Old 10-16-2005, 11:32 PM   #11401
mini-dub's Avatar
Trader Rating: 16 (100%+)
Just dont loan Sushi Boy any of yer stuff, he went home with both my motor AND pinion gear . I blew up the 7x2 saturday, timed at 22 degrees trying to dump. I couldnt dump if I tried (which I did). I'll just get the cobalt when I see you next but I should have my DC stuff soon. No more 10 turns ! It blew up before I could get an 8.9 though... I got 1 friday and that was it. My car was pretty good though, I was all 9.0's - 9.3's. You be at the track this week?
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 10-17-2005, 06:08 AM   #11402
Mini
Did you get a chance to try the new cantaliever suspension at the Nats? How was the car?
Oh and another thing, how how many bags of fish did you eat there?
Later
Jim
Fantom, BL Racing, Retired
jimnew is offline   Reply With Quote
Old 10-17-2005, 06:29 AM   #11403
Taffyjnr5's Avatar
Trader Rating: 31 (100%+)
Default Help Needed!!
Guys I have big understeer issues with my Mi2 I have just moved up to modified and the thing flies in a staight line but I can not steer it I have just about tried everything camber,castor,springs,shock oil,ride height,shock angle,front one way,front spool,standard diff,battery forward,battery back and so on and so on and every time it pushes going in either under power or off power and comming out under power.
Taffyjnr5 is offline   Reply With Quote
Old 10-17-2005, 06:33 AM   #11404
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
try this one
http://www.racing-cars.com/usa/image...ew_asphalt.pdf
Old 10-17-2005, 07:25 AM   #11405
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
That setup should give you massive amounts of steering.
Jon Kerr is offline   Reply With Quote
Old 10-17-2005, 07:31 AM   #11406
Taffyjnr5's Avatar
I have tried somthing very similar but my track is low grip and bumpy asphalt and it is difficult to get it to grip up and not have it bouncing through the turns. i currently have the softest setup I can grey springs and 4 hole piston and 25wt shock oil on the front and it will not turn in or hang on comming out I use a peak 10/1 motor on foam outdoor track and I have used just about everyones setup I have found on the net for my tracks characteristics and none have worked so far .I have a Teemu chassis on the way I hope this will help.
Desperate
Old 10-17-2005, 07:53 AM   #11407
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Desperate
Do you guys treat the track with anything? If not running foams on that track sounds lke it would be hard to do with any car, do you have to run foams? The setups that you will see on here are usually on rubbers for at least med traction tracks. If foams it's usually carpet, we had some guys try foams at our track and it was a no go.
ClemsonTigers
Team C Racing
TA10
RKeasler is offline   Reply With Quote
Old 10-17-2005, 08:03 AM   #11408
Taffyjnr5's Avatar
We have an open tyre rule here and everyone uses foam I have tried rubbers but it was worse we are changing to rubbers next year so i supose it will be difficult again.My teamate reckons I should of bought a Losi he runs one and it flies he broke the lap record with his GTX having no drag brake (stuffed) so I guess its back to the old drawing board.
I will keep trying
Old 10-17-2005, 08:12 AM   #11409
Jon Kerr's Avatar
I've seen cars run on low grip parking lot tracks before and it was never pretty. I'd go to rubber tires and put PW's setup on it to a T. Don't deviate from it at all to start. Then fine tune it from there.
Old 10-17-2005, 08:25 AM   #11410
RKeasler's Avatar
What rubber tires will you run? Your friends Losi If it is a JRXS is not rolling very much and is probably more stable with as soft a setup as you have it may just be "jacking" the car around that coupled with foams on a low grip track sounds like trouble. Try what Jon says "he knows" and that should get you close. After that I have a couple ideas that may help, my track while not a low grip parking lot surface doesn't have the grip that some of the guys on here have. Also my car is probably a little closer to stock like I am assuming yours is.
Rod
ClemsonTigers
Team C Racing
TA10
Old 10-17-2005, 09:13 AM   #11411
IslandBwoy's Avatar
Hey you guys think we can get a setup sheet designed for the BMI chasis; more specifically the shock mount towers/positions. I'm trying to follow some of the later setups that have been flying around and never know exactly which position (I wont say hole :-0) to put the shocks in or the camber links.
BTW. Where is the latest setup at? I looked on gear chart but the ones listed under PW are not the ones. At least i dont think so.
IslandBwoy is offline   Reply With Quote
Old 10-17-2005, 09:15 AM   #11412
rbboy's Avatar
Send a message via MSN to rbboy Send a message via Yahoo to rbboy
JON KERR/Paul Wynn: do you have any new set-ups for the BMi2? have a 19T race coming up.. kinda need PLEH!
www.xtremerchobbiesph.net
rbboy is offline   Reply With Quote
Old 10-17-2005, 09:35 AM   #11413
STLNLST's Avatar
Trader Rating: 19 (100%+)
I will keep trying
GTX is gas off road right??????
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-17-2005, 09:40 AM   #11414
STLNLST's Avatar
PW last set up that he posted on here with the white springs is by far the best set up to date with the BMI chassis and towers. You can put Masami a lap down with it
JON- u coming up for the carpet regionals this weekend? PW will be in cali this weekend I think but I don't expect him to pass thru
Old 10-17-2005, 10:51 AM   #11415
RKeasler's Avatar
GTX is Novak speedo.
ClemsonTigers
Team C Racing
TA10
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
