Old 08-13-2005, 10:03 AM   #10621
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Are the steel CVD bones available seperately? I looked on the website but I want to make sure I have the right part number.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 08-13-2005, 10:54 AM   #10622
AdrianM's Avatar
Originally Posted by STLNLST
I believe that the cells are in and to the rear in the Teemu chassis. I haven't run mine in a while so I don't really remember how the car felt with it. I mainly run my batteries middle and in.
On the Teemu Chassis the cells are 1.5mm forward of the stock chassis rear position. The BMI is 3mm further forward than that. On asphalt both are very good. Of Rubber tire carpet the Teemu chassis is better but on foam tire carpet the BMI is better. This has to do with weight transfer. The Teemu chassis transfers more weight on to off throttle.
Adrian Martinez
Old 08-13-2005, 12:53 PM   #10623
rbboy's Avatar
Send a message via MSN to rbboy Send a message via Yahoo to rbboy
any news if teemu will be racing at the International Indoor Championships (IIC) September 21-25, 2005 in the world famous city of LAS VEGAS???
www.xtremerchobbiesph.net
rbboy is offline   Reply With Quote
Old 08-13-2005, 03:06 PM   #10624
P-DUB's Avatar
Yes, Teemu will be there running in both Modified classes (foam & rubber)
Larry Pryor
P-DUB is offline   Reply With Quote
Old 08-13-2005, 03:16 PM   #10625
protc3's Avatar
hey paul,did the brown truck ever show?
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 08-13-2005, 03:21 PM   #10626
P-DUB's Avatar
Yeah, but no BMI packages
Larry Pryor
Old 08-13-2005, 03:43 PM   #10627
mo
mo's Avatar
Hey Jason. Anything new planned for the Mi2 for carpet? Maybe a super stiff top deck?
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 08-13-2005, 06:23 PM   #10628
AdrianM's Avatar
Schumacher has provided stiff top decks to its team drivers in the past. We are asking that they make this top deck a production part this fall. BMI also makes a solid top deck for the Mi2.
Adrian Martinez
Old 08-13-2005, 06:46 PM   #10629
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Default Anti squat
When I put in spacers for it how do you decide what your anti-squat actually is? For instance a spacer that is 1 mm. would be ...?
Rod
ClemsonTigers
USVTA # 224
Team C Racing USA / TC 10 2015
ERC
RKeasler is offline   Reply With Quote
Old 08-13-2005, 06:53 PM   #10630
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I usually just think of it as 1mm anti squat. If you have a setup station you can check it. If I remember right, 1mm anti-squat is a little over 1 last time I checked it with the setup gauges.
Jon Kerr is offline   Reply With Quote
Old 08-13-2005, 07:04 PM   #10631
P-DUB's Avatar
If I remember correctly, 1mm spacer = 1.77 deg
Larry Pryor
Old 08-13-2005, 07:15 PM   #10632
Jon Kerr's Avatar
p-dub's right. I had just checked it on my car when he posted. Too quick, as usual
Old 08-13-2005, 07:27 PM   #10633
RKeasler's Avatar
Jon I had to use Losi springs today (got them to work) the car had a push but I figured it out after I broke the stupid plastic bones(ended my day) but that was my fault (Spool). Gots to get my hopups but I was running just as fast as my XXX-S I have had 4 years, and the car is nowhere near as good as it will be. Buying a whole set of Xray springs for 25.00!!!! Need one of those P-Dub bumpers!
Rod
ClemsonTigers
USVTA # 224
ERC
Old 08-13-2005, 08:20 PM   #10634
Jon Kerr's Avatar
Get yourself a p-dub bumper for sure. The X-ray springs aren't all that necessary.And no, they're not cheap either. You can achieve pretty much the same thing with AE Blue's in front and Silvers in the rear. The new Schumacher springs that are the right length for TRF shocks are also good. Many guys are using the blue in front and white in the rear. There's a really good article in XRC Magazine a few months back where they used a spring dyno to get the actual spring rates for springs from different companies. It'll allow you to compare much better than going by what they label them as.
Old 08-13-2005, 08:23 PM   #10635
Jon Kerr's Avatar
I'll be running rubber mod and 19 turn in Vegas. I'm planning on actually having two cars there. One BMI car and one Teemu. This way I'll have the chance to try out both and see what one I like on the rug.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
