Old 07-07-2005, 12:51 AM   #10231
bender's Avatar
Originally Posted by STLNLST
the holes IMO seemed to enhance the over all steering response.
The holes? Which ones?
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 07-07-2005, 01:05 AM   #10232
King-G's Avatar
Send a message via ICQ to King-G
the outer hole of the 3 on each steering bellcrank, gives a more aggressive steering response.
I started with the outer holes when I got my Mi2, but have used the middle position, with a centre link length of 40.5 - 41.0 mm ever since.
nice linear steering throughout the turn.
King-G is offline   Reply With Quote
Old 07-07-2005, 01:09 AM   #10233
King-G's Avatar
KidTTo1...the standard chassis should suit the Indoor track at canberra fine...as Its not Ozite it doesnt have the Bite that would really require an ultrastiff chassis...But if your using foams perhaps try the Teemu chassis.
Kambah when VHT is applied heavily is ultra grippy, so it would be a benefit there...But I wouldnt spend money on that until your really on top of the setup of the car and driving...
Gav
Old 07-07-2005, 05:45 AM   #10234
Default Schumacher at the Aus National's
Hi Gav do you know if any Schumacher driver's are coming to Perth for the National's later this year as it would be good to get some idea's for my son's MI2
John
Hot Bodies D8
Hot Bodies D8T
tao3 is offline   Reply With Quote
Old 07-07-2005, 06:39 AM   #10235
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I'm actually going to be trying the outer Ackerman holes this weekend. I'll post up how I like them.
Jon Kerr is offline   Reply With Quote
Old 07-07-2005, 06:40 AM   #10236
STLNLST's Avatar
Trader Rating: 19 (100%+)
Talking
The holes you asked about.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-07-2005, 08:14 AM   #10237
rbboy's Avatar
Send a message via MSN to rbboy Send a message via Yahoo to rbboy
Smile WOOHOO!!!
finally nailed the set-up on my Mi2... it is finally DIALED WOOOHOOO!!! anyone who may want to try the set-up PM me
www.xtremerchobbiesph.net
rbboy is offline   Reply With Quote
Old 07-07-2005, 08:45 AM   #10238
belgianchamp's Avatar
Send a message via MSN to belgianchamp
Helo,
Put it online so everybody can take a look @ your setup.
belgianchamp is offline   Reply With Quote
Old 07-07-2005, 08:49 AM   #10239
fjm9898's Avatar
if anyone is looking for or needs a new in box, never opened Mi2 let me know, drop me a PM, the link to the selling thread is in my signature
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 07-07-2005, 08:52 AM   #10240
Bender- I personally have used those holes alot (no jokes). I find that the outer holes give less initial steering, but better/more steering in middle of the corner. This should be because of the increase in ackerman provided by these holes. This is especially true for racing in high bite situations like foam tire carpet or VHT outdoor where steering geometry plays a larger roll in how the car handles. Note, I have only used these holes with a oneway or diff, I have never tried them with a spool. Also it is very important to re-adjust your bump steering when you make this change (or any front end change for that matter) so that it is the same as before trying the new holes. Many peple forget this, and get unexpected results for this reason.-Jeff
Jay Dub is offline   Reply With Quote
Old 07-07-2005, 11:46 AM   #10241
AdrianM's Avatar
Has anyone tried the ackerman link in the outer holes on the steering bellcranks?
I've noticed that in all the setups I've downloaded, everyone is using the middle hole.
I have switched to the outer holes on the bellcranks recently. The car seems a lot more aggressive and seems to turn better mid corner. I use a spool 100% of the time.
I have always set my car to be neutral in bump toe but after reading some posts on Todd Hodge's thread and talking to him a bit I want to try some bump toe out next time I race.
Adrian Martinez
Old 07-07-2005, 05:28 PM   #10242
King-G's Avatar
Interesting Adrian..
I havent read Hodge's thread, but it has always been my understanding (from reading a number of engineering manuals) that Bump Toe out should be avoided.
Reduced steering angle of the laden wheel being the main reason, and also unpredictable bump handling response.
I have always used Neutral Bump steer, (on the Mi2 I use 2 x 2mm alloy spacers under the ballstud - With a long Tir Ballstud to ensure theres plenty of thread in the bellcrank to prevent it being stripped out)
pic: http://img8.exs.cx/img8/6192/F_gearbox.jpg
Old 07-07-2005, 07:05 PM   #10243
AdrianM's Avatar
I haven't read Hodge's thread, but it has always been my understanding (from reading a number of engineering manuals) that Bump Toe out should be avoided.
I thought just as you did. The laden wheel will straighten out as the chassis rolled with bump toe out and this is not what you want. However, the inside wheel will turn in more. As Todd explains it bump toe out gives a reactive Ackerman effect that increases turn in and steering in thigh corners.
This is one of those things that we can explain to death one way or another but we would be better off testing on the track. It is easy enough to try. Just remove one 2mm spacer from the bell crank ball stud, re-adjust your front toe and you will have bump toe out.
For neutral toe I mill the arm on the steering knuckle down to the mold parting line (~2mm) and add a 2mm spacer to the bell crank.
Adrian Martinez
Old 07-08-2005, 01:06 AM   #10244
King-G's Avatar
I really am finding it hard to believe that Toe out in bump will give noticable amount of steering gain, when you consider the following.
The Inner wheel (Unladen - closest to apex) has very little weight on it, and does only around 20% of the steering effort.
secondly the unladen wheel wont travel very far, hovering around neutral...it wont be in bump once the car transfers weight and sets...especially when we use 1-2 mm droop on todays T.C's.
If anything the perceived steering gain would come from the inside wheel kind of acting like a brake, as it scrubs beyond maximum useable slip angle.
How soft are your front springs to allow enough compression for the steering angle to actually change much?
I think the gain would come from initial bite from a little toe out as the nose dips slightly, but were talking about a pretty steep link angle for it to have an effect in the first 1-2mm of travel.
It may give a similar feel to reduced castor perhaps (at an extreme angle of steering link). so there is potential for initial steering gain, but I cant see how mid corner - exit would benefit.
Im going to test it this sunday, what the heck, it just darnt maken nun sense.
Old 07-08-2005, 06:10 AM   #10245
AdrianM's Avatar
Most of us use AE Blue (17lb) or Schu Pro Blue (16lb) springs up front.
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
