Old 06-16-2005, 11:24 PM   #9991
A Ilievski's Avatar
Trader Rating: 39 (100%+)
hey guyd i got my mi2 i it didnt come with a pinion gear what pinion gear should i use with a 95tooth spur
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 06-17-2005, 01:09 AM   #9992
I'd say that you need a pinion between 20-30 tooth. It's kind of hard to be more precise without knowing your motors and track. Even same type of motors can require different pinions, some up to 2-3 teeth.
If you know what final gearing your motor and track needs, check the needed pinion out in the manual. If you don't know, ask some locals about a ballpark figure, start with a bit smaller pinion (=higher gearing) and work your way up from there, checking every once in a while that your motor doesn't overheat (especially if you're running stock).
If you're racing, you need more than one pinion anyway...
olev is offline   Reply With Quote
Old 06-17-2005, 04:49 AM   #9993
Barry_Hughes's Avatar
Originally Posted by cyrrus
I have a couple of question are the Tamiya shock a dirrect replacement or is there any type of mod involved.
My other question is I have the Stock shock towers. on the car it has a set of low profile towers(guessing better for carpet.)
One last question do ae springs fit. on a small tight track what type of springs do you recommed.
The Tamiya shocks work with the low (Carpet Towers) if running Schumacher shocks you should use the stock towers. You need need different top mounts to fit the Tamiya shocks.
AE springs fit the Tamiya shocks, as do the new Pro Springs from Schumacher.
Small tight track I run 40 weight three hole front with AE blue springs, 35 weight three hole rear with AE blue springs
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 06-17-2005, 05:29 AM   #9994
P-DUB's Avatar
Mounting Tamiya shocks to the Mi2 made easy http://www.pdubracing.com/products.htm Scroll to the bottom of the page
Larry Pryor
P-DUB is offline   Reply With Quote
Old 06-17-2005, 06:12 AM   #9995
Great thanks
cyrrus is offline   Reply With Quote
Old 06-17-2005, 07:38 AM   #9996
belgianchamp's Avatar
Send a message via MSN to belgianchamp
With the TAM shocks is the schumi more stable than the SCHUMI'S and they are better to do oil in.I run with 40 on the front and 40 on the rear with 3 holes .The length of my shocks are 61.5mm (front and rear).On tarmac i use blue on the front and silver on the rear.When i driving high grip circuit.(mostly carpet)i use blue on the rear and gold on the front.
belgianchamp is offline   Reply With Quote
Old 06-17-2005, 12:38 PM   #9997
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
TRF shocks are more consistent build to build and much easier to build. AE blue (F) and silver (R) is a very common combination. I know PW put AE blue and Schumacher whites in the back and liked it a lot.
I'm going to be doing some testing with new setups on the BMi 2.5mm chassis and higher flex top deck. Different spring combos, shock locations, roll centers, etc... I'll post some stuff up once I get some track time.
Jon Kerr is offline   Reply With Quote
Old 06-17-2005, 05:14 PM   #9998
A Ilievski's Avatar
i put my TRF shocks on my Mi2 and alli did was just a like washer/spacers i think and it worked ok. and by the way i tried to put a 25teeth pinion with the 95 spur and for some reason when i acelarate the gears get to tight so it doesnt spin how can i fix this?
alex
Alex Ilievski
Old 06-17-2005, 05:31 PM   #9999
HarshGuy's Avatar
Is that just a 3 mm screw you would put through those badboys?
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 06-17-2005, 05:43 PM   #10000
P-DUB's Avatar
Yep, thats it
Larry Pryor
Old 06-17-2005, 05:56 PM   #10001
HarshGuy's Avatar
Yep, thats it
....just ordered me up a couple sets ...I'll lyk how they work, I've got TRF's on my car, but they're at a bit of an angle, I thing that shoulder on your chingadera's will take care of that
Old 06-17-2005, 06:09 PM   #10002
Thraex's Avatar
So the car is more stable if you're using the tamiya shocks, does that mean the schumi shocks are bad?
I mean is it essensial to replace the orginal schumi's by trf's?
(I'm planning buying a new tourer so that's why I'd like to know)
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 06-17-2005, 06:44 PM   #10003
IslandBwoy's Avatar
Default SPRING LENGTH
Hey Guys,
Thank for the response on the previous question but i got one more. I am switching my car from a Adrian based setup to a Padillla based setup and i was wondering how critical is it to have the exact same shock length when following the setup sheet. Before you get buck wild on me i have always followed the setup sheets passed to be to the T. However, since my last setup I’ve had to cut the ball joints on my Tamiya shocks to aceive ride height. After having than done i noticed that there was so much material gone (aprx. 1mm) that i could vary my shock length too much before the shaft didn’t have enough threading to remain stable. Therefore my shock would sometime buckle causing it to separate and thus i loss control.
Thus i ask against, how important is it to use the same shock length in these setups? If i am able to make ride height, and my oil is the same, and my shocks are the same, wouldn’t the shock’s length not affect the car????
MI jeDI
IslandBwoy is offline   Reply With Quote
Old 06-17-2005, 06:54 PM   #10004
Jon Kerr's Avatar
It's not requider for the car to run well. It's just a nice thing to have. TRF shocks are IMO and I know many others, the best shocks on the market. But you can run and be competitive with the stock one as well.
Old 06-17-2005, 06:55 PM   #10005
Jon Kerr's Avatar
Originally Posted by IslandBwoy
Hey Guys,
MI jeDI
The way I see shock length, as long as it's not limiting your droop and ride height and they are equal on both sides, it should be just fine.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
