Old 07-20-2005, 06:35 PM   #10381
P-DUB's Avatar
Set it to 40.8mm outside to outside
Larry Pryor
P-DUB is offline   Reply With Quote
Old 07-20-2005, 09:36 PM   #10382
rbboy's Avatar
Send a message via MSN to rbboy Send a message via Yahoo to rbboy
thanks p-dub! 40.8 it is... would you know what benefit i would get by this setting?
www.xtremerchobbiesph.net
rbboy is offline   Reply With Quote
Old 07-21-2005, 07:59 AM   #10383
korevo's Avatar
Smile
My new Mi2........
korevo is offline   Reply With Quote
Old 07-21-2005, 10:26 AM   #10384
rbboy's Avatar
korevo: you have a bad ass car!!! when are we gonna test it out at the track?
Old 07-22-2005, 02:22 PM   #10385
AdrianM's Avatar
TTT
Adrian Martinez
Old 07-22-2005, 06:09 PM   #10386
IslandBwoy's Avatar
Is there a replacement part for the outdrives on the spool diff?
IslandBwoy is offline   Reply With Quote
Old 07-22-2005, 09:00 PM   #10387
AdrianM's Avatar
The spool is one piece. If it breaks you get another spool. The alloy part is not available separately. If it were it would cost the same as a complete spool. Schumacher pretty much gives away the pulley when you buy a complete spool.
Adrian Martinez
Old 07-23-2005, 05:49 AM   #10388
IslandBwoy's Avatar
k. The one i have is not completely gone yet. Its just that out drives are looking a little busted up. I'll get one soon though. Might as well.
Old 07-23-2005, 07:35 AM   #10389
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
How often are you changing your blades?
Jon Kerr is offline   Reply With Quote
Old 07-23-2005, 04:20 PM   #10390
Default set up
adrianM i ahve folowed your set up that u gave me. just one problem that i am not sure about y it is hapening, on the shocks to get the ride hight (i have up'ed it to 5.5 and 6 mm wer as on the set up sheet its 4.5, 5 mm) and to get the ride hight right i cannot get all the adjusters on the shocks the same on the front left to right and on the back left to right. is this just because the battery side waighs more??
with it being like this the springs are not the lame tention. at the start? and wen off the floor ther not under any preload? can any 1 help. o yeah all the droop is the same its not that btw. thanks alot bob
bob33 is offline   Reply With Quote
Old 07-23-2005, 05:56 PM   #10391
AdrianM's Avatar
This can happen for a couple of reasons.
1. The chassis may be tweaked. The best way to check this is with the blocks from a droop gauge set. Put the blocks on a known, dead flat surface and place the car on the blocks so the chassis is directly on the blocks and not being lifted by any screw heads. The car should sit flat on the blocks. If you push on any corner of the chassis ands hear a tick that corner is curled up. Loosen all the top deck screws and the chassis should flatten out. Tighten them up while pushing down on the top deck and the car should stay flat.
2. Camber differences on the wheels. If you set you car to 1.5deg camber and 5mm ride height then change the camber to 1deg you ride height will increase. If you set ride height first then adjust camber your tweak will be affected. I always set camber first check ride height ands re check camber.
3. The front and rear suspensions are interrelated on all independent suspension cars. If you have a lot of preload on one rear corner you will have an imbalance in the front too. I always screw down the threaded collars all the way and turn them up equal #'s of turns left to right per each end of the car to start setting up a car.
The Mi2 is almost always equal in tweak left to right. My car never needs more than a half turn on any given collar to make it tweak properly on an MIP Tweak station.
Adrian Martinez
Old 07-23-2005, 08:21 PM   #10392
A Ilievski's Avatar
Trader Rating: 39 (100%+)
hey guys whers the cheapest place to gethop ups for the mi2 i found a place here in australia (metro hobbies)
im after the heavy duty one way diff
alloy front and rear hubs
the price for the one way is 110 aus and the hubs was 130 for all 4 is that a good price ?
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 07-23-2005, 08:24 PM   #10393
STLNLST's Avatar
Trader Rating: 21 (100%+)
TQ and a win today at Speedworld for Mo in 19 turn. He was a brave soul that went out in the heat....
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-24-2005, 01:19 AM   #10394
bender's Avatar
Kid,
Try Dave Guyatt (heavy D) at http://www.actionrc.com.au
His prices are cheaper than what you've quoted - though he is in Brisbane so you will have to pay for postage. But I don't think it will be much considering the size and weight of the bits you want.
I have found a big improvement in my car since i switched to Tamiya shocks.
I ran 19T class in our Winter Cup meeting, and whilst i didn't make the A-Main (there was just over a second seperating 6th to 10th), I found myself in 10th place.
I won the B-final in a time that would've put me in the "A" (a little too late ) and the car was working the best it's ever been
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 07-24-2005, 04:49 AM   #10395
IslandBwoy's Avatar
how often do you guys change the blades on your car to keep from eating up the spool?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
