Old 01-05-2002, 03:59 PM   #976
Send a message via AIM to Type S
adrian M i need to order some parts from shumacher usa, who do i call to order them? thanks
Type S is offline   Reply With Quote
Old 01-05-2002, 04:18 PM   #977
cornerspeed's Avatar
I can answer 2 of your questions.
The grey belts are more efficient and faster. I've been using the front grey with a 7-2 motor. Holding up well and have the run time. Car is a cruise missile.
The wieght of my carbon mission and titanium is 50.4. Well under wieght.
cornerspeed is offline   Reply With Quote
Old 01-05-2002, 04:25 PM   #978
I myself have only tested the 17 pulley. My team mate Jay W. at SoCal has tried both. He so far likes the 20 pulley. It is a rather small track, so I am hesitant to try it yet. My car is extremely fast. I feels faster with a 8-2 compared to a 7-2. Not sure if I'm geared for the 7 turn yet. His car with the 20 pulley is not looking to me to accelarate as good as should. He ended up turning a faster lap time then me though. I think his car steered a little more then mine or its because he drives harder. We are still working hard to get set-up for this track, but getting close.
Old 01-05-2002, 04:51 PM   #979
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
OK....
I tell you what P-Dub, you drop one in the mail, and I'll do some further testing for you.......
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 01-05-2002, 06:24 PM   #980
Ty
Ty's Avatar
Trader Rating: 25 (100%+)
What size 64 pitch spur gear are most of you guys running for stock? I want to use the largest spur I can fit but also have enough room for the motor to be moved back and forth on the motor mount for the pinions.
Also, the car seems to come with plastic CVD shafts, is that right? And why are most people running the steel shafts for carpet in stock? What are the advantages over the plastic drive shafts and what is the part number and price. Thanks again.
Ty is offline   Reply With Quote
Old 01-05-2002, 06:59 PM   #981
hey guys, is it easier to order off of the shumacher site, or to call up shumacher in florida and order from them?
Old 01-05-2002, 08:06 PM   #982
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
Well guys, I ran the my mission today for the first time since Cleveland, and BOY WAS IT A AWSOME TIME!!! I also found a new dialed setup, that for you guys running foams, will deff want to try! I will post it here, if some one is interested........
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 01-05-2002, 08:50 PM   #983
Sure please post your set-up with a discription of the track conditions would be helpful.
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-06-2002, 05:52 AM   #984
Send a message via ICQ to MattW
Ty, The stiffest springs that Schumacher do are 35lb and Silver.
The driveshafts have plastic bones. Some people change to the steels as they think they are going to break, i have seen a couple break but have never broken any myself. I use the steel in the rear, and plastic in the front.
MattW is offline   Reply With Quote
Old 01-06-2002, 08:36 AM   #985
Racer X's Avatar
Type S: Call Adrain, he works there...
TY: I run a 116 or a 115 (depending on brand). Ialso run the plastic drive shafts for less rotating weight in stock, plus the metal are not needed if all you run is stock.
Cornerspeed: Email me, I can't find your email address so I can send you the setup sheets. JMaurer1@Concentric.Net
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 01-06-2002, 08:47 AM   #986
Ty
Ty's Avatar
Thanks for all the replies so far guys.
Old 01-06-2002, 11:19 AM   #987
Ty
Ty's Avatar
So if I want stiffer springs than the Schumacher silvers, do the Associated springs fit the Schumacher shocks?
Corey Bernardo,
How was the Mission compared to the TC3's in stock? Can you post your setup and are running any mods like grey belts or anything extra? Thanks so much.
Old 01-06-2002, 01:25 PM   #988
STLNLST's Avatar
Trader Rating: 19 (100%+)
Racer X- Good run yesterday. Damn does that car have steering. It will take some getting use to if I were to run that car. One battery pack wasn't enough to really get a feel for the car. Tom did look like a racer on a mission Also thanks for the heads up on that speedo. Did you see what happened to mine? It's back to the 7.1 until I get my TC2.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-06-2002, 02:20 PM   #989
Ty, I haven't ever tried them myself, but am fairly sure that they fit fine. Although i think they are a bit shorter than the Schumacher ones.
Old 01-06-2002, 03:07 PM   #990
Ty
Ty's Avatar
MattW,
Thanks for the reply.
Corey Bernardo,
Are you using TRC and Jaco 28mm wheels? I had to put a washer on the hex hub on my Yokomo and Axis 2 for the 28mm foam tire wheels to clear. Do you have to do that on the Mission?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
