Old 07-08-2005, 07:26 AM   #10246
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I did mess with bump steer quite a bit and it does make a significant difference on the track. Going to bump out did seem to effect the entry more and made it dive into the corner harder under braking.
Jon Kerr is offline   Reply With Quote
Old 07-08-2005, 07:54 AM   #10247
Iain's Avatar
Hey Guy's,
What are the optional chassis' available for the Mi2?? The BMI, the Teemu and is there also another thickness Schumacher Chassis?
And what are the benefits of each?? As my current chassis, has been worn down alot, so am looking to get another. But I do like the adjustable battery position of the original, but I believe the Teemu and BMI are single position's for cells?
Where is a good place to get Schuey stuff from OS? As here in Australia, it's quite expensive and not a lot of people stock the parts??
Iain
Iain is offline   Reply With Quote
Old 07-08-2005, 10:24 AM   #10248
Jon Kerr's Avatar
Originally Posted by Iain
Hey Guy's,
Iain
Optional chassis are the BMI, Teemu, and I believe there's also a 2.5mm adjustable chassis. The BMI is a 2.5 mm chassis. It's much more narrow, it moves the batteries forward and as far to the inside as you can get. Jason also has a couple different top decks available for different applications. I use the high flex top deck since I run on lower grip asphalt mainly. When I go to Vegas to run on the rug, I'll be running the stiffer top deck. I haven't run the Teemu chassis so someone else may be able to fill you in on that chassis.
Old 07-08-2005, 10:44 AM   #10249
Send a message via ICQ to MattW
The Teemu chassis has the cells fixed in the "Back + In" position from the adjustable chassis. It is 2.5mm thick. There is now a 3700 verson of this chassis, i assume the cell position is comparatively the same.
The 2.5 adjustable chassis was never available for sale.
Jon, i do like the look of that "narrow" BMI top deck
Interesting debate on the bump steer adjustment. Haven't tried it, but might be worth looking into, fairly easy to change.
MattW is offline   Reply With Quote
Old 07-08-2005, 03:45 PM   #10250
STLNLST's Avatar
Trader Rating: 21 (100%+)
Just letting you guys know that tomorrow is the day that I'm whippin' up on MO and everyone else running the Revo race....LOL
PW paint job will have some stickers on it!
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-08-2005, 03:56 PM   #10251
Trader Rating: 18 (100%+)
You got some for 19T? Or is it a "no sack" type of thang?
LMAO
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 07-08-2005, 04:31 PM   #10252
Originally Posted by mini-dub
Take out the diff balls. Glue one side of the diff rings with CA to a header card. Then just tighten the diff/spool down so it cant spin unless you hit something really hard. Don't over tighten it with a steel screw or you can break the screw (I did that the first time I built a spool) and its a pain to get the broken screw out.
-Weylin
Just curious how much of the card do you use? Do you cut it to the same size as the diff rings? And you do both sides? I'm just trying to get as much info as I can before I attemp this conversion.
cyrrus is offline   Reply With Quote
Old 07-08-2005, 04:37 PM   #10253
P-DUB's Avatar
Just superglue the ring to the card, once dry cut the ring from the card so there is no excess card. Put the carded side torwards the gear, tighten diff and back off 1/8 or 1/4 turn
Larry Pryor
P-DUB is offline   Reply With Quote
Old 07-08-2005, 06:46 PM   #10254
STLNLST's Avatar
LMAO
With me not running 19 turn tomorrow you go from BQ to 10th in the A......
....BTW.....you're welcome
Old 07-08-2005, 07:00 PM   #10255
Hmmmmm.....
I haven't run mod in a long time.......
Old 07-08-2005, 07:45 PM   #10256
STLNLST's Avatar
Hmmmmm.....
Tomorrow is going to be so much fun. when I posted my challenge the thread only had 1047 views....now go look at it. I will also share some mic duties along with Ruben and Kathy. Norcal is the place to be tomorrow. Good luck and I'll see you around 2:00pm
If you're running mod....you might want to see if P-DUB offers a rear bumper....
Old 07-08-2005, 07:53 PM   #10257
Matt Howard's Avatar
I just tried to order one but P-DUB said you bought 'em all
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-08-2005, 11:32 PM   #10258
A Ilievski's Avatar
Trader Rating: 39 (100%+)
heres some pics of my mi2 its just a stocky but its still good
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 07-08-2005, 11:34 PM   #10259
A Ilievski's Avatar
pic 2
yous have any advice on weater if i should re arrange the placing of the reciever and esc coz ive read that the reciever is ment to be on highger ground than the esc
Alex Ilievski
Old 07-09-2005, 01:09 AM   #10260
Oasis's Avatar
Trader Rating: 36 (100%+)
On the gear ratio's how can you tell what ratio you are running..The pulley 20 or 17?? What is the "stock" ratio,2.12 or 1.8..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
