Old 08-29-2005, 07:48 AM   #10801
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by SQC049
Hey guys, I just got my Mi2 over the weekend but I am yet to run it. A few quick ???s before I do. I will be running the car on a medium sized carpet track, using foams.
First, I bought the car used, it has the aluminum rear hubs and aluminum spur gear adapter. Is there any other upgrades I need? I know people say to upgrade to TRF shock, but I want to know why? The Schumacher shocks seem very smooth and I dont see the point in spending that kind of money on new shocks.
2. The car came with a 124 tooth spur. What is a good starting pinion to run for stock? I know I will need to fine tune the gearing for the track I am running, but I would just like to know a good starting point.
3.What a some good spares to have on hand? I am ordering a bunch of stuff from Schumacher and would like to know what brakes alot.
Any other info you guys have would be great. I am very impressed by the design of this car, I cant wait to get it on the track.
Drew
1. The Schumacher shocks will work fine. The TRF ones are just easier for most to build and build consistently. Plus most companies springs will fit them easily without using preload spacers.
2. Don't know rollout but I'm sure if you go to www.gearchart.com you should be able to find a good rollout starting point.
3. Stock up on the usuals, front and rear arms, caster blocks, spare blades, etc... Maybe a set of hinge pins. As for upgrades, get yourself a P-Dub front bumper, a selection of springs, (Schumacher has a new pro spring kit out) and you should be good.
Jon Kerr is offline   Reply With Quote
Old 08-29-2005, 07:50 AM   #10802
Jon Kerr's Avatar
Originally Posted by Cole Trickle
How long do the blades last? Is it a good idea to have some spare ones, or will I do fine, if I check them once in a while?
Depends on if you're running a spool or not in the front. With a spool running mod or 19 turn, I change the fronts every 3-4 runs. With a oneway or diff, they should be fine for a while. The rears I replace every couple of race days just to be sure. I keep a good stock of them at all times.
Old 08-29-2005, 08:03 AM   #10803
SQC049's Avatar
Trader Rating: 15 (100%+)
Thanks for the fast reply. My only other questions is, do you think that the BMI chassis is a worth while upgrade? I will be running the car only on carpet and I am interested in it. Is it worth getting or is the stock chassis fine?
Also, where can I get a Pdub bumper?
Thanks again
Drew
SQC049 is offline   Reply With Quote
Old 08-29-2005, 08:16 AM   #10804
AdrianM's Avatar
Originally Posted by STLNLST
Can someone please give me a roll out to start out with using a Reddy 19 turn with foam tire's? This will be the first year we are running foam 19 turn so I need a good idea as to what I should gear this thing at. Any help is greatly appreciated.
Well...since we run in the 5.6-5.8 final drive range with the Reedy 19 on rubber (63mm) I would say try something around 5.2-5.3 final on 58mm foams. This would give you about the same roll out rubber to foam.
I had to go to Gearchart.com to figure this out...lol!
Start at 5.3 and gear up until you either slow down or the car starts to feel soft out of the corners then drop a tooth or two from that. You want to use the lowest gear ratio that gives you fast lap times. If you gear up and do not pick up speed you are just heating your motor up and draining your batts without going anywhere.
Adrian Martinez
Old 08-29-2005, 08:33 AM   #10805
Jon Kerr's Avatar
Thanks again
Drew
Absolutely. It's stiffer than the stock chassis and pulls everything in much closer to the centerline of the car. This will help it transition weight quicker and it helps keep it more balanced. If you're running on carpet, get the solid top deck for more rigidity. For asphalt, get the flex deck. The Teemu chassis is also very good for carpet. You can get a P-dub bumper by clicking on the link in my sig to go to his website and order one direct from PDub.
Old 08-29-2005, 08:34 AM   #10806
HarshGuy's Avatar
LOL, yep I had to go there to and had to "reverse calculate" my rollouts for stock, redline 19T's (orion based) and reedy quad 19T's ...found out I gotta use a smaller spur for the orion based 19T as I can't stuff a big enough pinion in my car to get the correct rollout with the existing spur!!
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 08-29-2005, 12:13 PM   #10807
tim fry's Avatar
Hi all
Just preparing my Teemu chassis and was wondering how much material to take off the cell slots. On all my other TC I've only ever just beveled the edges. I'm running 3300s What do you all do?
Tim
tim fry is offline   Reply With Quote
Old 08-29-2005, 12:13 PM   #10808
bender's Avatar
Originally Posted by Wirre
Actually, you can see graining on the tires, this have happened to me many times with Sorex 36's. This usually occurs in the front tires when going out too hard on a new set, if you survive the first couple of runs, you should be ok. Just turning in a bit easier in the high-speed corners helps a lot.
Ok, then I assume it's not the tyres as they look very good, like they've only been used for a couple of laps.
Maybe it's my setup? - If the front tyres heat up before the rear then initially I would have good steering which would then turn to understeer as the rear tyres warmed up
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 08-29-2005, 12:18 PM   #10809
AdrianM's Avatar
Just take the sharp edge off the cell slot. Beveling is not necessary and will result in your cells hanging out below the chassis....not good...lol!
Adrian Martinez
Old 08-29-2005, 12:20 PM   #10810
tim fry's Avatar
Thanks thats the answer I was looking for
Old 08-29-2005, 12:42 PM   #10811
mini-dub's Avatar
Trader Rating: 16 (100%+)
Hope you florida guys aren't getting hit too hard by the hurricane , it sounds like a bad one. But what would I know, I live in the Northwest .
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 08-29-2005, 02:37 PM   #10812
robk's Avatar
Trader Rating: 22 (100%+)
C-Ball in full effect...Looks like a Schumacher won the Halo Hobbies Vegas warm up race...
Old 08-29-2005, 06:11 PM   #10813
cornerspeed's Avatar
Originally Posted by Jon Kerr
Mechanical grip is the opposite of aero grip. Mechanical grip is any kind of grip generated by the car itself. The suspension, tires, chassis etc... So spring rates, camber links, tire compounds, all that stuff will effect the mechanical grip the car gets. On the other side, aero grip is generated by the body.
Well said.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 08-29-2005, 07:58 PM   #10814
P-DUB's Avatar
How AWESOME is that...SEABALL is my carpet hero!!!!!!!
Larry Pryor
P-DUB is offline   Reply With Quote
Old 08-29-2005, 11:59 PM   #10815
STLNLST's Avatar
Trader Rating: 19 (100%+)
Thanks. We gotta start getting everything ready for the first carpet race in October.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
