Old 06-03-2005, 12:38 PM   #9826
Cole Trickle's Avatar
Originally Posted by AdrianM
If no one can run sauce everyone will be in the same boat.
True. With my old HPI Pro2, which now will go to pension, I use to have TOO much traction, even without sauce However, I have absolutely no idea about how these two cars compares handling wise, with the same tires, track and driver.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 06-03-2005, 01:02 PM   #9827
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
That's true Adrian, but out of curiosity, how would they enforce that? I know I usually use motor spray to clean the dirt and crap off the tires after a run. Would that be considered saucing tires?
Jon Kerr is offline   Reply With Quote
Old 06-03-2005, 01:33 PM   #9828
STLNLST's Avatar
Trader Rating: 21 (100%+)
I gotta take my car apart tonight and change a few things for some testing this weekend. I'm thinking of trying the oneway in 19 turn....then again I may just run the spool since the set up from the Reedy is pretty dialed.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-03-2005, 02:56 PM   #9829
PW
PW's Avatar
Send a message via AIM to PW
Which ever you choose, please refer to page 14 in your Mi2 manual for installation
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 06-03-2005, 03:12 PM   #9830
John_S's Avatar
im running pre mounted 22s
John_S is offline   Reply With Quote
Old 06-03-2005, 08:56 PM   #9831
speedxl's Avatar
R/C Tech Charter Subscriber
Why would you use that awful thing they call a oneway! Stay with the spool Clint its faster!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 06-03-2005, 09:48 PM   #9832
Jon Kerr's Avatar
Old 06-04-2005, 01:54 AM   #9833
STLNLST's Avatar
I went to public school PW so you are going to have th post a pic of what you're talking about...LOL
Old 06-04-2005, 06:38 PM   #9834
STLNLST's Avatar
Kept the spool in and the car was pretty good at times. traction would come and go and that made it sort of hard to dial your set up in. We all ran mod....some guys had oneways and some stuck with the spool. At the end of the racing day these are my thoughts....
in mod the spool had it's advantages over the oneway (especially at the end of the straight) and the oneway looked smoother in other sections of the track. The end result was TQ set by a oneway car but the win went to Mo with a spool.
in 19 turn the oneway cars seemed to own the track. It could be this particular layout or the practice some of these guys have put in (Congrats to my buddy Harshguy) For next weekends Speedworld cup I plan on running a oneway in 19 turn if the layout is some what flowing. Most have stuck with the spool but is it me wanting to throw in a oneway to gain a touch more corner speed instead of working harder with my spool set up? The two guys in 19 turn to beat at our track are running Xray's with oneway's. I want to change that come next weekend. Any and all suggestions are more than welcome. If worse comes to worse I'll just go in the living room and ask MO....LOL
Old 06-04-2005, 11:09 PM   #9835
speedxl's Avatar
Hey Clint I'll give you a good set up for a spool that you can run in 19t also.
It carrys good corner speed and stable. PM me your number I'll have you dialed. All we run down here is spools even though we are allowed to run a oneway. Its faster and more consistant everywhere. Most of the guys at the worlds were running them in the main,that should give you and idea how much better it is. 90% of tracks I've run a spool is best!!
Old 06-05-2005, 01:50 AM   #9836
A Ilievski's Avatar
Trader Rating: 39 (100%+)
hi what hop ups should i do to the Mi2 to improve it
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 06-05-2005, 03:02 AM   #9837
bender's Avatar
Hey guys I've got a couple of questions,
Firstly, does anyone know of an on-line shop that sells 10x15mm flanged bearings - but NOT the kit type. My car has only done about 5 meetings and now a couple of the blue seals are starting to fall off during a race - so I'd like to find a better replacement, but haven't located any so far.
Secondly, I tried raising the rear riser plate today (1mm) to free up the car a bit in the corners - it worked but I would like to try lowering the front by 1mm as this is supposed to give more steering, - the question is where will I gain steering? Turn in, mid corner, exit, or everywhere?
cheers
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 06-05-2005, 04:26 AM   #9838
hobbipro's Avatar
Default Bearings
Try www.bocabearings.com I think thats there web sight. They have all kinds of bearings from buget all the way up to ceramic hybrids. You should be able to get those 15x10mm flanged in a 4 package too.
hobbipro is offline   Reply With Quote
Old 06-05-2005, 09:20 AM   #9839
STLNLST's Avatar
cheers
the seals do come off rather easily but the bearing are still good. Don't be too quick to run out and get the higher priced bearings. It's a nice upgrade but it's not really needed unless you blow out a bearing or it's starting to fell gritty.
Old 06-05-2005, 09:38 AM   #9840
Jon Kerr's Avatar
cheers
Lowering the front will make the car turn in harder. I like to do this as well as add 1mm of antisquat to the rear. This also helps turn the car into the corner a little but it will really help square up the rear end coming out of the corner so the rear dosen't want to continue to come around.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
