Old 08-22-2005, 10:10 AM   #10711
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
There's lot's of us here for you anytime you need help with the car or anything.
As far as the BMI chassis, I'm liking it a lot. If you're running asphalt, you'll want to get the flex top deck. It'll yield more grip than the solid deck. The solid top deck is more for carpet. The car seems to react a little quicker and with everything moved so close to the centerline, it transitions very quickly from left to right.
Jon Kerr is offline   Reply With Quote
Old 08-22-2005, 10:58 AM   #10712
Scho's Avatar
Send a message via MSN to Scho
Seems wallis and Schumacher are no longer a team
Scho is offline   Reply With Quote
Old 08-22-2005, 11:12 AM   #10713
AdrianM's Avatar
Scho - Yup..he will be running another Nitro Sedan, Mugen I think, as Schu will not be updating the R12 anytime soon.
Adrian Martinez
Old 08-23-2005, 02:59 AM   #10714
Cole Trickle's Avatar
My MI2 shold arrive within a week, hopfully it's a matter of a few days I'm really looking forward to this, I've been attracted by the Mission, since the first version hit the streets
I've been recommended to mount some washers somewhere in the steering, to reduce steering travel, thus improving the durability. Seaball explained it quite detailed with words, however, I would appreciate, if someone is able to post a picture of it.
Also, I'm considering the riser plates. Is I'm correct, when I think they'll alter the roll center?
I've ordered extra A-arms, the spur gear adapter and steel CVD's for the front. I'll also get the castor blocks. Depending on handling on my track (tight, carpet, rubber tires), I'll also get the front one-way.
I've found a setup, which seems to fit my needs.
Can you guys recommend a nice front bumper?
Anything else, I should consider at this point?
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 08-23-2005, 03:47 AM   #10715
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
colo tamiya shocks will be nice. A spool,bmi chassie that you can get later.p-dub bumper is one of the out there! good luck.
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 08-23-2005, 03:53 AM   #10716
A Ilievski's Avatar
Trader Rating: 39 (100%+)
get the BMI chassis with solid top deck, some trf shocks and then get lower shock towers. and for a bumber get the P-Bud bumper its ment to be much better
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 08-23-2005, 04:08 AM   #10717
This car is a about to gain most laps for the money. Stuff like castor blocks, can give a lot for a few bucks.
However, I consider shocks as a nice to have, definately not a need to have. I might be wrong here, but I dont believe upgrading the shocks will give me an extra lap during five minutes.
Chassis parts use to be expensive around here, so I'll wait with that, till I've tried the car. If the stock chassis is good enough for me, I wont shell out the money for the BMI.
However, the bumper you guys mention is very interesting. Where can I find it.
Thanks for your replies.
Old 08-23-2005, 04:40 AM   #10718
Super Moderator
Tony Rivas's Avatar
here the bumper link-http://www.pdubracing.com/
Old 08-23-2005, 05:05 AM   #10719
Not the only person, Schumacher don't realise what the R12 could be capable off with the right support to the product
Hot Bodies D8
Hot Bodies D8T
tao3 is offline   Reply With Quote
Old 08-23-2005, 05:51 AM   #10720
Great, thanks.
Old 08-23-2005, 04:22 PM   #10721
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Default ANTIDIVE
OK guys talk to me about what this actually does on the car. The manual says it makes steering more aggressive entering turns seems just the opposite( bench racing)...PW,Jon????
ClemsonTigers
USVTA # 224
Team C Racing USA / TC 10 2015
ERC
RKeasler is offline   Reply With Quote
Old 08-23-2005, 04:46 PM   #10722
Jon Kerr's Avatar
I haven't worked with anti-dive but the way I understand it works is similar to less caster. When the tires are initially turned, with anti dive, or less caster, the tires are more straight up and down and you get more foot print on the surface. Once the car starts to roll over more, the tires will lean to the outside and you'll loose some of the contact patch. So you'll get a more aggressive turn in and less steering from the middle out. The opposite is true with kick up and/or more caster. Less aggressive on entry because when the tires turn, you have more initial lean and less of the foot print on the track. As the car rolls over, the tire will straighten up and you'll get more contact patch.
PW-correct me if I'm wrong but that's the way I've always understood it.
Old 08-23-2005, 06:29 PM   #10723
mo
mo's Avatar
Anti-dive gives more on-power steering, less initial.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 08-23-2005, 07:45 PM   #10724
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
jon, would'nt Pro-dive ? Give you less effective Castor.... I get confused sometimes...
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 08-23-2005, 08:30 PM   #10725
Jon Kerr's Avatar
Pro dive?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
