Old 08-11-2005, 01:23 AM   #10606
A Ilievski's Avatar
Trader Rating: 39 (100%+)
go to metrohobbies.com.au i think thats the site they are located in melbourn
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 08-11-2005, 05:43 AM   #10607
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Default Carpet towers
I don't have these yet how important are they if the setup I am putting on the car calls for them? Using Jon Kerr's setup from the Tamiya track to start.
ClemsonTigers
USVTA # 224
Team C Racing USA / TC 10 2015
ERC
RKeasler is offline   Reply With Quote
Old 08-11-2005, 06:45 AM   #10608
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
The biggest reason for using the carpet towers i so you can use the TRF shocks. If you don't have them go a head and run the stock ones with the stock shocks and make sure you use the same shock mounting holes. Also on the camber links on the front, I think the stock tower only has 4 mounting holes instead of the 6 that the carpet have. Use the top row, inside hole for the front.
That setup I sent you was what I usually run outdoors. It actually didn't work well at Tamiya at all but it has worked everywhere else I've run it. Let me know how it works and if you need any help with it.
Jon Kerr is offline   Reply With Quote
Old 08-11-2005, 06:55 AM   #10609
Actually, the stock front tower shock holes are very different from the carpet tower. Rear was almost the same, but front was waayy different... one had outer hole almost in the same location where the other had inner hole. Of course I can't remember by heart which way they were... I think the carpet tower had front shocks more laid down.
olev is offline   Reply With Quote
Old 08-11-2005, 07:37 AM   #10610
Jon Kerr's Avatar
I know they're a bit different, what I should have said was make sure you use the closest corresponding upper mount. The best thing though would be to use the carpet towers when you can get a hold of them. Sorry for the confusion.
Old 08-11-2005, 01:03 PM   #10611
lmunno's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to lmunno
Originally Posted by cornerspeed
See if these pictures are more clear.
Don, Are you using the macro mode for the close ups? It should be used for anything 12" or less from the camera - it is usually marked with something that looks like a flower.
lmunno is offline   Reply With Quote
Old 08-11-2005, 04:58 PM   #10612
cornerspeed's Avatar
No I wasn't. Didn't know about that. Will try that next time, thanks.
Got the chassis on Friday. Thanks.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 08-12-2005, 04:22 AM   #10613
Yup, I was sure _you_ knew that, but not so sure about the guy you tried to help
I just looked at them last night @ home and the outmost hole on carpet tower is somewhere between inner and middle hole on stock tower. Middle and inner holes on carpet tower are obviously more laid down than the stock tower permits.
Of course, you could always drill 1-2 more holes to the stock tower, if you have the tools and want more laid down front shocks...
Old 08-12-2005, 06:04 AM   #10614
A Ilievski's Avatar
hey guys what pitch is the mi2 spur gear
Alex Ilievski
Old 08-12-2005, 06:09 AM   #10615
its 48dp for the shui ones.
bob33 is offline   Reply With Quote
Old 08-12-2005, 05:54 PM   #10616
RKeasler's Avatar
Default Roll centers
If I run the low roll centers in front by removing the riser is there anything else I need to do? Saw an old setup by PW that said must use straps across front mounts I do not have the carpet towers.
ClemsonTigers
USVTA # 224
ERC
Old 08-12-2005, 06:39 PM   #10617
P-DUB's Avatar
If you remove the lower plate, you must replace the plate with 1.5mm or the Schumacher black 1.6mm plastic spacers. If running a 2mm chassis, you want to have a strap on top of the front suspension mounts.
Larry Pryor
P-DUB is offline   Reply With Quote
Old 08-12-2005, 09:10 PM   #10618
RKeasler's Avatar
I guess the first time out I will run with the plates in. I see what you are saying need more spacers
Rod
ClemsonTigers
USVTA # 224
ERC
Old 08-13-2005, 05:51 AM   #10619
Iain's Avatar
Default New Chassis and Parts
I spent all day today swapping chassis' over, because I got my Teemu chassis (And other parts) from the US, (Big thanks to AdrianM for his assistance with that )
I've also installed my low towers, Tamiya shocks, alloy pivot blocks and Titanium screw kit, turnbuckles and hingepins so at racing tomorrow I think the car will feel like completely different to what I've had.
But I'm really looking forward to getting it dialed in and seeing how she goes!!
Is there anything I should expect that will really feel different with the Teemu chassis compared to the stock one?
Also, what are the position of the cells in the Teemu?? Inside middle??
Iain
Iain is offline   Reply With Quote
Old 08-13-2005, 08:07 AM   #10620
STLNLST's Avatar
Trader Rating: 21 (100%+)
Iain
I believe that the cells are in and to the rear in the Teemu chassis. I haven't run mine in a while so I don't really remember how the car felt with it. I mainly run my batteries middle and in.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
