Old 06-24-2005, 11:37 PM   #10066
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by protc3
Adrian,
That was a very exact,hit the nail on the head explination.very impressive dude.
maybe this is another project huh
Jon Kerr is offline   Reply With Quote
Old 06-25-2005, 08:47 AM   #10067
Conrad's Avatar
Originally Posted by IslandBwoy
Have any of you guys tried the EPIC 19T motors? if so what do you think about them? currently i run my reedy and while i love the top speed it can handle it doesnt have as much punch to make a difference on the in field.
I've tried both motors and the reedy quad mag is a far better motor. The epic has alot of top end and really screams but it's lacking that bit spark out of the turns. The reedy has alot better midrange and is very punchy with still good top end.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 06-25-2005, 09:08 AM   #10068
STLNLST's Avatar
Trader Rating: 19 (100%+)
It all depends on how you gear them and how they are tuned. I'm assuming that the Epic can that we are talking about is the C2. Is this correct??? I always ran the Reedy can until a couple of weeks ago when I was tuning motors for the local racers for our annual race out here and was really impressed with the combo my buddy Scott B. came up with and when we duplicated it to my motor it was a rocket. Next time out on a med sized track try trinity 4499 brushes and purple spring on pos and red spring on the neg and gear it with a final drive ratio of 6.2 and see how that works for you.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-25-2005, 09:31 AM   #10069
P-DUB's Avatar
STLNLST....You finally got your car into the Magz (extreme R/C)!!!! Everything has been going so well since the body change
Some decals on that thing would of been nice
Larry Pryor
P-DUB is offline   Reply With Quote
Old 06-25-2005, 11:00 AM   #10070
Conrad's Avatar
Yeah it was a C2, tried it with 4499's and red springs all round and it didnt make any difference. I was racing indoors on carpet so my ratio wasnt quite that low but the c2 was flat mid range but was very strong top end, could of just been a duff motor but i wasnt the only person using one at the time and other peeps thought the same as me. Everyone else uses V2's here, i'm not a fan so the reedy works for me.
Old 06-25-2005, 11:50 AM   #10071
STLNLST's Avatar
what race made it into the magazine? was it the Reedy? I'll put some stickers on it after today...LOL
Old 06-25-2005, 04:33 PM   #10072
P-DUB's Avatar
Yeah, the Reedy Race!!! Nice support buddy j/k
Larry Pryor
Old 06-26-2005, 12:36 AM   #10073
bender's Avatar
Guys I really need some setup help here. I have been trying to dial in my Mi2 to this one track for the last 4 or 5 meetings and nothing seems to work. Weylin has helped me with some setups but I'm still having lots of trouble.
Basically, I've lost all turn-in and nothing I change seems to make much difference. I have been using brakes on a lot of corners to slow the car down - most of the other guys running stock don't have to touch the brakes!
Even with brakes, the car still pushes into turns.
I have attached a map of the track with the turns numbered so you can see what areas I'm talking about.
The car has lots of push entering turns 1,2,7 & 8 and lots of power-on understeer on turn 6.
I've also attached my "best" current setup - it will take too long to list all the things I've tried.
cheers,
Bender
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 06-26-2005, 07:26 AM   #10074
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Bender,
Do you have excessive chassis rub in the front ? Maybe you have too much droop in the rear, and the car is dumping in the hairpins.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 06-26-2005, 10:50 AM   #10075
STLNLST's Avatar
just a little testing update for you spool freaks....LOL The oneway set up that I posted on www.gearchart.com also works with a spool and no other changes to the set up. Just take out the oneway and put in the spool.....but due to the fact that 99% of the guys on here are Adrian followers LMAO just follow the set up with your exsisting spool
PW- The stickers will be on the car in the next hour or two. I couldn't sticker up a body that wasn't mine at the Reedy
Old 06-26-2005, 11:01 AM   #10076
Jon Kerr's Avatar
They just thought it was you on the track
Old 06-26-2005, 11:08 AM   #10077
STLNLST's Avatar
That was some Pdub type driving in the main.
Old 06-26-2005, 12:27 PM   #10078
bender's Avatar
Originally Posted by TimPotter
Bender,
I think there is some rubbing on the front edge of the chassis where it meets the bumper, I'll have a closer look this afternoon.
What do you mean by "dumping", is that too much weight transfer?
Jason W
Old 06-26-2005, 04:44 PM   #10079
papadocks's Avatar
Default HELLO
looking to get rid of my axis 2 whats a good starting price ?
thanks guy .......i know this is the wrong place
papadocks@comcast.net
papadocks is offline   Reply With Quote
Old 06-26-2005, 05:17 PM   #10080
P-DUB's Avatar
Hello Bender...I see quite a few things I would change:
Front:
Black swaybar
Remove riser plate and replace with 1.5mm shim
Rear:
35wt oil
5mm ride height
Black swaybar
shock mount on lower arm 2nd hole in from outside (most important)
Spool (locked diff)
Battery moved back to middle
Larry Pryor
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
