Old 01-10-2002, 10:09 AM   #1021
Send a message via ICQ to JesseT
At least in off-road this "pack" plays a big role in damping. Thick oil with large holes and light oil with small holes giving the same low piston speed damping results in totally different high piston speed damping.
JesseT is offline   Reply With Quote
Old 01-10-2002, 10:37 AM   #1022
Send a message via ICQ to MattW
Chirs, I agree that it seems that the shock needs slowing down, hence thicker oil. I have just been looking at Teemu's setup from last years LRP. with the same rear spring he was running 100wt oil with 1 hole open. makes my 80 wt 2 hole look very under damped!!
MattW is offline   Reply With Quote
Old 01-10-2002, 10:59 AM   #1023
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Matt W....I have had the same problem that you are talking about with my car on carpet with rubber tires. I went down in oil to 50wt or 60wt with 3 hole pistons in the rear this cured this also with the thiner oil I went down in spring as well to a 15lb spring. It felt like the car was just riding around on the spring and never really rotated with 80wt and 2 hole combo. I like the thinner oil and more hole combo better until the grip gets too high.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 01-10-2002, 11:59 AM   #1024
Kevin, What shock mounting position were you using with that set-up??
Old 01-10-2002, 03:41 PM   #1025
Kevin K's Avatar
One out from the inside on the tower and inside on the arm shocks 67mm long.
Old 01-10-2002, 03:58 PM   #1026
Racer X's Avatar
Kevin: The Mission seems to like softer setups. I run alot of rubber on carpet, and it seems like 80 wt is too thick, the silver spring may be too heavy too. Currently I'm running 70wt with yellows in the middle hole on the tower...give it a try
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 01-10-2002, 04:04 PM   #1027
kevin,
i agree with racer-x and the others,,try a softer spring, lighter oil combo...let us know if your still having problems,,
gdcopbadcop is offline   Reply With Quote
Old 01-10-2002, 04:46 PM   #1028
Kevin K's Avatar
Thanks for the helps guys but if you re-read my post you will see that I am now running 50wt oil and light springs. When I first got the car I tried my old setup off the Axis2 and it did not work at all, with the stiff springs and oil. Racer X I still feel that the yellows are too stiff for week to week racing. I race on carpet about 8 months out of the year so I have a tinklin as to whats going on. Reds and Blues feel much better on the track week to week. If there is a lot of traction that day then yellows might be needed but I have yet to see that at a club race.
Old 01-10-2002, 04:51 PM   #1029
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
Anyone here got any setups for foam tyres on asphalt track pretty high grip and warm temperatures?Im presuming Proline purple on front and Proline pink on rear with hard oil, red or yellow springs all round and shocks lent in will be in the ball bark.Oh small piston also with possibility of sway bars.
Oasis2001 is offline   Reply With Quote
Old 01-11-2002, 01:02 AM   #1030
Just for the sake of argument... I run silvers and 100wt on carpet with Take-offs and it goes like on rails. Teemu seems to be fond of the Picco springs that are 40lbs and 50wt oil... go figure...
Drive what ever works for you ;-)
BR/ JesseT
Old 01-11-2002, 02:32 AM   #1031
Cole Trickle's Avatar
I'm running with rubber tires on carpet. Our track got some (maybe 3-6) small bumps. The bumps are in the underlying concrete and where the carpet pieces are connected.
I went from 60 wt/piston 3 (HPI medium) to 80wt/piston 5 (largest HPI). That improved the cars handling of these bumps a lot.
Cole Trickle is offline   Reply With Quote
Old 01-11-2002, 05:57 AM   #1032
Happy to hear. Have you checked if the slow speed damping was increased or decreased. The high speed damping was probably decreased in any way...
Old 01-11-2002, 06:03 PM   #1033
Well..... I got it!!!!!!!! Yes I went to Gaithersburg and it was there!!! too badd she didn't get the hop-ups this morning... but I am getting ready to build my new baby!!!! Also can't wait to paint the new Stratus-fear body too.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-11-2002, 07:45 PM   #1034
tc3driver's Avatar
Send a message via AIM to tc3driver
Congrats IMPACTPLAYR, On what you got ( is it a mission?!?!?!) I bet it is , woo hoo all I can say about it is that it is ROCK STAR!!!!
lates all!
tc3driver is offline   Reply With Quote
Old 01-11-2002, 08:39 PM   #1035
Default HELLO
Just wanted to say Hello!! I have read just about every page on here and have spoke with Adrian and I can HAPPILY say I will be getting a mission soon. I am getting out of offroad and making the move to Electric touring cars. A few of my buddies race them and have A2's. I am totally new to electrics so may have more questions rather than just Mission specific. I have been a nitro guy and I just don't feel like running gas and 1/8th anymore. AS soon as my mugen sells I will be ordering my Mission and all else that I need. Here is the setup I am going to buy...let me know what you think
-Mission
-Keyence Zero Extreme or CS Rocket Max
-Integy 16x9 or 16x5 (not sure which to choose)
-Integy Ocane 2 Discharger (is this good or should I go with Trinity
realtime 2 and Deans bulb tray?????)
-I already have an M8 with rec. and ALOT of servos as my 1/8 liked to eat thenm
- If anyone wants to add to this or comment PLEASE do. I am new and learning so any info is HELPFULL! Thanks!
wilson10 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
