Old 08-17-2005, 07:25 PM   #10681
Iain's Avatar
Originally Posted by AdrianM
Since the shims are available in 7 colors and 7 sizes some industrious racers are color coding the sizes
Either that or we were out if that particular size in Purple when Jon ordered them...lol!
Yeah I thought of that when I bought my shims, but I've got a pair of calipers. And I didn't think it would've looked very good, with the other colours.
Turns out I was right!!!!
Iain is offline   Reply With Quote
Old 08-17-2005, 07:30 PM   #10682
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Yes, Donny was the one who came up with the outdrive savers.
And yes Adrian is right, I started ordering my shims color coded.
Jon Kerr is offline   Reply With Quote
Old 08-18-2005, 07:52 AM   #10683
where do you order them shims from i need some 1mm ones, as mine are just under a 1mm, one other thing i had to rebuild my front diff in a hurry and i lost the circlip bushing (spacer) can i get these?? thanks bob
bob33 is offline   Reply With Quote
Old 08-18-2005, 08:21 AM   #10684
Jon Kerr's Avatar
You can order them directly from Schumacher or if your local shop carries Schumacher products, they can order them for you.
Old 08-18-2005, 01:12 PM   #10685
thanks jon, what section do they come under on the shui web site in the mi2 bit if u no what i mean? i cant find them. thanks bob
Old 08-18-2005, 01:31 PM   #10686
Jon Kerr's Avatar
Go to the product finder and type in "washer" and select Take Off as the manufacturer.
Old 08-18-2005, 01:37 PM   #10687
right ok thanks for that jon
Old 08-18-2005, 02:34 PM   #10688
Jon Kerr's Avatar
Any time.
Old 08-18-2005, 06:33 PM   #10689
IslandBwoy's Avatar
Let me submit my stupid question for the day:
How does the out drive savers, save the out drives
IslandBwoy is offline   Reply With Quote
Old 08-18-2005, 08:28 PM   #10690
Jon Kerr's Avatar
Not a stupid question at all. When you run a spool, the out drive wants to spread out in an impact. These outdrives don't really bend when that happens, they snap. The savers keep that from happening as easily. They're really easy to make. Take four old outdrive bearings, use a cutting wheel and cut the outer race off. The inner race will pop right out. Then when you install the spool, after you put your bearings on, slide the save over the outdrive, butt it against the bearing and put just a little drop of CA to hold it in place. (knock on wood) I haven't broke an outdrive yet.
Old 08-19-2005, 04:00 AM   #10691
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Originally Posted by Jon Kerr
This should explain it
Lets see if I have this right, you use a 1.5mm spacer for low roll center in place of the stock piece to lower the arms front and rear, now to get kickup you put ?mm spacer to raise front of arms up is this correct? If so what size is good .5mm for kickup? I am going to 2 degree caster blocks and may want a little kickup as well as a little antisquat in rear. Let me know if I am understanding this car better or not.
Rod
ClemsonTigers
Team C Racing
TC10
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 08-19-2005, 05:59 AM   #10692
one other thing i had to rebuild my front diff in a hurry and i lost the circlip bushing (spacer) can i get these?? if you dont no what i mean i will have to try and explain better thanks bob
Old 08-19-2005, 06:46 AM   #10693
Jon Kerr's Avatar
Rod
Yes, you have the idea. I have 1mm spacers under there though to get more steering. PW posted earlier that raising the pivot block 1mm for anti-squat gives 1.77 of anti squat. The same should be true for kickup. I would start with a 1.5mm shim for the front block and 1mm for the back block for kick up and work from there. That's one adjustment I haven't tried on this car yet. I've always just run the 4 caster blocks. Let us know how it works.
Old 08-19-2005, 06:48 AM   #10694
Jon Kerr's Avatar
You can get the Pro Diff Rebuild kit part# U2629. If it's the part I think you're talking about, it should be in there.
Old 08-19-2005, 06:49 AM   #10695
STLNLST's Avatar
Trader Rating: 19 (100%+)
Rod
Most of us have been using a 1mm spacer rather than a 1.5 On my current set up I have a 1mm spacer in the front and a 1.5mm spacer in the rear of the front arms to give the car .5mm of antidive. This worked killer at the parking lot track that I was at last weekend. I plan on trying it at the regular race track for the regionals coming up.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
