Old 09-05-2005, 02:43 PM   #10876
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by RKeasler
What method are you guys using to measure droop?
Most of the time it's measured above ride height. You set your ride height and then lift one end of the car just until the tires are just touching the surface then measure it again. The difference is your droop. If you're running 5mm rider height and you want 4mm of droop, when you lift the car it should read 9 on the droop gauge. Then once you have it set to the right height, use a droop gauge like the Schumacher Aluminum one of the Hudy one to make sure both sides are exactly the same.
Sometimes though you'll see some of Teemu's setup sheets show him measuring it with the chassis flat on the surface and measuring to the top of the axle.
Jon Kerr is offline   Reply With Quote
Old 09-05-2005, 09:08 PM   #10877
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
You mean like the graduated one from Losi,Assoc. etc.? Seems to be a little more precise that way. Assuming measured to the bottoms of the hub.
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 09-05-2005, 10:16 PM   #10878
Jon Kerr's Avatar
It is more precise that way but not all of them measure the same. So me using my Schumacher gauge may not read the same as your Losi one. So using the method of checking it above droop is more universal and just use the droop gauge itself to even things up on both sides.
Old 09-05-2005, 10:27 PM   #10879
RKeasler's Avatar
Makes sense to me I used that method, now just need to check to be sure things are equal. I will be doing a little stock racing this weekend so freeing up the car the way we discussed is even more important, we will see how it goes.
Rod
ClemsonTigers
USVTA # 224
ERC
Old 09-05-2005, 10:41 PM   #10880
Jon Kerr's Avatar
Let me know if you need anything else.
Old 09-06-2005, 02:29 PM   #10881
Default Can any one reply to this?
I found someone on this board is selling ia front one way but he says that it is not the one pictured can anyone clear this up for me.
Here is the link to the sale: FS: Schumacher Mi2 One Way Front Diff
Thanks,
Z
zephry is offline   Reply With Quote
Old 09-06-2005, 02:47 PM   #10882
Jon Kerr's Avatar
That picture is of the new heavy duty oneway. He probably has the older, less beefy one-way.
Old 09-06-2005, 02:52 PM   #10883
Man that was quick
worth the $20 he's asking?
I hope to get a actual photo of the one he is selling.
What would it take to rebuilt it?
thanks.
Old 09-06-2005, 03:21 PM   #10884
Jon Kerr's Avatar
I've never had to rebuild a oneway. Personally, I'd just get a new one. They go for about $70 for the new heavy duty one. Plus if he's saying it could use a rebuild, it may have a blown out oneway bearing and you'll probably end up needing a new one anyways.
Old 09-06-2005, 09:18 PM   #10885
STLNLST's Avatar
Trader Rating: 21 (100%+)
I've run my original one way since the car first came out and I haven't had any problems with it. I may be one of the only team driver's that has run the crap out of his oneway
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 09-06-2005, 09:19 PM   #10886
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Don't you actually have to race to run the crap out of a oneway?
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 09-06-2005, 09:37 PM   #10887
STLNLST's Avatar
you say something backmarker The Schumacher party will be at Ripon while the big boys are having the Vegas Schumacher party. Which event do you plan to make????
Old 09-06-2005, 10:32 PM   #10888
Jack Smash's Avatar
If all goes well I'll be training for my new job in Vegas the same week as the race. Spectating only though If not, I wont be at Ripon cuz my Room n' Board hookup will be at Vegas Looking forward to Carpet season though.
Old 09-06-2005, 10:58 PM   #10889
bender's Avatar
Guys, I just got myself a Pdub bumper and was wondering how you fit it?
It's so stiff compared t the stock one that it won't compress when you do the upper and lower bumber mounts together. Do I have to cut that section?
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 09-07-2005, 04:31 AM   #10890
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
it fits right in with no cutting.
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
