Old 08-30-2005, 12:52 AM   #10816
Cole Trickle's Avatar
Originally Posted by Jon Kerr
Depends on if you're running a spool or not in the front. With a spool running mod or 19 turn, I change the fronts every 3-4 runs. With a oneway or diff, they should be fine for a while. The rears I replace every couple of race days just to be sure. I keep a good stock of them at all times.
Thanks. I'll be running stock and rubber tires on carpet. No spool, but probably a one-way a little later.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 08-30-2005, 12:53 AM   #10817
Originally Posted by P-DUB
How AWESOME is that...SEABALL is my carpet hero!!!!!!!
Yeah, congratulations Seaball
Old 08-30-2005, 12:56 AM   #10818
Mechanical grip is the opposite of aero grip. Mechanical grip is any kind of grip generated by the car itself. The suspension, tires, chassis etc... So spring rates, camber links, tire compounds, all that stuff will effect the mechanical grip the car gets. On the other side, aero grip is generated by the body.
Thanks.
Old 08-30-2005, 01:00 AM   #10819
1. The Schumacher shocks will work fine. The TRF ones are just easier for most to build and build consistently. Plus most companies springs will fit them easily without using preload spacers.
Dont shorter shocks like TRF, require new shock towers and riser plates?
Old 08-30-2005, 02:08 AM   #10820
Wirre's Avatar
You can use the TRF shocks with the old towers aswell, the shocks comes with longer ball cups aswell. The riser plates require short shocks and teemu towers, not the other way around :-)
Kyosho Ultima RB-5 SP
Kyosho Ultima RT-5
Kyosho Lazer ZX-5 FS
Orion Vortex Motors and ESC
Wirre is offline   Reply With Quote
Old 08-30-2005, 02:10 AM   #10821
Iain's Avatar
You don't need the low towers, yes they are better, but you can run the std towers with schumacher ball joints on the trf shocks to give them more length.
You only need new risers if you want to run the raised transmission and then you need the Teemu towers also.
Iain
Iain is offline   Reply With Quote
Old 08-30-2005, 02:12 AM   #10822
Thanks for clearing things up. One Q though, what's the advantage of the Teemu riser plates and shock towers? www.racing-cars.com aint particular clear about stuff like this... or I've looked at the wrong place ?
EDIT: Ian anserved my Q, while I was typing
Old 08-30-2005, 07:09 AM   #10823
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Cool word
Originally Posted by robk
C-Ball in full effect...Looks like a Schumacher won the Halo Hobbies Vegas warm up race...
hey, thanks guys. this baby's working well for me. no doubt. the next time someone tells you this car won't work on foams, just make sure you are smiling at them when you say "ok".
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 08-30-2005, 10:12 AM   #10824
Conrad's Avatar
Ah, told you someone would be along with a better explanation
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 08-30-2005, 12:41 PM   #10825
tim fry's Avatar
Hi guys
Need a bit more help with my Teemu chassis. It came with two small plastic shim/washers and I cant find where they go
Any help would be great
Tim
tim fry is offline   Reply With Quote
Old 08-30-2005, 12:47 PM   #10826
mini-dub's Avatar
Trader Rating: 16 (100%+)
Those washers should go under your battery strap posts to raise the strap to the height it would normally be at with the battery tray.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 08-30-2005, 12:48 PM   #10827
tim fry's Avatar
Ive got those ones under the posts the ones I mean are smaller I think they go on the steering somewhere
Old 08-30-2005, 01:15 PM   #10828
bender's Avatar
Originally Posted by tim fry
Hi guys
Tim
Did you get the whole Teemu conversion (ie: new riser plates too?). As I understand it, the little black washers go on top of the steering bellcranks to raise the long steering posts so that the heads still fit in the holes of the top deck once it's been raised with the new risers.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 08-30-2005, 01:25 PM   #10829
tim fry's Avatar
Yes the full conversion and that seems to have sorted it thanks
Old 08-30-2005, 04:33 PM   #10830
P-DUB's Avatar
Some cool action shots from this years National track http://rpm-photography.com/Gallery/d...album=24&pos=1
Special thanks to Jack!
Larry Pryor
P-DUB is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
