Old 08-25-2005, 08:14 PM   #10771
P-DUB's Avatar
Originally Posted by bender
Thanks for the setup
I was just looking at it and I have a few questions.
What is the theory behind raising the inner camber link position on the front?
It's such a big change (raised 4mm), what will that do?
Secondly, is running lighter oil in the front usual or is this just one new idea that is working?
We have found that the raised camber link is giving us WAY more steering/cornerspeed and better tire wear. I have my theories as to why, but we will save that for another day
lighter oil in the front is something we decided to try again and it seems to work pretty well
Larry Pryor
P-DUB is offline   Reply With Quote
Old 08-26-2005, 08:33 AM   #10772
PW
PW's Avatar
Send a message via AIM to PW
Roll call for the IIC Las Vegas race paul@schumacherusa.net
Roll call for the ROAR On-Road Nats paul@schumacherusa.net
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 08-26-2005, 03:15 PM   #10773
Cole Trickle's Avatar
Originally Posted by mini-dub
Cole Trickle - I have a good setup for both a oneway and spool on low - medium traction carpet for stock, 19t and mod. Let me know if you want me to send you either or both, although I can only send them in an excel format.
Thanks, Mini-Dub - I'm very interested.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 08-26-2005, 03:25 PM   #10774
Originally Posted by cyrrus
Hey cole makes total sense. but my question is when do you change the spure gear. I understand pinion now.
Basically, the spur will do the opposite, as the pinion. So one tooth LESS on the pinion, equals a non-changed pinion with a spur with approx. 3 MORE teeth. And vice-versa. It's all about changing the relationship.
However, changing the spur, will cause the motor to be moved sligthly more. In a car like the HPI pro2, it was up/down, the motor changed. So here the idea was to use a spur as large as possible, because that lowered the motor, thus lowered the CG.
In the MI2, the movement is front/rear, and since I dont have the car yet, I cant make any recommendations. I would assume, that moving the motor forward, will give sligthly more steering. But since it's rotating, there's more into it, than just moving dead weight forward
Old 08-27-2005, 08:08 PM   #10775
P-DUB's Avatar
Thought I would post a pic of the new shell before it gets to beat up
Larry Pryor
Old 08-27-2005, 08:13 PM   #10776
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
Looks nice!!! see you tomorow(weather permitting)
Old 08-27-2005, 08:34 PM   #10777
P-DUB's Avatar
Thanks!! What weather....LOL See ya tomorrow
Larry Pryor
Old 08-27-2005, 09:13 PM   #10778
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Originally Posted by PW
Just wanted to let everyone know that I have been working on a new asphalt/rubber tire setup and its been pretty darn good. Click here to give it a shot http://www.racing-cars.com/usa/image...ew_asphalt.pdf
PW I am assuming that you are drilling the new holes on the tower? What is the main difference from the stock towers to the carpet. I need some corner speed bad.
Rod
ClemsonTigers
USVTA # 224
Team C Racing USA / TC 10 2015
ERC
RKeasler is offline   Reply With Quote
Old 08-28-2005, 12:23 AM   #10779
cornerspeed's Avatar
Jon and I ran the set-up at SoCal tonight and it was pretty darn good. We both added a little more droop to the front end. Jon ran the alloy rear hubs and I ran the stock plastic rears. Jons car seem to scrub a lot of corner speed from the rear end dumping. I felt the same with my car when I ran the same firm inserts that he ran. I switched to a medium insert earlier and it was smoother with more flow around the corners. Car turned in very well. Never been that good there before. Feels like the front end is getting its mechanical grip. Did not have to brakes .
So on the set-up sheet Paul, you have plastic rear hubs listed. Is this correct and not the AE rear hubs? BTW, nice paint job.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 08-28-2005, 09:18 AM   #10780
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Lookin' good PW.
A little more work with that setup at SoCal, maybe mess with the inserts like Donny said, I think it'll be strapped there.
Jon Kerr is offline   Reply With Quote
Old 08-28-2005, 10:10 AM   #10781
RKeasler's Avatar
Originally Posted by Jon Kerr
Lookin' good PW.
I need a little help on setup guys. I can run times that are up to 4/10s per lap faster with these old 32s (first 2 pics) than I can with a fresher set of RP30/C27s (3rd pic) I know that the heat makes a difference track was 140 or so. But others at my track run fast times on the C27s so it's not just that. My question is what do I need to do to my setup to free it up the way the old 32s do.
Rod
Schumacher Corner-picture-121.jpg   Schumacher Corner-picture-120.jpg   Schumacher Corner-picture-119.jpg
ClemsonTigers
USVTA # 224
ERC
Old 08-28-2005, 10:19 AM   #10782
Jon Kerr's Avatar
Rod
Yes. New holes in the carpet tower. The differences are they are lower so the upper shock location is lower. All the upper mounts are in different spots giving some different shock geometries, and the comber link locations are different.
Old 08-28-2005, 10:20 AM   #10783
Jon Kerr's Avatar
Rod
Need to see the setup first.
Old 08-28-2005, 10:22 AM   #10784
RKeasler's Avatar
Jon I will email it to you.
Rod
ClemsonTigers
USVTA # 224
ERC
Old 08-28-2005, 10:25 AM   #10785
tc3 racer sc's Avatar
Rod
rodney call me 8032898183 reggie i will be waiting
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
