thru the riser plates? at the front arm position, is this the wheelbase position of the arms? thanks!
www.xtremerchobbiesph.net
rbboy is offline   Reply With Quote
Old 10-18-2005, 10:21 PM   #11438
Jon Kerr's Avatar
No Problem. Happy to help. Front roll center of 2mm is just the riser plate. 3mm roll center is the riser plate plus a 1mm shim under each pivot block. And yes, the front arm position is the wheelbase adjustment on the front arms.
Old 10-18-2005, 10:23 PM   #11439
Send a message via AIM to Roberto Falcon
Why running so high of a roll center? Whats the difference from 2 to 3mm ?
Roberto Falcon is offline   Reply With Quote
Old 10-18-2005, 10:28 PM   #11440
Jon Kerr's Avatar
3mm isn't all that high. Some of the guys have run 4mm in low grip situations. You usually want to run about a 1mm higher roll center in the rear. When I need more steering and lower the front roll center to 1mm, I'll usually lower the rear to 2mm to keep the balance.
Old 10-18-2005, 10:33 PM   #11441
Hmm I didnt know that.. I usually just run 1mm spacers up front and the stock plate in the rear and it has worked fine for mostly all the tracks out here.
Old 10-18-2005, 11:30 PM   #11442
mutley001's Avatar
Cheers for the assist guys and yes I have seen the tyre but not actually run them myself yet (the works guys at my club have been testing them out!)
I guess i'll go with PW's setup and modify from there too!
Let you know how I get on on Sunday.....
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 10-19-2005, 12:18 AM   #11443
Hey I have a oneway that I have that I know im not going to use, I got it from one of the 2 mi2's I bought I dont know much about it all I can tell you is that the cars were run on carpet and from the looks of it its in good to new cond. so if anyone is interested in trading me for a spool let me know.
Old 10-19-2005, 03:05 AM   #11444
helo all, what pw set up are u onabout withch 1 is it on gear chart,?
im looking at the state race one is that right for ruber carpet??
and on that am i right in thinking take front riser plate out then put pivot blocks on 1mm shims.
and on the rear wer do i put the 1mm shim for anti-squat? (and is that just 1mm shim on the riser) oh and btw im runing plastic pivot blocks.if it makes a diference.
thanks for the help.
bob33 is offline   Reply With Quote
Old 10-19-2005, 05:06 AM   #11445
Taffyjnr5's Avatar
Trader Rating: 31 (100%+)
I would like to thank Jon Kerr and RKeaser for thier help I used the PW setup you suggested and wacked on some Take off 27s and it is a bit taily at firstbut a differant car to drive it hugs the turns now and at least 1/2 a second a lap quicker.
Thanks heaps
Taffyjnr5
Taffyjnr5 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
