Old 10-01-2005, 11:20 PM   #11176
Iain's Avatar
Hey AdrianM,
Do you have any idea when the EC will be released??
Also, it says narrow hex's are included, is that in addition to standard ones or instead of?? And are all sway bars included??
Iain
Iain is offline   Reply With Quote
Old 10-01-2005, 11:21 PM   #11177
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
Nice!.. I just got me a Mi2 from Jim but ive had a Mi2 before and I stupidly sold it to Jack Smash (tears) lol ...but oh well people do dumb things all the time.
Hey Jack how is the car doing ?
Roberto Falcon is offline   Reply With Quote
Old 10-02-2005, 07:35 AM   #11178
IslandBwoy's Avatar
What about the diffs? One of my pain points is the out drives on the diff. They seem to tear up mutch faster than i can replace the blades. Will the EC have a new design to the outdrives? Maybe rounded edges or reinforced materials? Maybe we can get someone to machine some new ones like Troy's :-) Wishful thinking hu?
IslandBwoy is offline   Reply With Quote
Old 10-02-2005, 08:53 AM   #11179
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Donny and I have been making outdrive savers out of the inner race from old outdrive bearings for a while now and haven't hurt and outdrive since. Just take an old dead bearing, cut the outer race off it with a cut off wheel. The inner race will pop out and slide the inner one over the outdrive once the spool is installed. Use a very small drop of CA to hold it in place on the outdrive.
Jon Kerr is offline   Reply With Quote
Old 10-02-2005, 09:13 AM   #11180
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Car is really good. Haven't been able to put too many runs on it due to employment issues and needing to replace some electronics. Car now has the JMO carpet setup on it and just waiting to buy a new reciever and then its carpet season!!
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 10-02-2005, 10:29 AM   #11181
STLNLST's Avatar
Trader Rating: 21 (100%+)
What type of receiver are you looking for? I have a KO 27 band and a 75 band. Let me know.
The car was killer yesterday. I came up with my own set up and it was pretty killer. I just need to get more corner speed out of it. I had plenty of ponies though. Pulled Aaron down the straight Tested tire's and bodies yesterday and the G6 is pretty killer. The proto form alpha is also nice. Gotta worry about these RDX's now. Aaron was on fire and Charlie looked good as well. Next weekend will be more testingfor the regionals.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-02-2005, 01:29 PM   #11182
CAR
CAR's Avatar
I take it the new car will not have the adjustable battery tray ? If not will the battery location be in the same location between the 2mm and 2.5 mm chassis?
CAR is offline   Reply With Quote
Old 10-02-2005, 01:33 PM   #11183
mini-dub's Avatar
Trader Rating: 16 (100%+)
Jon - I saw those on your car at Vegas, thats a cool idea. The only thing is can you pop those off if you need to take the bearing off the outdrive? Then just CA em back on? Blades sure wear even faster when your spool outdrives spread . Thanks.
Car - There is no tray on the EC or battery strap, we've found the tray and battery straps can tweak your chassis (tape can to, but it wont if you dont strap it like a cave man) and besides those add weight . I presume the battery position will be the same (middle) on the 2mm and 2.5mm chassis.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 10-02-2005, 01:37 PM   #11184
mini-dub's Avatar
dang RDX's
Old 10-02-2005, 01:39 PM   #11185
Korey Harbke's Avatar
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-02-2005, 01:53 PM   #11186
STLNLST's Avatar
Originally Posted by Sushi Boy
We'll get ya'll soon.
Old 10-02-2005, 01:56 PM   #11187
STLNLST's Avatar
Originally Posted by mini-dub
dang RDX's
I have to admit that the car rocks. But we are right there. Just need that one last set up change to dip the times down some. I have a few things to try next weekend so I'm looking forward to it. Then I gotta start all over once I get the new car.
Old 10-02-2005, 02:02 PM   #11188
mini-dub's Avatar
You running foam? I need some foam setups to start with when I get back from nats. I'll be starting with PW's Vegas setup but I want to look at what other drivers are running.
Old 10-02-2005, 05:02 PM   #11189
lmunno's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to lmunno
Teemu vs turn marshall = car lost
lmunno is offline   Reply With Quote
Old 10-02-2005, 07:11 PM   #11190
There is no tray on the EC or battery strap, we've found the tray and battery straps can tweak your chassis (tape can to, but it wont if you dont strap it like a cave man).
Mini- Where have you seen that before
Later
Jim
Fantom, BL Racing, Retired
jimnew is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
