Old 08-09-2005, 12:08 PM   #10591
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Default Spool
Got my Mi (thanks DS) and I see in the instructions that to make a solid diff just take out the diff balls, question is do I put in sandpaper like the Losi or just take the balls out?
ClemsonTigers
USVTA # 224
ERC
RKeasler is online now   Reply With Quote
Old 08-09-2005, 12:12 PM   #10592
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
take the diff apart. Take the diff rings,and glue them to a piece of "Header Card" then carefully cut them out, so now you have a diff ring with a cardboard ring glued to the side of it. Reassemble the diff without the diff balls and the carboard rings facing in, and you should be all set.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 08-09-2005, 12:35 PM   #10593
PW
PW's Avatar
Send a message via AIM to PW
The Losi method will work perfect
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 08-09-2005, 01:17 PM   #10594
Regional Moderator
Racer_Chick's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Racer_Chick Send a message via MSN to Racer_Chick
Thanks guys!
Adrian - I'm running the Teemu chassis right now with the standard top deck. I'm just waiting until Jason cuts some of the titanium colored ones. I'll talk to him and see which top deck he was going to send down, but at any rate, I do have the standard one incase I get the solid one with the chassis. Thanks for the tip
Toni Green|Munno Graffix|CFX Racing
Кто глупее? Дурак или дурак, который следует за ним?
Racer_Chick is offline   Reply With Quote
Old 08-09-2005, 01:42 PM   #10595
AdrianM's Avatar
Bring your car by our pits early this Sunday and I will go through it really fast so you can get as current a setup as possible.
Adrian Martinez
Old 08-09-2005, 04:12 PM   #10596
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
nice!!!!!! toni
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 08-09-2005, 05:45 PM   #10597
Regional Moderator
Adrian - just talked to Jason and he said he's cutting the narrow deck for me and I'll still have the standard one to switch between if I need it. I'll be sure to stop over Sunday morning and thanks!!
Thanks Tony!
Old 08-09-2005, 06:19 PM   #10598
Super Moderator
Tony Rivas's Avatar
I cant go this sunday but I will go to the next race at speedline
Old 08-10-2005, 04:19 AM   #10599
RKeasler's Avatar
Any quick tips on getting the diffs out looks like a BEAR to me.
ClemsonTigers
USVTA # 224
ERC
Old 08-10-2005, 05:17 AM   #10600
Front diff comes out quite easily (I hope I don't forget anything):
-undo the lower shock ball grippas and upper arm ball grippas. Also swaybar bones, if used
-remove 4 shock tower screws, shock tower drops off
-undo all 4 bolts that go into the diff mounts from above ( 2 upper deck, 2 bumper)
-undo 6 screws from underside of chassis (4 diff mounts, 2 bumper). Leave the screws of the lower (plastic) diff mount parts.
-bumper and diff mounts pretty much fall out by themselves. Now just take the diff out. You might hava to bend the upper deck slightly upwards to make things easier.
Installation is reverse of removal Get the driveaxles and belt in place when you put the diff in. All this takes 10 minutes max. Sure, it's harder than removing "quick-access" diffs found on some nitro cars, but still, it's nothing big.
Rear diff access is similar, but you also have to remove the upper deck rear screws that go to layshaft mount and motor mount.
olev is offline   Reply With Quote
Old 08-10-2005, 05:26 AM   #10601
RKeasler's Avatar
Thanks, I am going with the spool up front so the rear I can leave for now.
ClemsonTigers
USVTA # 224
ERC
Old 08-10-2005, 10:34 PM   #10602
cornerspeed's Avatar
Just figured how to do all this digital camera, attaching stuff. Took me about 3 hours to figure it all out.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 08-10-2005, 10:37 PM   #10603
Wow, guess I need to step up the quality of the picture a little. Lowered it so it would upload on manage attachments. I guess. Thanks for the help Jon. You gave me a little clue to do this.
Donny Vinkemulder
TLR Driver
Old 08-10-2005, 10:43 PM   #10604
See if these pictures are more clear.
Donny Vinkemulder
TLR Driver
Old 08-10-2005, 11:09 PM   #10605
WRXTC's Avatar
I am in Australia and have a Mission S1. It's my first serious RC car. I just got into RC and picked up the kit cheap. I want to add some Alloy Diff mounts. They are cheaper online than at the hobby shop problem is Schumacher USA are cheaper than Schumacher UK and the USA don't send to Australia. Is there anywhere else online I can purchase Schumacher parts?
WRXTC is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
