Old 05-04-2005, 05:50 PM   #9586
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
And with one of the bodies I'll be taking to the race.
Jon Kerr is offline   Reply With Quote
Old 05-04-2005, 06:49 PM   #9587
PW
PW's Avatar
Send a message via AIM to PW
Originally posted by AZ_Ron
Hi Paul... I've got your old Mission Pro that I've just started racing on carpet here in Phoenix...I'm the only Schuie guy... I was also the only Alex guy.
Ron
Send me an e-mail and I will see what I can come up with paul@schumacherusa.net
WOW Jon...I better get to work, I haven't even started on my Reedy Race stuff Car is looking good!
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 05-04-2005, 07:14 PM   #9588
AZ_Ron's Avatar
Trader Rating: 16 (100%+)
Thanks Paul...Email sent...
Ron
AZ_Ron is offline   Reply With Quote
Old 05-04-2005, 08:55 PM   #9589
cornerspeed's Avatar
Originally posted by LoSi xXx S
I think i have the one that should be the same as the schumacher one. cause theres 2 that hudy sells the one that says 0 and the one that says 20mm and i got the one that says 0 and me looking at the schumacher one they look pretty much the same exept hudy is step and schu is the slide one.
You can set the droop actual, then measure with your droop gauges. Write that down and your ready for that setting for whenever you need to check it. Just double check with actual droop measurment each time to be sure. I always do that anyway to check the tweak of the car.
I also have been experimenting with this set-up with a 1.2mm rear sway bar and more front droop-3mm to 3.5mm. It actually seems to added mid-corner to on power steering with more droop. Car feels freer in the corners. I know its opposite of what is suppose to happen, but lap times did prove it. The lap times are approximatly the same between RP30's and Sorex 36R's. More testing and evaluation will be done in 2 weeks along with RP30's.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 05-04-2005, 09:28 PM   #9590
Jon Kerr's Avatar
Yeah, when Donny made that change last weekend it was awesome to watch his car.
Donny, So Cal is on for Saturday (Reluctantly ) then the Babcock race in Hesperia the next week. Right? I've got a couple sets of tires coming in for Hesperia to work with.
Old 05-04-2005, 10:41 PM   #9591
Cool, its on. Especially for Hesperia. I want to go up Saturday and practice, then stay up there for the Babcock race.
Donny Vinkemulder
TLR Driver
Old 05-04-2005, 11:32 PM   #9592
donny, what is the front sway bar your using????
see you in a couple of weeeks,,
rich
gdcopbadcop is offline   Reply With Quote
Old 05-05-2005, 06:57 AM   #9593
PW
PW's Avatar
Hey Donny....Did you stay with the 1.5mm bar in the back when you switched front bars?
No Socal racing for either of you unless it's with a practice car
gdcopbadcop....The optional swaybar kit from Schumacher has 2 bar sizes; Silver=1.2mm & Black=1.5mm (part #U2728)
Paul Wynn
Old 05-05-2005, 10:14 AM   #9594
Jon Kerr's Avatar
Donny stayed with the 1.5mm in the front and went to the 1.2mm in the rear.
PW, I may just do that I've got an older stock chassis I may have to put on the BMI car. That stiffer chassis didn't work well at SoCal. Not enough flex.
Old 05-05-2005, 10:19 AM   #9595
PW
PW's Avatar
I gotcha....Do you know what each change did separately?
Paul Wynn
Old 05-05-2005, 10:24 AM   #9596
Jon Kerr's Avatar
Not sure about that. Donny will have to answer that one.
Old 05-05-2005, 01:44 PM   #9597
Jon Kerr's Avatar
PW- just got my tires. Thanks for the hat.
Old 05-05-2005, 05:44 PM   #9598
lmunno's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to lmunno
. . . . and bodies !!!
Jon: Car looks SWEET!!!
lmunno is offline   Reply With Quote
Old 05-05-2005, 05:57 PM   #9599
Hey PW, I use the 1.5mm bar in the front. Except at SoCal with a one-way, then its a 1.7 in front and 1.2 in back. Still a little sketchy with a one-way, but I'm working on it. Made a lot of headway.
Donny Vinkemulder
TLR Driver
Old 05-05-2005, 06:00 PM   #9600
Oh, by the way about running my car at SoCal. I am setting up my spare car as I speak for there. My good car is my original MI2 from Febuary '04. Going on 15 month old car.
Donny Vinkemulder
TLR Driver
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
