Old 07-28-2005, 02:47 PM   #10456
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by bob33
will the shui ally pully be as good as the RW one? as in will it have little slop? thanks bob
The alloy pulley will have slightly more slop than the RW, but will last pretty much for the life of your car.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 07-28-2005, 02:49 PM   #10457
right thanks i will see what i can get then. thanks bob
bob33 is offline   Reply With Quote
Old 07-28-2005, 06:18 PM   #10458
King-G's Avatar
Send a message via ICQ to King-G
Good Luck to the Schumacher team at the Euro's this weekend.
Go Teemu!
King-G is offline   Reply With Quote
Old 07-30-2005, 11:11 AM   #10459
STLNLST's Avatar
Trader Rating: 19 (100%+)
TTT
To The Top (for the new cats)
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-30-2005, 10:00 PM   #10460
mini-dub's Avatar
Trader Rating: 16 (100%+)
Here are some pics of a fan mount that I made from a broken CF battery tray. The mount is drilled for 2 fans, although I only have one right now. Charlie did you get my email . I added a separate switch for the fans and put a plug between the wires soldered to the ESC and the fan so I can remove the mount and fans while wrenching, or some other reason...
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 07-31-2005, 04:13 AM   #10461
IslandBwoy's Avatar
Nice car. Was wondering if there would happen to be a pre-fabricated fan mount for the mi2. I guess not though as you made your own.
Secondly, if I wanted to replace all the screws on the bottome of my chassy so that it sits perfectly flat what part number should i refer to for the screws?
IslandBwoy is offline   Reply With Quote
Old 07-31-2005, 04:20 AM   #10462
A Ilievski's Avatar
Trader Rating: 39 (100%+)
hi guys i wana change all my screws on my mi2 is it possible just to get them on there own.
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is offline   Reply With Quote
Old 07-31-2005, 09:12 AM   #10463
mini-dub's Avatar
R/C Innovations makes fan mounts for lots of cars, I think they're kinda expensive so that's why I just made my own. Go to http://coolcan.usmanbiz.com/pages/schumacher.htm for the Mi2 mount.
I really like the Titanium Racing screw kits, I've only stripped like 2 of the screws ever and I've been using them for a long time. They're expensive though...
TNM8532 - TiR Ti screw kit Mi2
TNM8532B - TiR Ti screw kit bottom Mi2
TNM8532T - TiR Ti screw kit top Mi2
R/C Screws makes some nice stainless screw kits that much cheaper. One thing to keep in mind is that with the stock 2mm chassis since the countersunk holes arn't that deep the screws might stick out a tiny bit even with the TiR ones. A thicker chassis such as the Teemu chassis or BMI ones helps, too. I have a 2.5mm chassis and TiR screws and it's perfectly flat.
Old 07-31-2005, 09:50 AM   #10464
rbboy's Avatar
Send a message via MSN to rbboy Send a message via Yahoo to rbboy
nice!!! just a question... wont the magnets of the motor can affect the fan? whats the measurement would you know?
www.xtremerchobbiesph.net
rbboy is offline   Reply With Quote
Old 07-31-2005, 12:10 PM   #10465
Good showing for Schumacher at the Summer Sizzler hosted by Scotty Ernst and Trackside Hobbies. With over 90 entries it was one intense day of racing. Here is a quick rundown of the finishes for Schumacher that I remember:
Chris Goetz(Seaball) Qualified 4th in stock foam and 6th in 19turn, don't know the finishes as the mains were pretty wild. He definitly had his MI-2 flying by the end of the day.
Nick Stampfel (Ottoman) Qualified 5th in Modified Foam, but unfortunatly broke in the main. His car was wicked fast but just could not find the balance he needed
James Newberg (Me) Qualified 2nd in stock rubber and won the A-Main. Car was good early in the day, but developed an entry push suddenly for the main.
Here is a short list of the drivers that were there, to make this one hell of an event:
Brian Jucha
Brad Johnson
Jeff Cuffs
Stephen Sobottka
Eli Ezrow
Mo Denton
Andrew Ellis
Chris Goetz
Later
Jim
P.S. For all you guys going to Vegas and running rubber tire classes, the handout tire is the CS-27
Fantom, BL Racing, Retired
jimnew is offline   Reply With Quote
Old 07-31-2005, 12:16 PM   #10466
bender's Avatar
Thumbs up
Congratulations to teemu Leino who has just won the Euro's
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 07-31-2005, 12:36 PM   #10467
IslandBwoy's Avatar
Thanks mini-deb. Way to go Teemu.
Old 07-31-2005, 12:41 PM   #10468
PW
PW's Avatar
Congrats to Team Schumacher and Teemu Leino!!!!!!!! Most impressive drive and well earn win for Teemu
Paul Wynn
Old 07-31-2005, 01:07 PM   #10469
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Excellent run for Teemu and all the guys running at Trackside.
Jon Kerr is offline   Reply With Quote
Old 07-31-2005, 01:40 PM   #10470
Send a message via ICQ to piorc
Default New bearings
Hi guys, i just need new bearings to my mi2, so what brand do u recommend??
and do u use ceramic or metal??
Another question, what hop ups do u use on mi2?
Thanks a lot.
Marcelo
piorc is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
