Old 06-02-2005, 02:32 PM   #9811
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Are you running a spool? Are you running outdoor aspalt or carpet? More info please
Jon Kerr is offline   Reply With Quote
Old 06-02-2005, 02:59 PM   #9812
AdrianM's Avatar
Could be as simple as the car is pushing and you are having to turn the wheel too much to stay on line.
Could be too much camber gain in the front suspension. Where is your inner camber link? We pretty much always run the upper middle hole.
How hot is it where you are running (assuming you are outside)? If the track is over 75deg you should be running CS27's or RP30 or 36's.
Adrian Martinez
Old 06-02-2005, 03:07 PM   #9813
you guys are all very welcome. im glad that i was able to contribute some way,,,lol, it sure wasnt with my driving or set up tips,,,,,tooo fun ny...
gdcopbadcop is offline   Reply With Quote
Old 06-02-2005, 06:10 PM   #9814
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
Originally Posted by John_S
hey guys i am having some irregular tires wearing problems and was wondering if you could help, i am runing -1 degree camber front and back. The back tires wear perfectly and i have no problem with them, but the fronts are quite strange. The last set of cs22s i had both got a really bad lip on the inside edge of the tire and now i notice after 2 days racing that one of the front tires is through to the tire belt already. I usually get a much longer tire life than 2 meetings and was wondering if you know any solutions for this. Thanks
maybe you got a bad pair of cs 22
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 06-03-2005, 06:00 AM   #9815
Cole Trickle's Avatar
Hi there
Is there some kind of tracks, which the MI2 are better suited for than others?
Thanks.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 06-03-2005, 06:25 AM   #9816
AdrianM's Avatar
The Mi2 can be set up to run on any surface with any tire. We haven't come across a condition where the Mi2, given a good setup and a good driver, couldn't be a winning car.
Adrian Martinez
Old 06-03-2005, 06:27 AM   #9817
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by Cole Trickle
Hi there
Thanks.
The Mi2 works well on most surfaces, but it excels on asphalt with rubber tires
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 06-03-2005, 06:32 AM   #9818
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
seaball is offline   Reply With Quote
Old 06-03-2005, 06:37 AM   #9819
How is it with rubber tires on carpet?
It will be different types of carpet, mainly without tire sauce, but once in a while with this messy and dirty fludium I driven my old car pretty far, so I believe I can do the same with any chassis
Old 06-03-2005, 06:47 AM   #9820
AdrianM's Avatar
Its really good on carpet/rubber. That all they run in Europe and Teemu is usually top 3 or 5 at every major race.
Adrian Martinez
Old 06-03-2005, 06:48 AM   #9821
STLNLST's Avatar
Trader Rating: 19 (100%+)
The car work killer on carpet with rubber tire's....but we have never run without sauce. I would think that the car would be sort of loose without sauce....but then again with the right set up it might feel pretty dialed.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-03-2005, 07:02 AM   #9822
AdrianM's Avatar
If no one can run sauce everyone will be in the same boat.
Adrian Martinez
Old 06-03-2005, 07:48 AM   #9823
PW
PW's Avatar
Thanks EA!! Not to bad yourself for last minute racin Thank you again for helping out Team Schumacher with some MAD HP's in 19turn!!!!
Special thanks to Latif (Mr. Trinity) for supplying brushes for 19 turn
Paul Wynn
Old 06-03-2005, 09:18 AM   #9824
John_S's Avatar
hi im runin a double diff car on a fairly cold day (about 5degree air temp) and i use a standard setups othert than removing the rear riser plate and rear roll bar and 30wt oil in the rear, the rest is as the manual states to set up. And also i sue -1degree cmaber front and rear
John_S is offline   Reply With Quote
Old 06-03-2005, 11:13 AM   #9825
Are you using pre-mounted CS22's or have you glued them onto rims yourself?
Last time I had that problem I was running 24mm tyres on 25 mm rims...
Regards
Dan
dhamblin is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
