Schumacher Corner
Adrain,
Thanks for the info and put my name on the list I realy would like to get the new car before I goto irac it would be cool to see how good it works on the tarmac!
Originally Posted by MattW
bob, the base setup that Chris and myself run at most UK National tracks is basically the Teemu Euros setup. I haven't done any work on a new carpet set-up yet, that starts in the next week or so!
This past weekend, we did drop the rear r/c to 1.5mm for a little more taction, and i also moved the front wishbone back to alter the steering.
If your car is so bad, i would also give it a good check over to be sure tha tyou don't have anything actually wrong with it. Doesn't matter how good the set-up is, if there is something wrong wiht the car.
wen u say r/c do u mean roll center (so taking out the riser plate and puting 1.5 under instead?) wer is the set up on the schui teck info ? i will put it on and try it. thnaks bob
no I believe MattW means he was using a 2mm shim ontop of the riser plate, and he removed that and replaced it with a 1.5mm shim, effectively lowering the rear R/C .5mm
Yes, King G is correct 1.5mm/2.0mm on top of the carbon riser plate. This is with the alloy pivot. If you look in the Tech info, under Mi2 then look on page 2 you can see Teemu's Euros set-up.
right thanks u 2, wen teemu mesurs droop. is that chassis flat to the floor then mesur up to the top of the axles?
just sum more things, wen he says rasied innner pin 1mm?
and rasied upper camber link 3mm how do i do that.?
think thats it lol sorry bout all the questions.
thanks bob
thanks bob
What chassis is better for carpet, the BMI, or the Teemu?
Or are they both pretty close.
Have you ever tried the Teemu chassis?
Are both chassis the same thickness?
I talked to Seaball last night about the different Mi2 chassis and he said that BMI has it about right. He also did a lot of development work on steering geometry, etc. that I think inspired the dialed Mi2 ec's used at Vegas. Seaball has an unbelievably dialed Mi2 he runs on carpet/foams at the Gate.
I know from experience that the CF BMI uses is awesome and his work is the best in the business.
Gear Ratio
Hey Guys,
Long time no talk. Everyone seems to be pumped on the EC but i'm still working on getting my TEEMU converted over to the BMI Regarding gear ratio's and motor combinations, I noticed at the last over at supperior that Troy's car had all kinds of crazy rip out of the corners and was wondering what size spurs do you guys run for the most part. Currently i have a 122/41 combination in which i think is affecting my ability to spool up quickly. The car is still fast once it gets up to top speed but on smaller tracks obviously i would have an issue. Am i correct in assuming that my spur gear may be a bit on the excesive side? If its not that, what motors are you guys running for 19T classes. I'm still running the Reedy quad spec motors.
~MI JEDI
~MI JEDI
Hey guys,
a friend of mine wants me to order 24-Ceramic Si3n4 Grade 5 diff balls for him in 2.5mm-same size as Mission. I already sell other sizes and I have to buy 100 at a time for price. if any of you guys will commit to a few 24 packs-I can buy them bulk. Its $31.10 for 24 shipped in the US. No comments about put it in the for sale forums-I know that-just trying t help out a buddy. one time deal. Let me know asap [email protected]
Ray
Ray
Bob, yes that is how he measures droop.
raising inner pin 1mm is to raise the roll centre - it's just putting a 1mm spacer under the inner pin mounts.
raising the camber link is a little more tricky. you need to file (or dremel) the camber link hole upward 3mm (or what ever dimension). Can be a little tricky, but you just need to take some time and measure carefully with vernier caliper.
right thanks ill have a look at doing that then. then try it on sunday thanks
Originally Posted by IslandBwoy
Hey Guys,
~MI JEDI
~MI JEDI
Schumacher ball grippas...
Any body got the part # for the Schumacher ball grippas...
