Old 06-17-2005, 06:57 PM   #10006
Thraex's Avatar
Thanks jon for the fast reply!
I'll take a look at the car, but maybe it's just better if I wait for the Mi3.
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 06-17-2005, 07:54 PM   #10007
IslandBwoy's Avatar
The way I see shock length, as long as it's not limiting your droop and ride height and they are equal on both sides, it should be just fine.
Thats how i saw it too J. but i just wanted to see what you guys thought because there have been a few people blasted for not following setup sheet to the letter in the past ;-)
IslandBwoy is offline   Reply With Quote
Old 06-17-2005, 08:01 PM   #10008
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Well, the setups do need to be followed exactly. Shock length really is the only thing I can think of that wouldn't really effect much as long as it's not limiting droop and such.
Jon Kerr is offline   Reply With Quote
Old 06-18-2005, 04:03 AM   #10009
John_S's Avatar
you may have to wait a while i think
John_S is offline   Reply With Quote
Old 06-18-2005, 08:44 AM   #10010
Originally Posted by HarshGuy
....just ordered me up a couple sets ...I'll lyk how they work, I've got TRF's on my car, but they're at a bit of an angle, I thing that shoulder on your chingadera's will take care of that
Is your shock cap touching the tower on the rear? That plastic shock top mount looks a little tweaked like it's forced up against something? The Tamiya shocks look awesome on the Xray though.
Art Jensen is offline   Reply With Quote
Old 06-18-2005, 09:10 AM   #10011
Thraex's Avatar
Ohh well, it's not that I need a new car right a way.
I'm still going strong with my "old" FK04
Thijs van M[HPI/HB]
Old 06-18-2005, 10:12 AM   #10012
HarshGuy's Avatar
Actually ...they look better now ....refresh your page, I had the pics of the old shocks on my server :-) ...no the tamiya ball cups provide enough clearance for the caps to clear, NOTHING binds on the shocks, I had driven a 3 mm screw from front to back so they wouldn't pop off the ball cup and it bound them a little bit so I added a cone washer:
The only "issue" I see is that the shocks are kind of at an angle not bad but at an angle nontheless, just looks wierd, not sure if it affects the performance. I was gonna add some washers to fix that, but it looked to "ghetto" ...that's where I think the pdub ones would solve that issue without looking ghetto
...BTW I though about that after I posted the pics ...an xray pic on the Scheuy thread ...I'm TOAST
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 06-18-2005, 05:44 PM   #10013
I am sure it's all good.
I would put spacers either behind the shock mount (Getto or not) or space the tower to achieve a perfectly vertical shock. JMO
Old 06-18-2005, 06:04 PM   #10014
hobbipro's Avatar
Trader Rating: 21 (100%+)
After owning a few tamiya's, I decided to mounted my TRF shocks the same way to my MI2. Just get the 5mm florine coated ball nut (TAM53599), and flourine coated ball stud (TAM53598). The ball nut mounts on the shock tower with a 3mm srew through the back to secure it, use a few spacers to get your shock as verticle as you want ( if you look, actually the MI2 stock mount has some angle to it too). the threaded ball stud has the same threads as stock so all you do is replace the stocker with the 5mm stud. I built my shocks with the included tamiya plastic shock shaft ends (short), and it turns out beautifly. You can get the non-florine coated studs/nut as well to save a few $$, but they sure do make is smooth as silk, plus you get 10 in a pack.
hobbipro is offline   Reply With Quote
Old 06-19-2005, 06:58 PM   #10015
King-G's Avatar
Send a message via ICQ to King-G
Congrats to Teemu Leino, Winning the Nordic Championships (Euro Warmup) in Fine Fashion with 3 straight Finals Victories.
King-G is offline   Reply With Quote
Old 06-19-2005, 07:28 PM   #10016
Jon Kerr's Avatar
Went and practiced today. Made some progress with the BMi chassis and higher flex top deck setup. I'm still sorting some things out but it's coming a long nicely. Once I get some things I'm confidant with I'll post them up.
Old 06-19-2005, 07:46 PM   #10017
P-DUB's Avatar
Yes, very good result for Teemu
Larry Pryor
P-DUB is offline   Reply With Quote
Old 06-19-2005, 07:48 PM   #10018
Jon Kerr's Avatar
Are there any writeups for the race on line?
Old 06-19-2005, 08:46 PM   #10019
cornerspeed's Avatar
Way to go Teemu.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 06-19-2005, 10:22 PM   #10020
STLNLST's Avatar
Trader Rating: 19 (100%+)
I'm back after a mini vacation. Was right down the way from the Norrca nats but didn't feel like going by the track to check things out. I'll be testing my new set up at Ripon next weekend. It was killer at Speedworld.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
