Old 08-04-2005, 01:13 PM   #10561
bender's Avatar
I don't think you're wrong, but it seems wherever you gain in one area you often lose somewhere else.
The narrower rear diff reduces transmission rotating mass, but on the other hand running the belt over a larger diameter pulley (standard set-up) is more efficient than a smaller (layshaft) pulley - so the question is which combination works out better?
I agree that there may be a small amount of "lag" with front diff spool-up time, but, it's the rear that does most of the acceleration under power and the drive to the rear diff is the same as other belt drives.
By running this more conventional layout we might find that the car has a little more rip out of corners, but this may be at the expense of slightly less overall efficiency than the current set-up.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 08-04-2005, 02:32 PM   #10562
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Originally Posted by xxxkat
For carpet what would be "the" hop ups that you need,Stock/19,rubber tires.What is wrong with the belt system that is on the Mi2 now?? If you like the belt system that teemu was testing you can get one now..It's called a Yokomo BD/415/Xray.. I have no problem with the curent belt system it seems as free if not more than the 415's and Xrays.
A one-way and some steel front driveshafts. A gear adapter if you want to go to 64p. Gearchart.com has Mo and STLNLST carpet setups for rubber tire. If Norcal ends up switching to foams for all classes, scrub the one-way and order some BMI shock towers.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 08-04-2005, 07:08 PM   #10563
Oasis's Avatar
Trader Rating: 36 (100%+)
The carpet track i race at I own..so rubber tires for stock it is.. (jk)I'm with Ruben on "it's what the racers want".I have the Teemu chassis and the carpet towers and the steel cvd's and the tamiya shocks,I guess i should get the one way.On the belt system I still think the stock system works great,I have way more "rip" corner to corner with my Mi2 than with my Tech or 415 and both the tech and 415 use the "short" belt.I guess if you think the belt system for the Mi2 is "slow" get another car..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 08-05-2005, 07:44 PM   #10564
Iain's Avatar
TTT
Iain is offline   Reply With Quote
Old 08-05-2005, 07:48 PM   #10565
Trader Rating: 239 (99%+)
Hey guys just wanted to re-introduce my self. Names Fred Perkins. I am returning to on road racing and Schumacher. I'll have my old MI2 (tracked it down from england back to the USA, lucky I found it!!) in about 3 days. I am going to Frederick Maryland for some testing next Sat and again on the 19th and 20th for there trophy race. Any setup help would be appreciated so that I have some where to start.
Fred
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 08-06-2005, 02:06 AM   #10566
Oasis's Avatar
Has anyone else broken the saver arm.. Car was on rails got hit by a back marker and ..only spare part I dont have..
Old 08-06-2005, 07:58 AM   #10567
Yep, I broke about six of them in a three week span on carpet with foams. Then out of desperation at the track (due to lack of replacement parts) I found something that worked and am running it ever since.
Jim
Fantom, BL Racing, Retired
jimnew is offline   Reply With Quote
Old 08-06-2005, 09:57 AM   #10568
Oasis's Avatar
That would be a TC3 steering rack?? How did you mount your servo,I'm using the Teemu chassis and I'm not sure if i have enough room to mount the servo.
Old 08-06-2005, 12:42 PM   #10569
AN
(How much) Will the grip level reduce if I change from standard wishbones to c/f wishbones?
AN is offline   Reply With Quote
Old 08-06-2005, 12:54 PM   #10570
Wirre's Avatar
Doubt you'll really notice it, I gained a little consistency in the car after the switch...and that's probably the way to go.
Nice to see another Swede in the forum by the way ;-)
Kyosho Ultima RB-5 SP
Kyosho Ultima RT-5
Kyosho Lazer ZX-5 FS
Orion Vortex Motors and ESC
Wirre is offline   Reply With Quote
Old 08-06-2005, 06:09 PM   #10571
Regional Moderator
Racer_Chick's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Racer_Chick Send a message via MSN to Racer_Chick
Hey Paul, what should we do for gearing on this?
Toni Green|Munno Graffix|CFX Racing
Кто глупее? Дурак или дурак, который следует за ним?
Racer_Chick is offline   Reply With Quote
Old 08-06-2005, 07:25 PM   #10572
ottoman's Avatar
Jim
I saw Jim break most of those arms with my own eyes... it was the weirdest thing.... almost funny ... just the slightest brush on a wall or another car would snap the steering arm... while we could hit all kinds of things with our MI2 and not break. Never did figure out why his car broke all those arms but Jim did a great job changing over to a TC3 rack at the track and only missed one qualifier
ottoman is offline   Reply With Quote
Old 08-06-2005, 07:44 PM   #10573
Jack Smash's Avatar
Mo and I each broke one during the Speedworld Cup. We were both on the stand during practice, I tapped a board, *snap*, a lap or two later and he tapped a board, *snap*.
Old 08-06-2005, 07:49 PM   #10574
mo
mo's Avatar
Those were both over a year old parts though. Generally if you are breaking a lot of those arms or bellcranks, you may have the servo saver set a little too tight. Back off the spring tension a little and it should be ok.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 08-06-2005, 10:15 PM   #10575
AdrianM's Avatar
Jim
I think I remember you calling in about this. You had us really stumped as no one else is really breaking those. We ran a report that showed US usage of those part and it was really low.
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
