Old 10-06-2005, 02:53 PM   #11251
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
It's not a completely new car. It's is going to be a copy of Teemu's car from the Euros. This car had all the things that guys have been doing to the car that help the performance. Things like the different chassis and suspension geometry. Better shocks and the new drivetrain. That being said, there's enough different about it that it would be cheaper to buy the EC car than try to convert the current car to the EC specs.
It is more of a asphalt car in the kit form, however there will be an optional chassis and top deck to make it a carpet car.
Jon Kerr is offline   Reply With Quote
Old 10-06-2005, 03:02 PM   #11252
Jon Kerr's Avatar
Originally Posted by bob33
i dont think they run foams but the track int like normal carpet its a rubbery thing (its on a indoor runing track) i never been ther befor, but the grip is suposed to b like tarmac.
MATTW have u been ther (don vally sheffeild)
jon 2 more things what shock length you runing on that set up u gave me
and lastly wer its says ackerman/bump middle/3mm whats this mean (i dnt no waht all this ackerman is lol)
thanks
If the grip is similar to good asphalt, this may be a good starting point for you. I can't remember the shock length I have on there. The main thing to remember with shock length is just make sure they're long enough to not hinder the droop and that they're equal on both sides.
The Ackerman is the difference in how much one wheel turns compared to the other. It's adjusted by moving the ball stud on the steering bell cranks. Use the middle hole on the bell cranks with 3mm spacer under the ball stud.
Old 10-06-2005, 03:13 PM   #11253
thanks alot jon, i understand that now lol. we have to use nosram vetec 24r preglued tyres/insert/rim as the controll tyres so will have to see what these are like as i never used them befor . thanks bob
bob33 is offline   Reply With Quote
Old 10-06-2005, 03:18 PM   #11254
Jon Kerr's Avatar
Anytime.
Old 10-06-2005, 06:20 PM   #11255
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
Can anyone tell me what setup is this ? looks like a pro4 rear shock tower ???
Roberto Falcon is offline   Reply With Quote
Old 10-06-2005, 06:22 PM   #11256
cornerspeed's Avatar
Kinda looks like a BMI tower, but not.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 10-06-2005, 06:26 PM   #11257
Jon Kerr's Avatar
Actually, I think that's a Yokomo shock tower. Jim Newberg was using Yok towers in Vegas and that's what they looked like. Jim, you want to chime in and correct me if I'm wrong.
Old 10-06-2005, 06:26 PM   #11258
I have run both the BMI chassis's and the Teemu chassis. I am currently running the Teemu. Seems better for me. I think it has more turn-in then the BMI because of the rearward battery position and the pendulum effect. My car does not get loose on turn-in, just better suited for me to my driving style and set-up.
Donny Vinkemulder
TLR Driver
Old 10-06-2005, 06:36 PM   #11259
I have a BMI rear tower, should I swap them ?
Old 10-06-2005, 07:46 PM   #11260
Jon Kerr's Avatar
I would just so that you're more on the same page as most of the other drivers that are using them.
Old 10-06-2005, 11:53 PM   #11261
Default mi2
hi i was wondering if any one had a foam tire carpet setup i could use i have a mi2 with bmi lower and top deck and i have lower shock towers can any one help me.
regards matt
snap_u2000 is offline   Reply With Quote
Old 10-07-2005, 05:31 AM   #11262
jayps's Avatar
Send a message via Yahoo to jayps
Hi everyone. I just wanted to ask what your take on this is or if anyone has tried this out. I am currently running with a teemu chassis and shock towers. someone told me that I could try installing the stock riser plates together with the ones that came with the teemu chassis to increase my center roll rate. comments please.thanks
JP
jayps is offline   Reply With Quote
Old 10-07-2005, 05:58 AM   #11263
Jon Kerr's Avatar
regards matt
PW has a killer foam tire setup from Vegas. I don't think he's had a chance to get it ups on the site yet. (With nationals right after Vegas and all.) Adrian, do you have a copy of it yet?
Old 10-07-2005, 05:59 AM   #11264
Jon Kerr's Avatar
JP
I don't have any experience running those risers under the bulkheads. They're usually used for very low bite conditions. What are your track conditions like?
Old 10-07-2005, 06:01 AM   #11265
Actually it is a Rayspeed option part for the Yok SD.
As to whether you should run it or not, it depends on the surface you run on.
This tower actuall has the camber link holes that are very similar to the newest generation BMI towers that were made for the IIC in Vegas. It also lowers the upper shock mounting holes a little more then the BMI. This tower works very well in high bite or with foams. If you are going to be running outdoors stick with the BMI towers.
And another thing, Roberto, if you have any questions on any thing on that car, feel free to ask. As Jon Kerr can atest to I completely rebuilt that car (yours) at Vegas
Later
Jim
Fantom, BL Racing, Retired
jimnew is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
