Old 06-21-2005, 09:31 AM   #10036
HarshGuy's Avatar
Originally Posted by STLNLST
and all of them stayed ahead of you I normally let the Xray guys choose which chassis they would like to get beat with....LOL
Dang dude ...that hurt
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 06-21-2005, 09:45 AM   #10037
Matt Howard's Avatar
Originally Posted by HarshGuy
Yea STLNLST has gone from "car of the month" to "motor of the month" to "chassis of the month"
Yeah but he'll always have the excuse of the week
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-21-2005, 11:37 AM   #10038
Oasis's Avatar
Trader Rating: 36 (100%+)
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 06-21-2005, 07:18 PM   #10039
cornerspeed's Avatar
Hey Jon, Do you by chance have any wheels, Rev-Lites that I can use this weekend? I forgot to order some.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 06-21-2005, 10:52 PM   #10040
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Nope. Sorry.
Jon Kerr is offline   Reply With Quote
Old 06-21-2005, 11:07 PM   #10041
Originally Posted by Jon Kerr
Nope. Sorry.
Thats ok. I will make another order tomorow.
Donny Vinkemulder
TLR Driver
Old 06-22-2005, 10:53 AM   #10042
Default bmi chassis
thanks 4 that jon,car looks cool,
im having a problem with the rear of my car i cant stop it from overstering,my car at the min is.
front:
spool
2dg camber
-1 toe
blue spring,45 wt oil
5.5mm droop (with shui gadge)
ride hight 5.5mm
shocks on mid hol top and outer on bottom
1mm spacer on front pivot block
rear
roll bar yellow
3dg toe
2dg camber
ride hight 6mm
droop 4
40 wt oil blue spring
shock 2nd hole from botom (top)
shock 2nd hole from outer (botom)
camber link flat (if u no what i mean?)
1mm washer under rear pivot block
runing with cs-22 tyres, std chassis running on tarmac
thanks bob
bob33 is offline   Reply With Quote
Old 06-22-2005, 12:17 PM   #10043
Jon Kerr's Avatar
Fist off, take the yellow bar off the rear and put on a black 1.5mm bar. Also, are those the stock blue springs from the kit? I honestly never ran those and don't know what they're rated at but I'd suggest getting some Associated Blue and silver springs. Also, take out some camber. I pretty much always run only 1 degree of camber all around. Lower the ride height to 5mm all around. Give those adjustments a try and see how it is.
Old 06-22-2005, 12:23 PM   #10044
yeah i will then, but will the ae springs fit std shocks??? yeah blue is the stock set thanks for that i will giv it a go. bob
Old 06-22-2005, 12:30 PM   #10045
Jon Kerr's Avatar
I think you need to use the old preload spacers under the threaded collar to take up the gap since the AE springs aren't long enough. Someone, if I'm wrong on this, correct me.
Old 06-22-2005, 12:41 PM   #10046
o and one more thing, i have made my spool with the diff by taking the balls out and glueing a shui header card on the diff rings is this right becaus i get lots and lots of chatter wen i turn with power on is thins normal ?? it works fine i just dnt like the sound it makes lol.
Old 06-22-2005, 01:04 PM   #10047
Jon Kerr's Avatar
Chatter is something that happens to pretty much all cars running spools. And yes, you built it the right way. Make sure since you're running a spool that you change the front blades often. You'll notice the spool wears them out quickly.
Old 06-22-2005, 01:24 PM   #10048
thats good then thanks, racing sunday i will see how the changes go thanks bob
Old 06-22-2005, 02:28 PM   #10049
Send a message via ICQ to piorc
Default rw spurs
Hi guys, i was reading this forum ,and i have 2 questions:
1) Im going to use rw 64 pitch 128T spur, am i need something to convert it to fit in my mi2? what?? part numbers please.
2) is it normal u have a little play on the 20t pulley?? what i do to dont have anymore?
Thanks a lot.
Marcelo-Brazil
piorc is offline   Reply With Quote
Old 06-22-2005, 03:17 PM   #10050
Jon Kerr's Avatar
Thanks a lot.
Marcelo-Brazil
You'll need the alloy gear adapter, part# U2744.
There is some play in the 20t pulley. RW just came out with a new machined 20t pulley, part# RW1000, I believe that will pretty much eliminate that. I'll be getting one on my next order.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
