Old 05-03-2005, 01:12 PM   #9571
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
Oh well i used the ae one cause i cant find my hudy one anywhere! I probably left it in my buddys trailer.
Roberto Falcon is offline   Reply With Quote
Old 05-03-2005, 02:10 PM   #9572
Send a message via ICQ to MattW
I use the method that Jon describes as it works for tyres that are of slightly different diameter. If you set if to x on a droop guage, that is fine, but if you then happen to use a tyre that is a little bigger - either because of a thicker insert or bigger wheel, you have changed your droop setting.
MattW is offline   Reply With Quote
Old 05-03-2005, 02:16 PM   #9573
Ok i dont like this method i want to stick to the other one !
Old 05-03-2005, 04:27 PM   #9574
IslandBwoy's Avatar
...those stupid snap rings out of the diffs, but they arn't very good body scissors anymore..
LOL. Good one. I broke down and got me a set of c ring remover thingy ma jiggies from sears and its the perfect fit. But now that i removed the clip i was suprirse to see that nothing came out of the outdrive ????? it was like the damn thing was there for style. On the other side of the out drive i can see a few washers being held into place by i dont know what but i'm going to mess with that later. I just wanted to test out my new $20 c ring remover that didnt do anything ;-)
R
IslandBwoy is offline   Reply With Quote
Old 05-03-2005, 04:36 PM   #9575
mo
mo's Avatar
The washers and thrust assembly didn't come out because it is probably stuck together with grease and dirt. That all pushes out through the outdrive.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 05-03-2005, 06:19 PM   #9576
steveM3's Avatar
Default New Fusion Team pack for sale (1.181 voltage)
I am selling one of my team packs for $80. I will pay for shipping if in US. If you bought this pack on Fusion's website, it would cost you $99.99. Only respond if you are serious about owning this pack with some tremendous punch and great run time at 428-429 run time. See picture attached
Steve McNichols
Serpent- Desoto Racing
steveM3 is offline   Reply With Quote
Old 05-04-2005, 07:43 AM   #9577
PW
PW's Avatar
Send a message via AIM to PW
If you're going to the Reedy Race, make sure you get your parts orders in soon
RP30's are also back in stock
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 05-04-2005, 07:54 AM   #9578
AZ_Ron's Avatar
Trader Rating: 16 (100%+)
Hi Paul... I've got your old Mission Pro that I've just started racing on carpet here in Phoenix...I'm the only Schuie guy... I was also the only Alex guy.
I've got a carpet setup sheet of of Jon Kerr, but am he was using AE springs... what Schuie springs do you recommend on carpet??
I've got them all, just trying to cut down on my test & tune time...
Thanks!
Ron
AZ_Ron is offline   Reply With Quote
Old 05-04-2005, 03:06 PM   #9579
STLNLST's Avatar
Trader Rating: 21 (100%+)
how soon is soon.......LOL
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-04-2005, 04:10 PM   #9580
Jon can you tell me whats the droop doing it the normal way?
Old 05-04-2005, 04:17 PM   #9581
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Well, this is the normal way But like I said, different droop gauges read differently. I'll chack mine on the Schumacher gauge when I get home but I'm not sure it'll be the same as a Hudy gauge. But I'll go ahead and post it anyways.
Jon Kerr is offline   Reply With Quote
Old 05-04-2005, 04:29 PM   #9582
Alright ..
But i want to know somthing why so much droop and im right with mine ?
Old 05-04-2005, 04:49 PM   #9583
I think i have the one that should be the same as the schumacher one. cause theres 2 that hudy sells the one that says 0 and the one that says 20mm and i got the one that says 0 and me looking at the schumacher one they look pretty much the same exept hudy is step and schu is the slide one.
Old 05-04-2005, 05:27 PM   #9584
Jon Kerr's Avatar
OK, I just measured mine with the Schumacher gauges. The blocks are 10mm blocks to prop the car up and the 0 on the gauge is at the same level. So with the 2mm plate in the rear and 1mm shims in the front, your measure meant should be 4.5 in the rear and 3.5 in the front. Also remember, you'll get different readings if you change the roll center riser plates. But that's where it should be on the gauge.
Old 05-04-2005, 05:49 PM   #9585
Jon Kerr's Avatar
Here's my car for the Reedy Race. All good to go.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
