Old 10-02-2005, 07:48 PM   #11191
mini-dub's Avatar
Trader Rating: 16 (100%+)
I think the girl with the nice camera was doing that. You should stop posting so much and get back to work on our cantilever shock tower design , it would be cool to see if it worked. Hey if one corner of your car was almost like the real design and you made the main like that it might be dialed . Let me know if you actually get anywere with it, that would be hilarious.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 10-02-2005, 08:11 PM   #11192
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by mini-dub
Jon - I saw those on your car at Vegas, thats a cool idea. The only thing is can you pop those off if you need to take the bearing off the outdrive? Then just CA em back on? Blades sure wear even faster when your spool outdrives spread . Thanks.
Yeah, All you have to do is take an Exacto knife and scrape the glue off. It should just flake right off. It doesn't stick permanently to the aluminum outdrive. Just enough to hold them in place.
Jon Kerr is offline   Reply With Quote
Old 10-02-2005, 08:54 PM   #11193
AdrianM's Avatar
Originally Posted by lmunno
Teemu vs turn marshall = car lost
Yeah, Teemu easily TQ'd the club race before the ROAR Nats and was running away with the race when a young corner marshall ran out to get a car and stepped right in front of Teemu's car...going full throttle. The good news is the kid is fine. Who would have thunk DC skate shoes were great at protecting your feet from 45mph Mod Sedans. The bad news is that the actual car Teemu used to win the Euros is completely destroyed.
The other good new is that PW ran down Barry Baker and took the win. Schumacher swept all classes winning 19T, Pro Stock and I even won 1/12th with a new BMI pan car.
Adrian Martinez
Old 10-02-2005, 09:44 PM   #11194
mini-dub's Avatar
Good thing they copied it already
Old 10-02-2005, 09:50 PM   #11195
Iain's Avatar
On the EC, it states that the drive shafts are alloy, will they be strong enough to survive in mod with the spool?? I understand they would for a while, as thats what Teemu was probably using, but he doesn't have to pay for more if they break....
Iain
Iain is offline   Reply With Quote
Old 10-02-2005, 09:56 PM   #11196
Jon Kerr's Avatar
I've been running the purple alloy CVD's with a spool and 7 turn motors without problems.
Old 10-02-2005, 10:05 PM   #11197
Iain's Avatar
Ok cool, thanks Jon, are they the same as the titanium ones?? Or are they a made from a different material?
Iain
Old 10-02-2005, 11:10 PM   #11198
King-G's Avatar
Send a message via ICQ to King-G
The early batches of the Worlds CVD were prone to snapping at the base of the ball - cvd pivot joint, as there was too little material there. The following batches are almost bullet proof, I'm yet to break one using a spool and 7's.
brilliant CVD's, much lighter than any I've seen.
King-G is offline   Reply With Quote
Old 10-02-2005, 11:13 PM   #11199
King-G's Avatar
The confusion arises because they are Made by Titanium racing, they are infact made of alloy.
Excellent durability, I cant really fault them after months of use I cant detect any wear of the joint. You wouldnt expect this kind of wear when they are so light.
Just keep them clean and re-greased between meets.
Old 10-02-2005, 11:13 PM   #11200
Jon Kerr's Avatar
The purple one are aluminum I believe. And like Gavin said, the early ones broke the axle itself, but that's been fixed.
Old 10-02-2005, 11:42 PM   #11201
Iain's Avatar
That explains it, thanks Gav and Jon.
I currently have the alloy ones on the front of mine, as I am running the spool. So no drama's with them then.
Cheer's
Iain
Old 10-03-2005, 04:04 AM   #11202
lmunno's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to lmunno
lmunno is offline   Reply With Quote
Old 10-03-2005, 04:16 AM   #11203
Send a message via ICQ to MattW
Nasty crash, seen worse mind. Chris A killed his race car at a practice day, flat into the end of the main straight. Can't remember if the top deck was in 3 or 4 pieces - chassis was in 2. As a side note, the driveshafts survived, so even though they are alloy they are still strong.
Gavin is correct about the earlier ones, although i have been running a pair all year and only recently had to change the axles as i'd broken them. The bones are still fine - although i one of them has started to twist a bit
MattW is offline   Reply With Quote
Old 10-03-2005, 04:44 AM   #11204
rcshark's Avatar
Send a message via Yahoo to rcshark
Destroyed or not can I put in my bid for Teemu's car. That would be a prize!
I wished that drivers would put there cars up for sale after big races like last yrs. aleast old bodies. This would good publicity. Especialy if there is a good story behind it.
rcshark is offline   Reply With Quote
Old 10-03-2005, 07:50 AM   #11205
Taffyjnr5's Avatar
Trader Rating: 31 (100%+)
Default understeer issues
I am new to racing R/C tourers an have just bought a new MI2 to race modified and i am suffering with understeer issues I race on a low grip outdoor asphalt track on foams with a peak vantage 10/1 the car is in stock trim with the stock setup and i have just about tried everything.
hope some one can help thanks.
Taffyjnr5 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
