Schumacher Corner
Has anyone used the Cool Can mount for fans ? And what are your opinions on best location for optimum cooling ?
Originally Posted by Iain
I thought the raised transmission was purely to make the transmission more efficient, by allowing the dogbones to sit level instead of being angled down or is that the Teemu Towers?
Are the Teemu tower's (U2787) that have to be used with the Teemu Riser's the same as the low towers (U2714 and U2715) or are they slightly different (Say for low grip?)?? What about the BMI towers? Are they the same as the low towers, but with the body post mounts on them??
Also, with the 3700 Teemu Chassis, is there any problem using 3300's in it, they don't sit too low or anything?? As I still have a few 3300's left to use but imagine in not too long will have all 3700's?
Iain
Iain
The Teemu towers have all the holes moved down 2mm to compensate for the diff riser plates.
The 3300's fit in 3700 slots just fine if your cells are not glued together. If they are they will ride a bit higher than the 3700's.
What shells are people using now on a Mission on carpet, tight, on rubber tyres please, so I know what to order.
Thanks in advance, also, is there a good base setting for the mission on carpet/rubber tyres???
i always liked alpha 2.0 on tight tracks
for setups look @ this link : http://www.racing-cars.com/search.as...e1=prodvalue14
For Carpet Rubber tires the Protoform Maxda 6 or Stratus 3.0 All Purpose are the the best.
For Carpet Foam tires the Parma Alfa is the only choice.
Thanks for the Shell advice, I was wondering whether to go for the Mazda 6 or the Strauts 3.0.
As for setups, I been to Schumachers site (my first port of call) and they vary so much, especialy the shock oil.
Originally Posted by AdrianM
The raised drive train increases dogbone plunge into the drive cup and raises the CG for more weight transfer. The increased plunge should reduce on power traction but its effects are minimal. The higher CG make the car roll more for more weight transfer/traction.
Hey Jack have you tried the car out yet or still having gliching problems?
I just got my new set of Schumacher tools. I can't wait to use them. I've got a bunch of wrenching to do tonight to get the car ready for the Hitec race this weekend.
I can't believe these things retail for only $8 each.
I guess I'll just start throwing money at it till I get it straightened out.
Originally Posted by Jack Smash
I ran a loner MI2 with spektrum this weekend with my transmitter. Qualified 5th in 19turn and had the 3rd fastest single lap at a track I have never run at but had to pull off on the first lap of the main, still glitching.
