Old 07-28-2005, 12:22 PM   #10441
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by bob33
talking of pullys
if i turn my spur gear and hold the pully i can turn the spur alot (not quite a qutter) befor it gets a "grip" what do i need to stop this?? if i get the alloy pully will that solve the problem?
thanks bob
The RW pulley (part # rw1000) will do the trick http://www.racing-cars.com/usa/searc...&templateid=12
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 07-28-2005, 12:23 PM   #10442
AdrianM's Avatar
Yes, over time and with crashed the stocl pulley slot can get opened up and cause what is happening to you.
U2460 - 20T Alloy Pully will stop that forever
RW1000 - 20T Machined Acytel Plastic will also end your problem.
Adrian Martinez
Old 07-28-2005, 12:27 PM   #10443
thanks alot u 2 i will get 1 orderd soon. thanks bob
bob33 is offline   Reply With Quote
Old 07-28-2005, 12:28 PM   #10444
PW
PW's Avatar
bob....Go with the RW
Paul Wynn
Old 07-28-2005, 12:32 PM   #10445
right wer can i get one of them from in the uk?? is the rw 1 alot beter?
Old 07-28-2005, 12:45 PM   #10446
PW
PW's Avatar
RW Racing is actually a UK company Click here to contact them directly http://www.rwracing.co.uk/Contacts.htm
Paul Wynn
Old 07-28-2005, 12:49 PM   #10447
oh i see lol. ok thanks i will look into that then
Old 07-28-2005, 12:58 PM   #10448
mini-dub's Avatar
Trader Rating: 16 (100%+)
If you have the stock spur gear there could be the same problem with the roll pin slot being enlarged, replacing the spur with the alloy spur adaptor solves just about all the slop on that connection forever.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 07-28-2005, 01:09 PM   #10449
i cant find them pully on the rw website. i will have to swap to the ally gear adapter then, do u use the RW spurs on them ??? thanks bob
Old 07-28-2005, 01:13 PM   #10450
Send a message via ICQ to MattW
Bob, the RW pullies aren't all that common in the UK, although they are available. I have them on my cars. What i had to do though, was get a shop that deals with RW to special order them for me as i'm not aware of anywhere that keeps them in stock.
MattW is offline   Reply With Quote
Old 07-28-2005, 01:23 PM   #10451
right ok i might just go with the shui ally 1 but get the gear addapter as well. thanks 4 the help. bob
Old 07-28-2005, 01:24 PM   #10452
mini-dub's Avatar
The aluminum spur adaptor fits RW spurs perfectly.
Old 07-28-2005, 03:38 PM   #10453
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I use the aluminum spur adapter, RW Spur gears and the RW machined pulley and there's little to no slop in there.
Jon Kerr is offline   Reply With Quote
Old 07-28-2005, 03:44 PM   #10454
will the shui ally pully be as good as the RW one? as in will it have little slop? thanks bob
Old 07-28-2005, 03:47 PM   #10455
AdrianM's Avatar
The RW has no play in the pulley at all. The alloy one has a little. Its not an issue at all though. This play has no effect on the car on the track.
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
